Latest post Wed, Aug 20 2008 9:14 PM by Kevin Klimek. 36 replies.
Page 1 of 3 (37 items) 1 2 3 Next >
  • Wed, Jun 18 2008 2:17 AM
    • Divebum
    • Joined on Sat, May 27 2006
    • Key Largo, FL
    • Posts 57
    • Points 695
    Upgrading to MC 3.0 Dongle Problems
     Hello, this afternoon I purchased the MC 3.0 upgrade from 2.7, followed the install instructions from AVID and now when I launch MC it starts to launch and then immediately when the Boot info screen appears it immediately closes down.  I have read through some threads for testing the dongle and now when I double click on "Dongle Updater" I get "DBHelper.exf was corrupted or could not be found.
    - the dongle light is on
    - I registered the upgrade
    - I followed the instructions
    - I have no editing system anymore
    HELP!  Thank you.
    Avid Media Composer 2.7 (3.0 maybe) MOJO SDI Sorenson HP XW8000 Dual 3.06GHZ/4GB RAM XP Pro Quadro 1100 G-Tech 500 MB External (Dual Partitioned) G-Tech... [view my complete system specs]
  • Wed, Jun 18 2008 2:20 AM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,260
    • Points 168,260
      Moderator: MCA Mac
    Re: Upgrading to MC 3.0 Dongle Problems
    Hi...
    What you need to do is to download the dongle manager (Which you should  actually have since it's required to update your  dongle to 3.0) from avid.com/dongle and run it.
    The manager will tell you for what version your dongle is blasted. If it doesn't say 3.0, you will need to get out  the instructions for updating your dongle and follow those.
  • Wed, Jun 18 2008 2:22 AM In reply to
    • Divebum
    • Key Largo, FL
    • Posts 57
    • Points 695
     Hi there.  Correct, it was part of the upgrade flow.  It went through the process perfectly, showed and tested good for 3.0 and "Blasted" (which I WAS excited about) fine.  It had all the appearances of working perfectly...and here I am.
  • Wed, Jun 18 2008 2:25 AM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,260
    • Points 168,260
      Moderator: MCA Mac
    Good so then the quitting out is probably not due to your dongle.
    In that case, I would start by disconnecting everything from the CPU (Except  the keyboard and monitor of course) and see if the system will start. If it doesn't, see if you can tell what the boot process starts to do before it quits.
  • Wed, Jun 18 2008 2:30 AM In reply to
    • Divebum
    • Key Largo, FL
    • Posts 57
    • Points 695
     I may have mis-spoken.  The system is running perfectly.  It is only MC that "flash launches".  I say "flash launches" because it literally starts to launch and then immediately dissapears. It doesn't lock up or anything and the system continues to run fine. We did do a USB test and all work good, specifically the port the dongle is in.
    I'm happy to try your suggestion if you still think that is a direction.
    Thnx.
  • Wed, Jun 18 2008 2:32 AM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,260
    • Points 168,260
      Moderator: MCA Mac
    When I say "disconnect", I don't mean the dongle. I'm referring to any media drives or any other peripherals you may have attached.
    What's happening is the Avid is starting to access its boot routine but a conflict is causing it to crash. I'm just trying to troubleshoot starting at a baseline.
    If  you don't have any luck, I would do a complete uninstall and reinstall and try again.
    Is this Vista or XP?
  • Wed, Jun 18 2008 2:37 AM In reply to
    • Divebum
    • Key Largo, FL
    • Posts 57
    • Points 695
     Gotchya.  We will try that now.  We attempted a full uninstall and re-install twice.  Everything seemed fine.  It won't even let us launch 2.7 from the box.  Although, I must admit, I am a bit confused how this update works.
    XP
    Let me pull everything and try this.
    Thnx.
  • Wed, Jun 18 2008 2:49 AM In reply to
    • Divebum
    • Key Largo, FL
    • Posts 57
    • Points 695
     Okay, disconnected all peripherals and the results were the same. :(
  • Wed, Jun 18 2008 3:21 AM In reply to
    Did you fully uninstall 2.7.x before installing 3.0?  From the ReadMe ...
    Cleaning up Old Folders Before Installation
    Do the following to clean up old folders before you install the new ones if you are
    performing an upgrade.
    To clean up folders:
    1. Before installing Media Composer 3.0, you need to uninstall your old verison and any
    version of FilmScribe, EDL Manager, MediaLog, and Avid Log Exchange.
    2. Remove the following Registry keys on your system if they still exist after the
    uninstallation process.
    HKLM/Software/Avid Technology/<productname>
    HKLM/Software/Avid Technology/AVX Plug-ins
    3. From the following folders, remove any folders that do not have custom data in them
    that you want to keep. If you do have custom data, copy the data to the new locations
    after step 4.
    C:/Documents and Settings/AllUsers/ApplicationData/Avid/<productname>
    C:/Program Files/Avid/<ProductName>
    (Vista) C:/ProgramData/Avid/<Productname>
    4. Install the new Avid editing application.
  • Wed, Jun 18 2008 3:24 AM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,260
    • Points 168,260
      Moderator: MCA Mac
    Yep, that's what I meant  by a full uninstall.
  • Wed, Jun 18 2008 3:31 AM In reply to
    • Divebum
    • Key Largo, FL
    • Posts 57
    • Points 695
     Yes, we followed that process to uninstall.  We even went so far as to strip nearly 100% of anything and everything off the hard drive.  Not that there was much, this is solely an AVID machine.  I have a few other systems that are not AVID certified.  I may jut try installing on one of them and at least see where it ends up in the launch process.  What do you think?
  • Wed, Jun 18 2008 3:52 AM In reply to
    • jasperfdo
    • Joined on Wed, Oct 11 2006
    • Los Angeles
    • Posts 492
    • Points 6,350
    FYI - this may not be your issue, but in the last two months my Avid install would open and then immediately close.  Turned out I had been hammered with a virus and it somehow infected the Avid executable I guess....I had to reinstall Windows completely.
    Dell Precision 690, Intel 3.2GHz Dual Core Xeon (5060)4GB RAM, nVidia Quadro FX 3500 / Media Composer v3.0 / Mojo [view my complete system specs]
    kyler boudreau | www.theatereleven.com
    "Sometimes I wonder if men and women really suit each other. Perhaps they should live next door and just visit now and then. " - Katharine Hepburn
  • Wed, Jun 18 2008 8:43 AM In reply to
    • Divebum
    • Key Largo, FL
    • Posts 57
    • Points 695
     Well, couple things. 1. It takes exctly 5 hours to completely reinstall XP Pro.  2. Re-installing XP Pro didn't help one single bit.  However, one odd thing is that there is no Dongle Dumper folder or file.  When I double click on Dongle Manager it seems to be reading the dongle and it says 3.0.
    Looks like I am left with calling AVID.  GREAT!
    Thanks for your help.  If you have any additional thoughts I would love to hear them.
    Conrad
  • Wed, Jun 18 2008 12:55 PM In reply to
    • daveswan
    • London, UK
    • Posts 187
    • Points 2,355
     Can I come back in to my thread!
    I tried twice today to update my dongle, after giving the site time for any version cycling (Sorry, don't knoe how to put it better), but still no joy, the same error message.
    Bit fed up, and giving myself a good kicking, since if I'd held my nerve and waited another week I'd have got MC3 straight off, with the new goodies.
    Dave
    MESH P4 3.0 GHz, 1.5 GB PC 3200 DDR RAM, 160 GB system disk, 250 GB media disk, SoundBlaster Audigy zx platinum, nVidia FX 5700/250MB. Xpress pro HD 5... [view my complete system specs]
  • Wed, Jun 18 2008 1:08 PM In reply to
    • camoscato
    • Posts 4,518
    • Points 53,965
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Hi Dave,
    Have you done all the stuff in this post yet?  If so, and you're not getting any help after emailing dongle support, I'd contact Marianna and see if she can light a fire under somebody.
    good luck,
    Carl
