Latest post Fri, Jun 20 2008 3:09 PM by erik1185. 9 replies.
Page 1 of 1 (10 items)
  • Tue, Jun 17 2008 8:14 PM
    • erik1185
    • Gaithersburg, MD
    • Posts 738
    • Points 9,200
    Cant capture with manual deck control
    Using MC 3.0 and a canopus acedvio. I can no longer capture using manual deck control. 2.8.3 worked fine. Can someone test this out on there system. Thanks.
    Intel Core 2 Duo 3.0 GHZ, 2GB ram, Nvidia Quadro FX 570 [view my complete system specs]
  • Tue, Jun 17 2008 8:21 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,267
    • Points 168,385
      Moderator: MCA Mac
    Re: Cant captures with manual deck control
    It would help to know exactly what is happening to prevent you from capturing. Are you getting an error? Do you no longer see video or audio?
  • Tue, Jun 17 2008 8:22 PM In reply to
    • erik1185
    • Gaithersburg, MD
    • Posts 738
    • Points 9,200
    I cant see video or hear audio in the source monitor. If I click record I get a message saying "video and/or audio is no longer coming into the system".
  • Tue, Jun 17 2008 11:11 PM In reply to
    • robg
    • Tewksbury, MA
    • Posts 124
    • Points 1,660
      Moderator: Avid Symphony Nitris
    1394 capture direct from the camera, yes?
    Are you connected into a supported 1394 card in your PC, or using a motherboard 1394 connection? (Can't tell in the posted system config).
  • Wed, Jun 18 2008 11:43 AM In reply to
    • erik1185
    • Gaithersburg, MD
    • Posts 738
    • Points 9,200
    Ok, suddenly it started working again.
  • Thu, Jun 19 2008 4:23 PM In reply to
    • erik1185
    • Gaithersburg, MD
    • Posts 738
    • Points 9,200
      Ok, so now I have another problem. The colors are all screwed up. They are inverted and gray. About every 10 seconds the colors will switch back to normal and then go back to inverted again. I checked and replaced the cables and the problem is still present. This doesn't happen on my Avid training dvd though. I wonder if this has something to do with copy protection? Here's a screen shot.
  • Thu, Jun 19 2008 4:35 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,511
    • Points 65,790
     Check the levels on your video input tool.
  • Thu, Jun 19 2008 4:58 PM In reply to
    • outpostbc
    • Joined on Tue, Feb 21 2006
    • Lenexa,KS
    • Posts 46
    • Points 595
    erik1185:
    You are correct, that looks like an issue with the analog Macrovison copy protection. It doesn't happen with a non copy protected DVD, correct?
    Media Composer Nitris DX 3.0 Dual 3GHz Quad Mac Pro 4GB Ram 10.5.3, Symphony Nitris DX 3.0 Dual 3GHz Quad Mac Pro 4GB Ram 10.5.3, Unity MediaNet 5.1 [view my complete system specs]
  • Thu, Jun 19 2008 8:11 PM In reply to
    • erik1185
    • Gaithersburg, MD
    • Posts 738
    • Points 9,200
    "It doesn't happen with a non copy protected DVD, correct?" Correct.
  • Fri, Jun 20 2008 3:09 PM In reply to
    • erik1185
    • Gaithersburg, MD
    • Posts 738
    • Points 9,200
    bump
