Latest post Wed, Jun 18 2008 8:33 AM by jwrl. 50 replies.
Page 1 of 4 (51 items) 1 2 3 4 Next >
  • Tue, Jun 17 2008 6:19 PM
    • MovieMaker76
    • Joined on Tue, Mar 25 2008
    • Los Angeles
    • Posts 166
    • Points 2,160
    Can only EXPORT 2GB???
    Please help me.  I have tried to get help with technical support - they have not fixed my problem.
    I can only export 2 GB of video.
    Yes, I am exporting as quicktime NOT AVI.  Some people think it is only an avi problem (NOT TRUE)
    Yes, my drivers are NTFS - besides, another error is to think FAT32 only exports 2gb, not true, they can do 4GB.
    Please help.  This is my business, rent money, food on the table.  This is how I support my family.  And I cannot even get out a product which is completely edited.
    The other frustrating thing is Avid will not let you know until the export is FINISHED before it tells you that it is too big.
    I have cut the timeline up, and it still says too big - BUT, not until hours after it has been exporting.
    PLEASE HELP ME - This is a desperate plea, as I have no one else.
    Sincerely,
    Todd
    Intel Core 2 Duo E 6700, RAID(0), NVIDIA Quadro FX 3450/4000, 4GB ram, Vista64, MC 3.0 [view my complete system specs]
    Filed under: , , ,
  • Tue, Jun 17 2008 6:31 PM In reply to
    • GeorgeD
    • Posts 86
    • Points 1,015
    Re: Can only EXPORT 2GB???
    Todd, if you are in a hurry to get it out why not use an alternate method and leave the trouble shooting for later. I would make a video mixdown, put it on the top track, export a quicktime reference file and use another program to create whatever quicktime file you need. Such as Quicktime Pro, Canopus, TMPEG, After FX, Premiere....
  • Tue, Jun 17 2008 6:34 PM In reply to
    • MovieMaker76
    • Los Angeles
    • Posts 166
    • Points 2,160
    I will figure out an alternative for short term.  But, when you spend thousands of dollars on software - only being able to export 2gb???  that is ridiculous.
    Anyone know how to export more than 2gb on quickitme?
  • Tue, Jun 17 2008 7:14 PM In reply to
    • MovieMaker76
    • Los Angeles
    • Posts 166
    • Points 2,160
    I tried what you said.  Did the video mixdown, but STILL unable to export as a qucktime reference.  I shot it in HDV.
  • Tue, Jun 17 2008 7:21 PM In reply to
    Yes you can export QT files larger than 2 or 4 GB. I have done 100+ GB QT.
    What codec are you using?
    MovieMaker76:
    QT does not support MPEG stream natively. So HDV QT reference is not possible. You will need to transcode first.
  • Tue, Jun 17 2008 7:28 PM In reply to
    • MovieMaker76
    • Los Angeles
    • Posts 166
    • Points 2,160
    Dom,
    Please, enlighten me.  I exported as quicktime movie / animation / even field / 1440,1080 / 601,709)
    What am I doing?
  • Tue, Jun 17 2008 7:42 PM In reply to
    • GCapps
    • San Diego
    • Posts 27
    • Points 425
     I also often export much larger than 2GB files.. just finished exporting a 7.6GB file to our FCP suite this morning.
    I don't know exactly why your system won't let you do it, and if you've made sure your drives are formatted correctly, then you might try  transcoding your sequence to a different format vs. sticking with HDV. once transcoded, you will be able to export out a QT ref file and encode for your DVD
    Adrenaline MC 2.8.3, HP xw8200, Intel Dual 2.6GHz, 3.0 GB ram, Nvidia Quatro FX 3400, Atto 320U, HUGE array [view my complete system specs]
  • Tue, Jun 17 2008 7:54 PM In reply to
    • Fazz Powell
    • Joined on Sun, Dec 3 2006
    • Annapolis, MD
    • Posts 239
    • Points 3,380
    Adrenaline DNxHD 2.8.1 HP8400 Dual 3.0Ghz, Adrenaline DNxHD 2.8.1 HP8400 Dual 2.6Ghz, Final Cut Studio 2 8-Core 2.8Ghz, Discreet Edit 6.5 Uncompressed... [view my complete system specs]
  • Tue, Jun 17 2008 7:56 PM In reply to
    • MovieMaker76
    • Los Angeles
    • Posts 166
    • Points 2,160
    Yes, my drives are formatted correctly.  With this same system, I used Premiere Pro, and never had this problem.
    I did a video mixdown and exported as quicktime reference, but get choppy playback.  WHAT IS WRONG WITH AVID????
    I have called and emailed technical support - but have not gotten the help I need.
    I am sorry for venting, I am just so frustrated, as my client needed this last week - I SIGNED a contract.  I will be in trouble if I don't get this out.
    Anyone, anywhere... SAVE ME
  • Tue, Jun 17 2008 7:59 PM In reply to
    • MovieMaker76
    • Los Angeles
    • Posts 166
    • Points 2,160
    Fazz,
    Your link will not open.  But, in is not an ntfs fat issue.  fat32, allows 4gb.  and I have ntfs.
    thanks for the help though
  • Tue, Jun 17 2008 8:12 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,696
    • Points 161,335
      Moderator: MCA Mac
    Try this instead.
    I don't believe this is an Avid issue. It sounds more like a system problem. We export large QTs all the time.
    Have you tried exporting the large QT to your internal HD?
    Can you list your drive configurations for us? How many drives (in total in the setup), drive letter assignments. Which drive is set as the Media store for the project at hand. Wink
    MSI Neo-2 Platinum Nforce3 Ultra (Bios Rev 1.0D) Athlon64 X2 4200+ (Overclocked to 2 x 2.4GHz) AMD Cool'N'Quiet CPU Throttling 2GB Corsair PC3200... [view my complete system specs]
  • Tue, Jun 17 2008 8:17 PM In reply to
    MovieMaker76:
    What am I doing?
    Sorry but I am unsure what you are asking. My only question was what version of QT are you using?
    Playback is choppy on what? The QT file in QT player? What codec did you use? A HD QT Animation or even DNxHD often does not play smoothly in QT Player because of the horsepower (drive, CPU, etc) needed.
  • Tue, Jun 17 2008 8:28 PM In reply to
    • MovieMaker76
    • Los Angeles
    • Posts 166
    • Points 2,160
    Yes,
    I have exported and imported from an internal HD.
  • Tue, Jun 17 2008 8:32 PM In reply to
    • MovieMaker76
    • Los Angeles
    • Posts 166
    • Points 2,160
    Version of quicktime is 7.4.5.
    I am exporting as animation.  But, have 4gigs, and a powerful processor: intel core 2 duo E6700.
    My video card is Nvidia quadro FX 3450/4000 sdi
