Latest post Tue, Jun 17 2008 9:24 PM by NP. 8 replies.
Page 1 of 1 (9 items)
  • Mon, Jun 16 2008 8:01 PM
    • axel andy
    • Toledo, Ohio
    • Posts 134
    • Points 1,725
    copy & paste to new track...new thread
    I'm starting a new thread because the last one I started began to lose me...
    I just was able to copy several clips that were side by side on audio track 1 to audio track 2.  Actually, in seg. mode I marked an in & out point of the segment on audio track 1; copied (to clipboard).  Then I moved all those highlighted clips down to track 2.  Then I pasted the orginal clip back onto track 1.  Now when I try it I am unable to do any more than 1 clip at a time.  I don't want to simply pan my single track to the middle.  I want 2 tracks of the same audio (with all the keyframes I already put in).
    K
    Dell Precision 340 Workstation Win XP Pent 4, 1.80 Ghz 512 MB ram ACPI Uniprocessor PC Disk drives: IC35l120 avva07-0 SCSI (x2) Prolific PL3507... [view my complete system specs]
  • Mon, Jun 16 2008 8:11 PM In reply to
    • NP
    • Edmonton
    • Posts 47
    • Points 540
    Re: copy & paste to new track...new thread
    Rather than moving the clips after you copy them - you can open the clipboard monitor and then paste the clips from the clipboard onto track 2 using the same in & out points - just make sure to turn off track 1 when you paste to track two.
  • Mon, Jun 16 2008 8:23 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,430
    • Points 64,905
     You can mark an in to out region of your timeline and CTRL + ALT +c will load that material in your source monitor. You can then patch source tracks to record tracks any way you want. This is a great workaround for editing a portion of a sequence back into itself - something the software does not allow you to do directly.  You never have to touch the clipboard.
  • Mon, Jun 16 2008 9:58 PM In reply to
    • axel andy
    • Toledo, Ohio
    • Posts 134
    • Points 1,725
     Larry -
    I marked an in/out point on the audio track & did a "ctrl/alt/c" but nothing loaded into the source monitor.  I then tried it with the audio & video tracks turned on and still nothing loaded into the source monitor.  Is this a "MAC" command?
    K
  • Mon, Jun 16 2008 10:09 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,243
    • Points 167,995
      Moderator: MCA Mac
    Nope, but I believe the command is actually just alt+c.
  • Mon, Jun 16 2008 10:42 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,430
    • Points 64,905
     Strange, because on my systems both ALT + c and CTRL + ALT + c work. I guess that's a DV Express quirk.
  • Mon, Jun 16 2008 11:36 PM In reply to
    • axel andy
    • Toledo, Ohio
    • Posts 134
    • Points 1,725
     ALT + c brings up my clip menu
    and CTRL + ALT + c bring up nothing.
    K
  • Mon, Jun 16 2008 11:51 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,430
    • Points 64,905
     Well the only explanation would appear to be this shortcut is just not available in DV Express. That's a shame because it's a real time-saver. A workaround would be to create a new sequence, use your existing sequence as a source and cross patch any way you want to.
  • Tue, Jun 17 2008 9:24 PM In reply to
    • NP
    • Edmonton
    • Posts 47
    • Points 540
     Or use the clipboard monitor.  It works the same as source monitor.
