Latest post Sat, Jun 28 2008 8:15 PM by Rignold. 11 replies.
Page 1 of 1 (12 items)
  • Mon, Jun 16 2008 5:25 PM
    • Vin
    • Joined on Fri, Jun 13 2008
    • Posts 9
    • Points 115
    MC3 with 9800 Gx2 and 8800 gtx
     Test system: MC 3.0/WinXP SP3, self-built, water cooled, Intel QX9650 over clocked to 3.7 GHz.
    Problem: MC3 crash at acpl with 8800 gtx
    Solution: use Riva Tuner to emulate quadro 4600
    Problem: MC3 crash at acpl with 9800 gx2
    Solution: use RivaTuner to force open-gl 1.5.  The 9800 gx2 is actually two cards, so force open-gl 1.5 on both.   Also, the 9800 gx2 runs stable but very hot.  I recommend water cooling, or use it to heat your small studio during winter.
    Thanks to previous posters for the RivaTuner tip.
    Vin
  • Fri, Jun 20 2008 2:24 PM In reply to
    • JVR
    • Joined on Thu, Jul 13 2006
    • Bulli , Australia
    • Posts 1,205
    • Points 13,405
    Re: MC3 with 9800 Gx2 and 8800 gtx
    SP3 is not supported!
    MC 3.0 AXP 5.8.3 QTime 7.3 win xp pro service pak 2 Core 2 Duo Quad core 2.4 clocked to 3.1 4 gig ram 667mhz pci x nvidia 512mb geforce 8600 162... [view my complete system specs]
  • Fri, Jun 20 2008 3:20 PM In reply to
    JVR:
    haha you point out that SP3 is not supported, when he is using two cards that arent even supported lol Stick out tongue
    Intel Xeon E5345 Quad 2.33GHz - TyanS2696 MotherBoard - 4Gb Quad Channel DDR2 667 Ram - Nvidia Quadro FX 540 - 160GB (boot drive) 1.2 TB Raid 0 (4x320... [view my complete system specs]
  • Fri, Jun 20 2008 4:18 PM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,326
    • Points 38,225
    SP3 is supported with MC 3.  And soft-modding a GeForce card to Quadro with RivaTuner also works.  My previous system used an unmodded GeForce 9750 which also worked.
  • Fri, Jun 20 2008 5:19 PM In reply to
    I have Riva Tuner installed in my system for a long time. I mainly use it for controlling the fan of the GPU. I have not installed v3 on my home system. Hopefully, I dont need to do the soft mod.
  • Fri, Jun 20 2008 10:11 PM In reply to
    • Vin
    • Posts 9
    • Points 115
    I do take Avid's approved hardware list into great consideration, however I build my own systems and what is and is not supported comes out via my own research.  The new nvidia GTX 280 also works with MC3.0 via the opengl 1.5 mod in Rivatuner.
  • Fri, Jun 20 2008 11:35 PM In reply to
    Im new to using RivaTuner. How easy is it to soft mod my Geforce 7900 GTX?
    Thanks!
  • Sat, Jun 21 2008 1:02 AM In reply to
    • JVR
    • Bulli , Australia
    • Posts 1,205
    • Points 13,405
    jwrl:
    John I just checked the ReadMe and SP3 is not mentioned?
  • Sat, Jun 21 2008 4:16 AM In reply to
    • jwrl
    • Posts 3,326
    • Points 38,225
    [EDIT]  I just checked the link that I'd been directed to.  I have installed SP3, and it's working, but now it appears that although any updates released to May are supported, SP3 has not been checked by engineering and is currently "use at own peril" - which I am, albeit inadvertently.
    However the risk to me appears low, since SP3 is SP2 plus all updates to May '08.  Up to now after one week's reasonably intensive testing my system is stable,
  • Sat, Jun 21 2008 4:23 AM In reply to
    • JVR
    • Bulli , Australia
    • Posts 1,205
    • Points 13,405
     Smile
  • Sat, Jun 21 2008 4:31 AM In reply to
    • jwrl
    • Posts 3,326
    • Points 38,225
    Yes, sorry.  I corrected my previous post.
  • Sat, Jun 28 2008 8:15 PM In reply to
    • Rignold
    • Cape Town
    • Posts 75
    • Points 1,080
    jkhristian:
    Thanks!
    Hi JK.  I've just soft modded my GeForce 7900GT to a Quadro FX1500. Got all the info from this site.
    http://www.techarp.com/showarticle.aspx?artno=539&pgno=1
    Good luck!
    Asus P5K3 Deluxe Motherboard, Intel Core 2 Duo E6600 Conroe 2.4GHz, 4gig DDR3 1333mhz RAM, PNY Quadro FX1700(Driver 169.47), XFX GeForce 7900GT, QT 7.45... [view my complete system specs]
    Before you judge a man walk a mile in his shoes. After that who cares, you're a mile away and you've got his shoes.
