Latest post Sat, Jun 21 2008 7:06 PM by Butcher. 156 replies.
Page 3 of 11 (157 items) < Previous 1 2 3 4 5 Next > ... Last »
  • Tue, Jun 17 2008 1:52 PM In reply to
    • JVR
    • Joined on Thu, Jul 13 2006
    • Bulli , Australia
    • Posts 1,359
    • Points 15,335
    Re: Complaint post
    Locked Contact
    I just thought to let you know I just ordered my MC 3.0 upgrade from AXP looking forward to it bugs or no bugs it's the best system out there the rest really just aren't in the same league...Cool
    MC 3.5.4 QTime 7.6 2x Vista Ultimate 64bit sp1 2x XW 8400 2 x 3.0gig Xeons 5160 146.8GB 15K Ultra320 o/s drive 8 gig ram FX 1500 4 1tb 32 mb... [view my complete system specs]
  • Tue, Jun 17 2008 1:55 PM In reply to
    • Butcher
    • Joined on Mon, Apr 17 2006
    • Evansville, IN
    • Posts 1,331
    • Points 16,955
    Re: Complaint post
    Locked Contact
    CR8VDO:
    have the proper hardware
    Your system specs say you have an nVidia 8800 card.  That's not the proper hardware.  I'd therefore say it's safe to assume that any and all issues you've had with your Avid software are entirely your fault because you deviated from the required hardware.  Buy a certified system first...install and run Avid second...if that doesn't work, then complain.  Otherwise, your opinion is moot because you failed to follow the requirements.
    CR8VDO:
    Would you expect a moderator to say anything less.
    You obviously haven't been to these forums much.  I've seen Blkdog crucify Avid with the best of them.  He's hands down the most impartial and openminded moderator I've come across.  He knows what works with Avid and he knows what's broken and he'll fairly point out both.
    Michael.
    Dell Precision 490 Dual 3.2GHz Dual Core Processors (Hyper Threading disabled) 4GB RAM nVidia Quadro FX3450 driver 169.47 (nVidia driver supplied by... [view my complete system specs]
  • Tue, Jun 17 2008 2:46 PM In reply to
    • tompearson
    • Joined on Thu, Mar 1 2007
    • Wayzata MN
    • Posts 579
    • Points 6,245
    Re: Complaint post
    Locked Contact
            so you dont like the software or the company  so shut up and edit with what ever you like  oh wait you dont like any of the apps oh well  i  will set here and edit with a big smile  as i  enjoy mc-3.0 working rock solid on my unqualified system
    and for the record i do respect the mod's here they take a lot of bs from some bitchie people i for one would be still back on premire pro complaining about constant lock ups   i raise my glass to you guys and gals Marianna is the rock of avid
    peace
    asus mb p5wd2 dualcore 3 gig intel cpu's 4 gig crucial ram nvidia quadro fx 3500 1 tb wd sata 7200 raid 0 seagate 160 gig sata 7200 os drive mojo command... [view my complete system specs]
    Tom Pearson Director Hollywood-sounds.com
  • Tue, Jun 17 2008 3:17 PM In reply to
    Re: Complaint post
    Locked Contact
    One observation:
    I find it interesting that some users on these forums note that because Avid is a "resource hog" it needs a certified/qualified system to operate properly.  The implication is that this heavy use of resources is a good thing.
    It seems strange to me that we (as users) would encourage a company to have a resource-intensive application.  I've heard people (not necessarily on these forums) complain about bloat in Operating Systems, Browsers, Antivirus, and even other professional applications (Photoshop, etc.).  Yet somehow it's a great thing that Avid can only work on specific systems because it requires huge resources.
    I don't deny that an application like Avid will take a significant amount of power.  However, I do question some of the listed requirements and apparently incompatibilities that appear again and again with no remedy.
    Additionally, there's no doubt that this community is far better than many others, but there seems to be a pervading sense of "Avid is a gift to mankind" (particularly on this thread); "we should all thank Avid for how it has enriched our lives."  The closest thing I can compare it to is the Apple reality distortion field.
    Intel Core 2 Duo E6750 2.66Ghz 3 GB Crucial Ballistix DDR2 800 (2x1GB, 2x512MB;) XFX GeForce 8800GT 512MB 250 GB Seagate HD (System) 3x500 GB Western Digital... [view my complete system specs]
  • Tue, Jun 17 2008 3:23 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,838
    • Points 201,280
    Re: Complaint post
    Locked Contact
    I don't think that the discussion about "Resources" necessarily refers to Code resources. More, I think it's directed to Avid's unique ability to do things like play back multiple streams of HD (even different frame sizes and rasters) in real time to name a simple ability. Avid does much more heavy lifting than just about any other NLE out there and those capabilities require a tight rein on the hardware side.
    On the other hand, I do agree that the code itself has reached the tipping point and, though 3.0 has done much to stream line it, could use a re-write from the ground up. However, I don't believe it's necessarily CPU resources we're talking about here.
  • Tue, Jun 17 2008 3:31 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,005
    • Points 107,160
      Moderator: Meridien
    Re: Complaint post
    Locked Contact
    Steeldestroyer:
    Whoever said that most likely, like myself, came over to Avid from the linear world of editing. I don't think you can fully appreciate just how true that quote is unless you've come over as well. NLE only editors have NO IDEA what it took to create complex multi-layered, multi-effects programs in that environment. What an advanced level Avid editor can achieve in 15-20 minutes, including rendering could easily take an entire 8 hour work day in the linear world. I'll never forget the first time I fully realized just how much productivity power I had at my fingertips. It was like someone cut the ropes holding my hands behind my back and allowed me to change my mind without losing it. And for that I am very grateful to Avid - the true pioneer in Non-Linear Editing from which all others have come.
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
    Re: Complaint post
    Locked Contact
    Steeldestroyer:
    No that is not the problem. Avid is actually a very efficient software especially when you factor in its age. It minimizes/maximizes will little trouble. You can open other apps along with it. You can encode while you edit. etc.
    The problem is how Avid interfaces with the basic components of your computer (at least on the PC side). Avid does not seem to use a standard HAL system. So changes in hardware can break Avid without some involvement from Avid engineers. To shift to that, like resolution independence, probably would require a complete rewrite. We are talking about several years of top engineers working full time (aka million$$$). Eventually Avid has to do it. I just hoped it started around the DNA era (as that hardware would have revealed this weakness).
    MC 3.1.3, Intel i7 920, Vista 64 bit, Nvidia GTX 275, 6 GB of RAM, X-Fi Titanium Professional, MSI X58 SLI Platinum. [view my complete system specs]
  • Tue, Jun 17 2008 5:05 PM In reply to
    Re: Complaint post
    Locked Contact
     I find it realy funny when some keep saying how Avid needs to be able to run on all computers and so on. And they keep talking about how other NLE systems or so much better. Like FCP. well last time i looked FCP only run on a Mac... and what.. wait Avid runs on PC and MAC!   WOW talk about haveing a step on things eh?
    Intel Xeon E5345 Quad 2.33GHz - TyanS2696 MotherBoard - 4Gb Quad Channel DDR2 667 Ram - Nvidia Quadro FX 540 - 160GB (boot drive) 1.2 TB Raid 0 (4x320... [view my complete system specs]
  • Tue, Jun 17 2008 5:09 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,005
    • Points 107,160
      Moderator: Meridien
    Re: Complaint post
    Locked Contact
     I've always wondered myself why Apple refuses to port FCP for PC, given the potential spike in market share.
  • Tue, Jun 17 2008 5:16 PM In reply to
    Re: Complaint post
    Locked Contact
    " I've always wondered myself why Apple refuses to port FCP for PC ..."
    • The current version drives sales of their "own" hardware
    • The R&D might not actually have a sustainable ROI
    • They would then need to support, literally, thousnds of hardware combinations (something even Avid avoids, by offering a narrow range of platforms)
    Media Composer 3.5.9/4.0.2 w/Mojo (analog), HP xw8400, 1xQC 3.0GHz, 8GB RAM, FX 3700, 1TB Boot, 1 x 1TB & 1 x 500GB internal SATA media drives, 3-Ware... [view my complete system specs]
    Our new websites are up!
    http://www.lifenetintl.org/
    http://www.capitalchristian.net/
  • Tue, Jun 17 2008 5:17 PM In reply to
    • fiendish
    • Posts 343
    • Points 4,155
    Re: Complaint post
    Locked Contact
    because Apple is not interested really in creating a great NLE. They are interested in selling their own hardware.
    xw8600 Dual Quad 3ghz - MC 3.5.4 / QT 7.6 / Win XP / Vista 64 bit with Mojo SDI - 12gb RAM / Quadro 3500 / 3700 and 3ware 9650SE Raid 5 [view my complete system specs]
  • Tue, Jun 17 2008 5:22 PM In reply to
    Re: Complaint post
    Locked Contact
    Larry Rubin:
    Because Apple is a hardware company. And most users overly underestimate software development cost. Meaning at the price point of FCS, the Adobe dominance of desktop apps and does not have the potential constituents as iPods/iTunes, it is not as worth as much as you may think. It is still probably a lot to us pedestrians but I doubt anywhere near iPods.
    It also does not also fit the Apple image. Can you picture FCP running on one of those PC cases that looked like a washed out 1980s metal singer designed it?
    then again, Jobs is the billionaire. Not me.
    Re: Complaint post
    Locked Contact
    Larry Rubin:
    I would hazard to guess that the potential spike in FCP's market share would be directly related to a drop in Apple hardware sales.
    Picture a graph... FCP market share going up over time, sales of MacPro's going down.  The cost of FCP would then have to go up, which may also decrease it's market share as it would then be on a more even playing field with Avid.
  • Tue, Jun 17 2008 5:49 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,005
    • Points 107,160
      Moderator: Meridien
    Re: Complaint post
    Locked Contact
    Kenton.VanNatten:
    Hmmmm....do you think that could be because Apple doesn't have full confidence in it's platforms being superior enough to PCs, if customers could make that choice? From what I see, Mac users are very loyal to Mac and would not buy PC given the choice anyhow. And come to think of it, I can't recall any PC users who express the same degree of product loyalty. I myself would prefer to work on a Mac, but our shop went PC, so I'm stuck with it. But I should have been more specific - I was thinking of the already existing PC user base as opposed to new buyers as the marketing focus. Kind of an add-on market.
  • Tue, Jun 17 2008 6:07 PM In reply to
    • videovic
    • Miami, Florida
    • Posts 13
    • Points 175
    Re: Complaint post
    Locked Contact
     Folks, I agree. AVID recomends using an approved system and going on a non approved is a "proceed at own risk"; AVID is not to blame. My only gripe is JVC 24p HDV. It has been tossed around since XPP days and was now, with MCv3, announced, advertised, media hyped as finally implemented. Some of us have found out the harsh way and are stuck. I have gone the AVID way as for investing in an approved hardware and where is my solution?  Has AVID taken the time to come up front an publicly clarify to us and future clients to be aware of this limitation which is still advertised as a reason to buy or upgrade to MCv3 ?  I know we have to research before we commit, but do we have to search so hard to find the answer or the warning. It feels worse than reading a 20 page contract with vey small fine print.
    I like AVID, their productivity, etc...and I'm a bit mad because I play by the rules and I can't work on my preffered editing program.
    HP9440 portable workstation w/4GB ram 667mhz., Two SATA 7200rpm 120GB drives,XPress Pro 5.8, AVID STUDIO TOOLKIT, AVID MOJO, BORIS RED 4.2, BCC4.2AVX. [view my complete system specs]
