Latest post Sat, Jun 21 2008 7:06 PM by Butcher. 156 replies.
Page 1 of 11 (157 items) 1 2 3 4 5 Next > ... Last »
  • Mon, Jun 16 2008 11:59 AM
    • tpiom
    • Joined on Mon, Jun 16 2008
    • Posts 4
    • Points 105
    Complaint post
    Locked Reply Contact
    I only want to post to ensure you of your customers experience with your software,
    How should I put it... Well i first got Avid Xpress Pro 4.8.1 or something, that installation was more than troublesome and I never got through it. Some time later, I tried with Xpress 5.8.1 (latest) and the installation was better but then when I tried to start it it got stuck initializing audio, probarly because I'm running a Realtek card. I threw it away and went with Premiere Pro (Adobe's) and it works fine...
    And today I tried Media Composer 3.0, everything worked OK with the setup and so on. But when I was about to start it: "your system is not lisenced to run this software." That's it was my thought... I'm going over to Adobe's software completely now. Your programs has too many compadability problems with hardware.
    Be sure to keep in mind that I have upgraded my computer since my experience from (Xpress 4.8.1) to today. Now I'm more than angry with you, wasting time and money on your products. It was a big mistake!
    You seriously need to fix the Realtek problem, it's killing your compnay:
    http://community.avid.com/forums/p/3874/129630.aspx
    http://dvinfo.net/conf/showthread.php?t=61284
    http://forum.videohelp.com/topic336508.html
    http://dvxuser.com/V6/showthread.php?t=110799
    http://forums.creativecow.net/thread/207/55
    And the worst of all, you NEVER released any patch or fix to that problem and when I asked on the boards and your support I got the simply the answer: "Change hardware."
    Remember that Realtek is a major manufacturer of hardware today, and according to stats the AC'78 audio is the most commonly used audio card. I didn't buy any external hardware from Realtek either, I got their sound card from a Asus' motherboard and they are also a leading manufacturer when it comes to hardware. See my point? You're losing more than they do...
    Hope you'll imporve your products in the future, I'm done with you (at least for the coming years...). I'll stick with Adobe's prodcuts so I don't get any serious issues with never-released-fixes and bad support.
    Goodbye Smile
  • Mon, Jun 16 2008 12:12 PM In reply to
    • Paris MkVI
    • Norfolk, VA USA
    • Posts 349
    • Points 4,185
    Re: Complaint post
    And we wish you well.
    With professional editing systems, it is important to fully inviestigate your options prior to purchasing. If you had done so, you would have known, before spending any time - or money - at all, that Avid software has very specific hardware requirements.
    These hardware specifics allow Avid editors to work with the very high level of functionality and flexibility that had made it a leader in this industry for a long time.
    It needs what it needs. Respectfully, your argument is the equivalent of purchasing a work vehicle that has a diesel engine, but being unhappy it does not run on cheaper gasoline.
    Avid is not interested in supporting the most-commonly used audio card. The goal their eyes remain set on is performance. They will sacrifice the wide, easy road of hardware compatibility to maintain that focus.
    They understand their editing solutions are not for everyone. We wish you the best of luck with your other editing options. There's room enough in the world for other editing solutions for other folks, who, like yourself, have some different priorities.
    MCA 2.8.3 on Dell 490 • 4GB Ram • Quadro FX3500 Driver 6.14.10.9185 • Avid rs146 x 2 striped as one • 2 internal 500 GB SATA drives. Edit monitor: Sony... [view my complete system specs]
    A gentle answer turns away wrath, but a harsh word stirs up anger. (Proverbs 15:1 NIV)
  • Mon, Jun 16 2008 12:29 PM In reply to
    • tompearson
    • Joined on Thu, Mar 1 2007
    • Wayzata MN
    • Posts 411
    • Points 4,350
    Re: Complaint post
    my realteck ac 97 works you just have to switch it to 2 channel mode avid does'nt
    work with mulit channel one thought  avid is a PROFESSIONAL EDIT APP
    and you need professional  hardware  if you needed a doctor wouldnt you want him or her
    to use stainless steel  professional doctor hardware? or would you prefer a plastic toy dr tools
    asus mb p5wd2 dualcore 3 gig intel cpu's 4 gig crucial ram nvidia quadro fx 3500 1 tb wd sata 7200 raid 0 seagate 160 gig sata 7200 os drive mojo command... [view my complete system specs]
    Tom Pearson Director Hollywood-sounds.com
  • Mon, Jun 16 2008 12:45 PM In reply to
    • JVR
    • Joined on Thu, Jul 13 2006
    • Bulli , Australia
    • Posts 1,197
    • Points 13,315
    Re: Complaint post
    tpiom:
    Goodbye Smile
    Try this llink it should sort all your problems out...
    http://community.avid.com/forums/p/39988/224106.aspx#224106
    MC 3.0 AXP 5.8.3 QTime 7.3 win xp pro service pak 2 Core 2 Duo Quad core 2.4 clocked to 3.1 4 gig ram 667mhz pci x nvidia 512mb geforce 8600 162... [view my complete system specs]
  • Mon, Jun 16 2008 2:05 PM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,541
    • Points 77,405
    Re: Complaint post
    Most intriguing about this post is the fact that the thread starter tried 4.8.1 and it never worked.. so threw that in the corner.. then waited more then a year to try 5.8x release to discover again it would not work.. then MC3.0 which is a paid upgrade btw also did not work.
    Now that would account for roughly 2500 dollars worth of software just being unused. Thread starter.. if you do go PP please contact me off list.. i want to get your dongle and licenses as you do not use them anyway.. i am willing to pay Wink
    Ok.. enough fun.. The "error"  you got with MC3 is the fact you don not have a (upgraded) dongle in your system.. nothing more nothing less...
    As for realtek there are many working with Realtek since HP is being old with those cards.. just not all realteks will work ... research before you "buy" is always good. And a new SB live will break your bank for 30 bucks at MAX.. and will save you all the trouble in getting software for steep prices and then not using them Smile
    Menno
    Test-Intel Core2Duo 6800,GTS8800 Nvidia (soft modded into Quadro FX4600),Soundblaster Live 5.1, 21" Samsung display [view my complete system specs]
    Dutch AV forum
  • Mon, Jun 16 2008 2:17 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,696
    • Points 161,335
      Moderator: MCA Mac
    Re: Complaint post
    The Avid software is, very much, a professional's tool. Most professionals are very proficient at thoroughly researching their tools before putting them into an asset schedule.
    Thousands of Avid installations are done each day with very little trouble. You just have to be aquatinted with the skill set necessary to research, read and implement an Avid setup. I'm actually happy that this software has not yet been more commoditized than it already is. Sometimes "Plug and Play" really isn't a good thing.
  • Mon, Jun 16 2008 2:25 PM In reply to
    • Baklap
    • Posts 6,541
    • Points 77,405
    Re: Complaint post
    BLKDOG:
    Hence the reason it is often referred to as "plug and pray" Wink
    Menno
    Dutch AV forum
  • Mon, Jun 16 2008 3:03 PM In reply to
    • tpiom
    • Posts 4
    • Points 105
    Re: Complaint post
    But a commonly used hardware doesn't mean it's bad. Take Nvidia for example, they have a big market share and their best card is the fastest on standard PC these days. And myself, I didn't pay for the software - my work did. And they decided to upgrade when this (latest) was released. But I made them also get an alternetive (Premiere Pro) for the computers with a Realtek sound card or any other hardware that causes problem.
    You are also aware that Avid is losing market share right, Apple's FCP is earning some... The software should be compatible with the hardware (not the other way around).
    Still I'm suprised that you didn't release any patch, which basiclly says that you're more interesting in making money than a good application. Because the fix doesn't have to affect the other, maybe a just "Realtek" fix (so the people who have other doens't have to get it).
  • Mon, Jun 16 2008 3:10 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,696
    • Points 161,335
      Moderator: MCA Mac
    Re: Complaint post
    You know that you aren't speaking to anyone working for Avid here...right? We're all Users.
    Like we said, Avid is a professional tool requiring a professional skill set. A lot of what makes this software the best NLE also makes it more important that someone who has more experience is at the helm. If you aren't up to that level yet in your experience, then a more consumer-oriented product like premier may be more in your wheelhouse anyway.
    If you are ever prepared to step up to the big-leagues though, we will be happy to walk you through anything you need to get the app up and running. FOr the amount of money your employer laid out, I would think they would want to capitalize on their investment.
  • Mon, Jun 16 2008 3:30 PM In reply to
    • tpiom
    • Posts 4
    • Points 105
    Re: Complaint post
    Some of the employees are working with Avid, and I know it's a great tool. And I've the experience... Though, still dissapointed. But who knows, might be working in the future.
    For now PP works fine. At least the community is working Smile
    Who knows, the founder might be searching around here as a guest Stick out tongue
  • Mon, Jun 16 2008 3:48 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,696
    • Points 161,335
      Moderator: MCA Mac
    Re: Complaint post
    You sound as if you are very new to this whole thing. If you are interested in working it out, we'll be here to help.
  • Mon, Jun 16 2008 4:03 PM In reply to
    Re: Complaint post
    the software should be compatible with the hardware (not the other way around).
    I disagree. The Avid is a system solution. They are very clear on what machines they test and support. This is not some piece of software that will run on any machine.
    Symphony Nitris 3.0 on 2xquad core XW8400/4(??)GB | MC 3.0 on dual core XW8400/3GB | Mojo SDI | Unity Lanshare 4.23 fibre | MC 3.0 on MacBook 2.16/2.5GB... [view my complete system specs]
  • Mon, Jun 16 2008 4:31 PM In reply to
    • Laptopeditor
    • Joined on Tue, Feb 27 2007
    • Montreal, Canada
    • Posts 767
    • Points 9,455
    Re: Complaint post
    Job ter Burg:
     ...This being said, I think Avid software could well benefit from making their software a little more compatible across a wider spread of PC components. I do agree that one must run their Avid editing app on an Avid certified system, but the problem with this is there are too few PC compatible systems which have been qualified to run Avid. This situation is especially true in the PC Laptop end of certified systems.
    Upgraded to Media Composer from Avid Xpress Pro and now at MC 3.0. Also added Avid Studio Toolkit 5.7 running on.....HP Compaq nw 9440 Laptop PC w/2 x... [view my complete system specs]
  • Mon, Jun 16 2008 5:35 PM In reply to
    Re: Complaint post
    AFAIK, all of the certified HP (xw8xxx) systems that Avid approves include RealTek audio cards.  So they do work with Avid software, but I'm sure there are some reasons why a DIY box with a RealTek card has issues and the certified HP doesn't.
    The "not licensed to run this software" "error" is not an error.  You haven't paid to upgrade your dongle to run the software that you've downloaded.
    MacPro dual 2.66GHz 2GB RAM NVIDIA GeForce 7300 GT Storage: 2TB G-Speed eS with controller card 2x500GB Hitachi SATA-II internals various external... [view my complete system specs]
    • vvp
    • Edmonton, Canada
    • Posts 615
    • Points 7,480
    Re: Complaint post
    Avid is very clear about what computers their software will run on reliably.
    If you try it on non-approved gear you may have a less then satisfactory experience.
    Professionals require their gear to run with as few problems as possible.  Avid qualifies very few systems outright as very few are made to the standard they need to be to function correctly and with consistency.  You can't drive a Porche using an engine that was designed for a moped and expect it to work as well as the original Porche engine.  Sorry.  It just doesn't work that way.
    As was stated earlier... spend the lousy 30 dollars for a SoundBlaster card and kiss your realtech problem goodbye.
    MAN!  I am so sick of people who *** and whine about their poor experience with Avid software when they don't run it on qualified gear!  WAKE UP AND READ BEFORE YOU BUY PEOPLE!  I'm not saying don't try it on non-certified gear.  I have had great experiences running the software on both qualified and non-qualified computers.  But what I am saying is that if it doesn't work on non-qualified equipment don't blame Avid for it... its you who is trying to run it on gear they haven't passed for a reason.
    !rant out!
    So my new wife asks me about my "Avid Forever" tattoo... I told her she's an old girlfriend who was always coming up with new things for me to try...
