Latest post Tue, Jul 1 2008 10:27 PM by jasperfdo. 16 replies.
  • Mon, Jun 16 2008 7:07 AM
    • MikeD2
    • Posts 39
    • Points 595
    minimum requirements help
    Hey all,
        I'm trying to see if I meet the minimum requirements for Media Composer (currently using Xpress Pro 5.8) and could use some help. I'm sure these are probably easily answered questions for some. I'm confused and appreciate any and all help. Thanks.
         -Nvidia Quadro FX 560 - I don't know what's higher than this. How do I find out what is a part of the progressive improvement from the Quadro FX? Also, does anyone know what price the quadro fx starts at? If I need to get a new card to upgrade I'd like to spend the least amount. I'm having a hard time finding prices.
        Intel Core 2 Duo 2.33 GHz - I also don't know where this falls in the line of processors. If you have a Pentium 3 or 4 does that automatically mean you're okay?
        Also, it says that only Nvidia video cards are supported. Does that mean other cards may work with media composer and that avid just doesn't offer "support" like technical support, etc. for those other cards? Or does it mean no other cards work with media composer?
    Thanks again.
  • Mon, Jun 16 2008 8:48 AM In reply to
    • Solopost
    • New Jersey
    • Posts 1,055
    • Points 12,030
    Re: minimum requirements help
    "Intel Core 2 Duo 2.33 GHz - I also don't know where this falls in the line of processors. If you have a Pentium 3 or 4 does that automatically mean you're okay?"
     From what I read of system specs the only system with a single processor is the xw8200 on a 3.4 of 3.6Ghz (I believe on that system it is only a Pentium Xeon processor). So the answer is no.. if you have a pentium 3 or 4 you MAY not be okay.
    "Nvidia Quadro FX 560 - I don't know what's higher than this. How do I find out what is a part of the progressive improvement from the Quadro FX? Also, does anyone know what price the quadro fx starts at? If I need to get a new card to upgrade I'd like to spend the least amount. I'm having a hard time finding prices."
    Ever heard of eBay? Or even nVidia? HERE is the page on nVidias website that lists all the Quadro FX boards... from there you can discover the pricing (i.e. eBay or some other selling source).
    "Also, it says that only Nvidia video cards are supported. Does that mean other cards may work with media composer and that avid just doesn't offer "support" like technical support, etc. for those other cards? Or does it mean no other cards work with media composer?"
    As usual it means Avid has tested those boards and states they work and are supported. Anything outside of the 'supported' boards is your guess and at your own risk, as usual.
    XW8200 2x3.2Ghz Xeon nVidia 3450 3Gb Ram Media Composer 3.0 w/Mojo 2Tb storage (mixed SCSI/SATA/1394)---------------Mac Pro 2xQuad-Core Intel 3Ghz 9Gb... [view my complete system specs]
    My Two Cents .02
    Kent Brockman
  • Mon, Jun 16 2008 9:05 AM In reply to
    • camoscato
    • Posts 4,654
    • Points 55,510
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    MikeD2:
    If you tell us what you're running now (processor, gfx card, etc) we can help you figure out what you may need to upgrade.
    good luck,
    Carl
  • Mon, Jun 16 2008 7:32 PM In reply to
    • MikeD2
    • Posts 39
    • Points 595
     I'm using an ATI Radeon 9800 128mb video card - I know it's not the newest but it works fine with xpress pro 5.8. And I'm using a Pentium 4 3.0GHz processor. I didn't find anywhere in the 5.8 documentation that said the video card I'm using isn't supported, but I gues Media Composer is only supported with Nvidia.
  • Mon, Jun 16 2008 8:50 PM In reply to
    • lunalobo75
    • Cuadra
    • Posts 24
    • Points 265
    Check out my specs below. I have a pentium 4 3.06 and MC3 is working fine.
    Salud!
    MC 3.0, XP Professional SP3, P4 3.06 (yeah,P4) MSI 865PE Neo2-FIS2R, 4Gigs Ram, BFG AGP Geforce 7800 GS, 200 gig ATA 133 System drive, SATA 1Tb (Raid 0... [view my complete system specs]
  • Mon, Jun 16 2008 9:28 PM In reply to
    • MikeD2
    • Posts 39
    • Points 595
     do u think an ati video card would work?
  • Mon, Jun 16 2008 9:47 PM In reply to
    • lunalobo75
    • Cuadra
    • Posts 24
    • Points 265
    To be quite honest, I don't know. I do know my 7800gs work great, and one day soon I'll make the transistion to the recommended specs. But I would look into an Nvidia card though...
    Salud!
  • Mon, Jun 16 2008 9:51 PM In reply to
    • jasperfdo
    • Joined on Wed, Oct 11 2006
    • Los Angeles
    • Posts 536
    • Points 6,970
    Don't even try ATI.  Maybe if you are only cutting DV footage for wedding videos and that is all you do the ATI might work....if all the stars are lined up correctly in the sky.
    But seriously, even if you get it to work, the day will come when you are under a deadline with some HDV footage or something you don't normally do, you'll hit a bug with Avid and the ATI drivers, and then everyone on here will tell you "your card isn't supported" and then you'll miss your deadline and lose more money and years off your life than if you just bit the bullet and got an nVidia card now.
    Dell Precision 690, Intel 3.2GHz Dual Core Xeon (5060)4GB RAM, nVidia Quadro FX 3500 / Media Composer v3.0 / Mojo [view my complete system specs]
    kyler boudreau | www.theatereleven.com
    "Sometimes I wonder if men and women really suit each other. Perhaps they should live next door and just visit now and then. " - Katharine Hepburn
  • Mon, Jun 16 2008 10:58 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,034
    • Points 71,965
    jasperfdo:
    ...and then you'll miss your deadline and lose more money and years off your life than if you just bit the bullet and got an nVidia card now.
    Couldn't agree more. Basically with unsupported hardware, you have a 50-50 chance that it will work and even if it does initially, there are no guarantees for the long term. So the question now is, how much is your peace of mind worth?
  • Tue, Jun 17 2008 12:18 AM In reply to
    • MikeD2
    • Posts 39
    • Points 595
    Yep, I think I'm going to look into an nvidia card. I'm still confused on the processor though. I'm not really sure how to tell that I'm above the minimum requirements, with all the different types, etc. Anyone know?
  • Tue, Jun 17 2008 12:31 AM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,034
    • Points 71,965
     Mike:
    Here are the official system requirements for Media Composer Soft, Media Composer Mojo DX, and Media Composer Nitris DX.
    The official announced prices are: Media Composer Soft - $2,495.00   Media Composer Mojo DX - $9,995.00   and  Media Composer Nitris DX - $14,995.00.
  • Tue, Jun 17 2008 1:18 AM In reply to
    • MikeD2
    • Posts 39
    • Points 595
     I'm really not trying to keep hammering on the same subject, I just really don't understand.
    I have a pentium 4 3ghz processor. Does anyone know if this is above the intel core 2 duo 2.33ghz (which is the minimum requirement for media composer 3)? I think I can afford the graphics card upgrade but if my processor's not good enough I'm kinda out of luck for upgrading.
    Again, I'm not trying to try anyone's patience, I just have a hard time when it comes to the details of computer components. Thanks again all.
  • Tue, Jun 17 2008 1:31 AM In reply to
    "Does anyone know if this is above the intel core 2 duo 2.33ghz ..."
    Pentium 4 = approx 2004
    Core 2 Duo = approx 2007
    Here's the history, in reverse order ....
    http://www.intel.com/pressroom/kits/quickrefyr.htm
  • Tue, Jun 17 2008 2:05 AM In reply to
    • Blofelds Cat
    • Australia
    • Posts 28
    • Points 390
    Avid is a little precious when it comes to the various components and minimum requirements required to successfully run their products; essentially the quoted specs are built around two factors; 1) which companies have paid Avid a gratuity in exchange for the blessing of their equipment and/or 2) bullet-proof system specs which reduce, as far as possible, the chances of technical assistance being required by the customer (which makes perfect sense on myriad levels).
    If you are running a high-end business, it is wise to invest in a fully qualified system; to do otherwise is to set yourself up for disaster. I say this with some qualification as I have first-hand experience of high-end Avid systems in the Broadcast environment and the problems which have arisen with every link in the chain.
    If, like me, you have a low-end business, i.e. a sole operator running a single edit workstation, you can adopt a more flexible approach to Avid's recommendations. In my private work, I don't think that any of the systems I've used over the years has ever contained a single component that has Avid's blessing (and if there has been Avid-approved componentry it's purely coincidental).
    I recently installed MC v3 and while it is stable on my current system (see my system specs), I will nevertheless be upgrading with the following components:
    Intel Core 2 Quad processor
    GeForce GV-NX98X512H-B (9800 GTX) graphics card
    4GB Ram
    The cost of my new system will be about a quarter the cost of an Avid certified system, and should, all things being as equal as they have been for the last ten or so years, be more than able to handle anything expected of it.
    One very important word of advice: do NOT use Realtek HD audio as your sound card as Avid simply will not work with Realtek audio.
    cheers.
    Proudly non-Avid qualified - Avid Media Composer 3 - HP Pavilion m7288a - Intel Pentium 4 CPU 3.2GHz - 4GB DDR Ram - Gigabyte GeForce 9600GT... [view my complete system specs]
    www.ohmss-007.com
    home of:
    Far Up! Far Out! Far More! - James Bond, On Her Majesty's Secret Service
    The Bondles - take a trip down Moneypenny Lane to a world in which The Beatles and James Bond collide with moderately humorous result.
  • Tue, Jun 17 2008 5:10 AM In reply to
    • jasperfdo
    • Los Angeles
    • Posts 536
    • Points 6,970
    MikeD2:
    Mike - I'm going to assume that you are not a hardware guy and hence the confusion.  So please don't be offended if I get too basic, but here's the deal:
    Intel has made huge leaps in the technology driving their processors in the last few years.  What does that mean?
    1) that 2.33GHz processor you mentioned is a 'dual core' processor which means it is actually two 2.33GHz processors (or cores) in a single processor 'footprint' meaning a 4.66 processor (for multi-threaded apps which Avid is).
    2) Additionally, a single core in the new 2.33GHz Xeon processors will smoke that Pentium 4 3GHz processor.  Xeons are designed to handle more work than Pentium processors, but in addition to that, the architecture in the new Intel core 2 processors means they can do more in less cycles than the older versions.  For conversation sake, let's say it takes your Pentium 4 10 clock cycles to do a task.  That newer 2.33 processor will do it in 5-6 easy.  And then combine that with an additional core and you have just cut processing time for the same task by like 80%.
    Those are not book accurate comparisons, but the example is very close.  So my answer to you would be you'll probably get Avid to open and be able to do some basic stuff but it will be SLOW. If you are just cutting DV home videos that are not that long it might do it.  But don't even think about touching HDV and getting into long sequences with many FX, etc.
