Latest post Tue, Jul 1 2008 10:44 AM by Wm.Busby. 3 replies.
  • Sun, Jun 15 2008 4:12 PM
    • Kerstin
    • Joined on Sun, Apr 27 2008
    • Posts 4
    • Points 50
    no input signal. again.
    Hi everyone!
    trouble once more..
    I'm using Avid Xpress DV on my PC and I can't get a signal of my Cam with
    Firewire.
    Tried to configure my deck about 10000 times, rebooted everything again and again, installed DVBuffers, switched off my firewall, reinstalled drivers for my firewire-card...
    nothing helped.
    Some days ago, I tried it with another Cam, and it worked (same type) - temporarily. Then it stopped working. Tested the Cam on a Mac (where the same Avid system is running) - and it didn't work either. I thought it's just the camera gone bad - tried it with the new one. It worked. Worked with the mac, with avid, with my windows. But my Avid keeps telling my: no input signal. I'm confused - it worked before, and now I can't get an input signal anymore. Desperate.
    Any help? I'd really appreciate it!!
    Hope u understood everything and sorry for my English!
    Kerstin
  • Mon, Jun 16 2008 11:39 AM In reply to
    • Kerstin
    • Posts 4
    • Points 50
    Re: no input signal. again.
    Sorry, forgot:
    The cam I'm using is a Sony DCR-VX 9000 E, it's 9 years old.
    The Mac (where I tested it before), is a Dual 2.5 GHz Power PC G5, Mac OS X 10.4.10 (or 10.4.11, not sure about that)
    The PC has an AMD Athlon(tm) XP 2500+ 1,84 GHz, 1,50 GB RAM
    The firewirecontroler has the VIA-Chip VT6306
    Avid (on both systems) is Xpress DV 4.8
    Greetings
    Kerstin
  • Mon, Jun 30 2008 2:11 AM In reply to
    • nHunt
    • Joined on Fri, Mar 17 2006
    • Toronto
    • Posts 5
    • Points 55
    I've had the same issues and tried same many things. Same version XDV. Have used different input devices, usually a Sony PD150 camera which is even recognized on list of devices. Sometimes it's recognized, sometimes not. Sometimes one firewire port picks it up. Very puzzling. All I can wonder is if Avid software is not compatible with AMD brand processor somehow which I also have.
    I'm thinking about switching to MAC and Final Cut express.
    AMD Athlon 64 processor 3000 + 1.80 GHz 1.50 GB RAM MSI Radeon TD128 videocard 2 x 120 GB HD BENQ 19 inch monitor Windows XP Pro service pack 2 ... [view my complete system specs]
  • Tue, Jul 1 2008 10:44 AM In reply to
    • Wm.Busby
    • LA, Cali
    • Posts 234
    • Points 2,790
    Kerstin, one of your problems very well could be that your firewire card has a VIA chipset. If I were you, I would start by replacing/installing a FW card that has the Avid certified Texas Instrument chipset.
    Dell Precision 330, 2.6ghz, 1gig ram, 80 gig sys drive, 1TB media, SB Audigy, ADS Pyro, DSR-11, MAudio BX5's, Power Reach Duo KVM, dual Sammies, Win2K... [view my complete system specs]
    Forum etiquette rule #1: FILL OUT SYSTEM SPECS IN PROFILE! :)
