Latest post Mon, Jun 16 2008 12:00 AM by AndrewAction. 17 replies.
  • Fri, Jun 13 2008 6:41 PM
    • funky paul
    • Joined on Tue, Dec 19 2006
    • Cardiff
    • Posts 38
    • Points 575
    Short cut keys - Xpress to Composer
    Hi All,
     I've just upgraded from Xpress Pro to Composer as required now xpress isn't supported. One quick question - are the short-cut keys the same for Xpress and Composer? It would appear not because weird things keep happening. I've got a proper keyboard with all the short cuts colour-coded for xpress, but got a bad feeling this doesn't now correspond to Composer.
    Am I right, or just confused (again!)?
    Paul
    Avid Media Composer. PC with Intel DP35DP s775 iP35 ATX motherboard. Core 2 Extreme QX6800 2.93GHz. 256MB Nvidia Quadro/FX1500 PCIe 1Gb DDR2 [view my complete system specs]
  • Fri, Jun 13 2008 6:42 PM In reply to
    • camoscato
    • Posts 4,683
    • Points 55,805
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: Short cut keys - Xpress to Composer
    Hi Paul,
    No, you're right, there are some differences.  If you open up your Keyboard settings, you'll be able to see the MC layout.
    good luck,
    Carl
  • Fri, Jun 13 2008 7:41 PM In reply to
    • funky paul
    • Cardiff
    • Posts 38
    • Points 575
     Thanks for that Carl. Disappointing - I now have a keyboard which is effectively useless!
    Cheers,
    Paul
  • Fri, Jun 13 2008 7:55 PM In reply to
    • camoscato
    • Posts 4,683
    • Points 55,805
      Moderator: Meridien
    Hi Paul,
    Not really all that useless.  Most of the commands are the same.  I think there are only about 6 or 8 keys that are different.
    good luck,
    Carl
  • Fri, Jun 13 2008 10:42 PM In reply to
    funky paul:
    Not at all. Open the Command Palette and your Keyboard settings and map the buttons to match your existing keyboards labels
  • Fri, Jun 13 2008 10:54 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,141
    • Points 73,290
     Paul: First here is a snapshot of the Newscutter keyboard (which I believe is the same as XPRO) and under that the Media Composer keyboard.  And here are the keyboard shortcuts for Media Composer.
  • Fri, Jun 13 2008 10:58 PM In reply to
    • funky paul
    • Cardiff
    • Posts 38
    • Points 575
     Great! Thanks everyone, really helpful. I was all but ready to put my old keyboard in the bin!
    Much appreciated,
    Paul
  • Fri, Jun 13 2008 10:59 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,141
    • Points 73,290
     You're quite welcome, Paul. We're all here to help.
  • Fri, Jun 13 2008 11:13 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,141
    • Points 73,290
     And you can always order a set of MC replacement keycaps for your existing keyboard.
  • Sat, Jun 14 2008 1:18 AM In reply to
    • tompearson
    • Joined on Thu, Mar 1 2007
    • Wayzata MN
    • Posts 476
    • Points 5,170
     my copy came with mine in
    c\ program files\avid\utilities\xpresskeyboardsettings
    asus mb p5wd2 dualcore 3 gig intel cpu's 4 gig crucial ram nvidia quadro fx 3500 1 tb wd sata 7200 raid 0 seagate 160 gig sata 7200 os drive mojo command... [view my complete system specs]
    Tom Pearson Director Hollywood-sounds.com
  • Sat, Jun 14 2008 1:43 AM In reply to
    • Brickwad
    • Simsbury, CT
    • Posts 390
    • Points 4,695
    When I upped from 'Pro to MC I saved my 'Pro user settings to an external drive, then after installing MC placed them into the MC users folder. The 'Pro keyboard settings were retained and work perfectly. Now all I've got to do is make every keyboard on all my systems consistent, so I don't stare at it like a dufe until it snaps into my head which system I'm on.
    I have 10 Avid systems, DX, Meridian and DNA. 1 MCA 1.8 on 2.5 quad G5 w/ 5 Gigs of Ram, 1 Symphony Nitris DX on eight core mac pro with 4 gig ram, 1 MC... [view my complete system specs]
    Andy
  • Sat, Jun 14 2008 4:07 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,490
    • Points 40,370
    If you've upgraded to MC 3.0 - and you should have - it comes with a keyboard settings file that matches Xpress Pro for people migrating.
  • Sun, Jun 15 2008 3:14 PM In reply to
    • funky paul
    • Cardiff
    • Posts 38
    • Points 575
     Ok, thanks jwrl, how would I go about making this happen in terms of activating this keybpard setting? I've looked around and can't see anything.
    Also, do the 'skip to next edit' and 'skip to previous edit' buttons always switch you to trim mode? It never did that before in Xpress Pro and I'm finding it pretty annoying. Maybe it's a difference with composer, but can't see the benefit myself
    thanks,
    Paul
  • Sun, Jun 15 2008 3:24 PM In reply to
    funky paul:
    Unless you map RW/FF to those keys.... yes.
    MacPro dual 2.66GHz 2GB RAM NVIDIA GeForce 7300 GT Storage: 2TB G-Speed eS with controller card 3x500GB Hitachi SATA-II internals various external... [view my complete system specs]
  • Sun, Jun 15 2008 6:06 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,141
    • Points 73,290
     Confirming Kenton's post. FF and REW will snap to next or previous edits. And in earlier versions, they USED to snap to keyframes when in the effects mode. Check yours for this, for some people (including me) this function has disappeared. Kenton, what about yours?
