Latest post Mon, Jun 16 2008 5:52 PM by slabross. 3 replies.
  • Fri, Jun 13 2008 1:52 PM
    • ocho
    • Joined on Wed, Mar 28 2007
    • Posts 15
    • Points 240
    probleme
    hi evrybody,
    on ds 8.4 i have 3 probleme
    - i can not link video files... we have also 7.4 ds nitris and there no problem... i can work on Sd project and link HD video files... usefull when you have to resize (zoom on the image)
    i don t know why on the latest version it dosen t want to link? when i right click on the file it dosen t propose to link... but if i have a still image like jpeg it works...
    -On a Hd project i try to archive, it dosen t archive the media to tape. remote is ok... it dosen t propose the window with the timecode... only archive the project.
    - when i try to capture , the image is purple... somethings wrong with the aquisition card?
    output tool is working...
    thank you
  • Fri, Jun 13 2008 3:21 PM In reply to
    • ceffoavid
    • Joined on Thu, Jan 17 2008
    • Posts 104
    • Points 1,180
    Re: probleme
    What is the format of the HD video files?  MXF?
    Try another project for archive.
    Video is purple?  I would reseat the hardware. (aquisition card)
    Avid DS Artist and Tech Avid MC and Symphony Editor and Tech Here are some video's I edited with Avid DS Nitris. http://myspacetv.com/index.cfm?fuseaction=vids.individual&videoid=4525133 http://myspacetv.com/index.cfm?fuseaction=vids.individual&videoid=6118459 http://myspacetv.com/index.cfm?fuseaction=vids.individual&videoid=8204314
  • Fri, Jun 13 2008 4:11 PM In reply to
    • ocho
    • Posts 15
    • Points 240
    Re: probleme
    hi, ok for the capure tool
    what do you mean MXF? it HD cam the resolution was DNxHD 185...
    it s working whwn i archive a SD project>>>
    What about linking video files does ds8.4 do not linked video files, only photo?
    thanks a lot
  • Mon, Jun 16 2008 5:52 PM In reply to
    • slabross
    • Montreal
    • Posts 183
    • Points 1,695
    Re: probleme
    Are you trying to Link to QuickTime files?  If yes, that option was indeed removed from the application because the audio sampling is causing a DS error. The safe method is to import QuickTime and DS can then resample the audio to make a legal file.
    And you did click the Video option in the Archive panel?  And you are not trying to archive HD media while in a SD sequence or something that conflicts with your format?
    - when i try to capture , the image is purple... somethings wrong with the aquisition card? Output tool is working...
    It appears so.  Did you contact Avid Support to troubleshoot your hadrware?
    Sylvain Labrosse
    Team Lead for Avid DS
    WW Mission Critical Services
    Global Customer Support & Operations
    Avid Technology Inc.
