Latest post Fri, Jun 13 2008 8:19 AM by camoscato. 3 replies.
  • Thu, Jun 12 2008 4:13 PM
    Still frame while playing problem
     hello forgive me if i am being a bit of an idiot but i have a problem
    when i hit play after importing some new footage in, the audio plays but the video just shows the first frame.
    i can scroll forward using the skip one frame button but then there is no audio (of course)
    if i drag clips i have chopped down into the timeline and hit play the same happens
    Sorry if this is an obvious one but i am used to a mac and FCpro and i just cant get my small brain around this
    any help would be great
    [edited subject as [Problemas subject is not getting you much attention Wink
  • Thu, Jun 12 2008 4:17 PM In reply to
    Re: [problem
    Without system specs, we can only guess.  But, typically, this is due to the video card, it's drivers, or the Display Properties setup.
  • Fri, Jun 13 2008 3:16 AM In reply to
    • joelrmorgan
    • Gresham, Oregon
    • Posts 131
    • Points 1,720
    Re: [problem
    This kind of sounds like a problem I sometimes have, but have found a workaround for.  Do you ever get the famous flamethrower error when this happens?  Sometimes I do, but not always.  Here's what I've figured out...
    If I have "Output to DV Device" selected but there isn't a place for the DV signal to go (such as if the tapedeck connected via firewire was turned off), the same thing happens to me.
    Sometimes it seems to me that this is related to trying to play a timeline with non-rendered clips out to a DV device, which won't play to an external DV Device anyway.  But thinking about it now, perhaps that's just coincidence.
    If there's no place for a signal to go, playing the source monitor gives me the same thing - Audio and the only the first frame of video, usually followed shortly by a flamethrower error.
    By the way, I do not have Mojo.  (But I have moxie and spunk!)
    - Dell Precision 670 - Dual Xeon processors (2.8) - 2 gigs of Ram - nVidia 1400 (driver 7.7.1.8) - Creative SB X-Fi sound card - 120 Gig boot hard... [view my complete system specs]
  • Fri, Jun 13 2008 8:19 AM In reply to
    • camoscato
    • Posts 4,683
    • Points 55,805
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: [problem
    Like Randy said, tell us your system specifications, and we'll try to help you figure this out.
    good luck,
    Carl
