Latest post Fri, Jun 13 2008 2:59 PM by funckdren. 5 replies.
Page 1 of 1 (6 items)
  • Thu, Jun 12 2008 12:08 PM
    • pierreh
    • Paris, London
    • Posts 598
    • Points 7,245
    1:1 or 2:1, that is the question...
    Hi everyone,
    I'm starting an uprez today, and for the first time we'll do it in-house with MC and Mojo SDi. Now, to be honest I haven't done that for years, and I was wondering if I should go for 2:1 or 1:1 compression. I talked to one of the main Avid house yesterday, and they told me that I shouldn't bother about 1:1 and go for 2:1 instead which will be easier on the harddrives and as good as 1:1.
    All my sources are archives, some dating 30 years - though most are between 1 and 8 years old. It's mainly news footage, probably shot on Beta or SP at the time, and often on NTSC converted to PAL. The film won't be effect heavy (a couple of dissolves here and there), but the quality of the original footage will require some cleaning (drop-outs, damage tape, etc). I don't know yet if we'll try to clean as much as possible on the MC (well MC's not exactly a finishing tool) or if we'll take a digibeta playout and clean it at the place where the color-correction will happen.
    With all the info I can provide, thanks guys for your feedback and advice!
    Pierre
    At home: MacBookPro 2.5Ghz, 4Gig Mem, Mojo At work: MacPro 2.6Ghz, 3.5Gig mem, Mojo SDi [view my complete system specs]
  • Thu, Jun 12 2008 2:17 PM In reply to
    • funckdren
    • Los Angeles, CA
    • Posts 112
    • Points 1,465
    Re: 1:1 or 2:1, that is the question...
    I'd go 2:1. Here's a good thread for you...
    http://community.avid.com/forums/p/52656/295002.aspx#295002
    Mac Pro 8-Core 2.8, Media Composer 3.0.1, Mac OS 10.4.11, Quicktime 7.4.5, 4 GB RAM, Analog Mojo, Internal 3TB RAID [view my complete system specs]
  • Thu, Jun 12 2008 11:06 PM In reply to
    • pierreh
    • Paris, London
    • Posts 598
    • Points 7,245
    Thanks, great read. For some reason, I didn't find it on a search. I'll go for 2:1 for most of the shots, and grab the one that will be tweaked at 1:1.
  • Thu, Jun 12 2008 11:11 PM In reply to
    • TrevorA
    • Posts 48
    • Points 580
    You might find that 1:1 results in a snappier sequence, especially as you add effects. I understand that this is because the CPU doesn't have to decode for 1:1 material. Obviously your storage requirements will double.
    YMMV
  • Fri, Jun 13 2008 8:11 AM In reply to
    • pierreh
    • Paris, London
    • Posts 598
    • Points 7,245
    Good point. I'll get the shot that will have some effects at 1:1. I've raided two 500gig inside the MacPro, QuickBench gives me 120Mo/s, that should be enough for 1:1, no?
  • Fri, Jun 13 2008 2:59 PM In reply to
    • funckdren
    • Los Angeles, CA
    • Posts 112
    • Points 1,465
    Should be fine. 10-bit RGB Uncompressed PAL requires about 45 MB/sec not including audio.
