Latest post Thu, Dec 11 2008 1:48 AM by nogable. 27 replies.
Page 2 of 2 (28 items) < Previous 1 2
  • Thu, Oct 16 2008 7:11 AM In reply to
    • jknikman
    • Leiderdorp - NL
    • Posts 3,461
    • Points 39,230
    Re: MC 3.0 Install problem
     Realtek is known to give or give not proms. can you try to install on another machine without realtek?
    Dell Precision 670, Xeon 3Ghz 3GB Memory 1 x 250 systemdisk, Gb 2x500 Gb datadisks, 2x 1Tb datadisks, Soundblaster Audigy, Quadro FX 1400, MC 3.5.1, Mojo... [view my complete system specs]
  • Thu, Oct 16 2008 6:10 PM In reply to
    • nogable
    • Los Angeles, CA
    • Posts 55
    • Points 640
    I tried install on another computer, with Sigma sound, with the same results. This would point to a corrupt file, but I've downloaded the file 3 times.
    Sager NP5760-C, T7600 Dual Core Proc 2.33GHz, 2GB RAM, NVIDIA Quadro FX 2500M (Driver 156.55), Express card slot [view my complete system specs]
    Many thanks,
    S Behrens
  • Thu, Oct 16 2008 6:12 PM In reply to
    Avid prefers SoundBlaster ....
    Media Composer 3.5.9/4.0.2 w/Mojo (analog), HP xw8400, 1xQC 3.0GHz, 8GB RAM, FX 3700, 1TB Boot, 1 x 1TB & 1 x 500GB internal SATA media drives, 3-Ware... [view my complete system specs]
    Our new websites are up!
    http://www.lifenetintl.org/
    http://www.capitalchristian.net/
  • Thu, Oct 16 2008 6:40 PM In reply to
    • jknikman
    • Leiderdorp - NL
    • Posts 3,461
    • Points 39,230
     Yep... Avid doesnot have problems with Soundblaster. That is because the application needs two way communication wirth the soundcard because of syncing audio and video. A lot of cards don't have that. A cheap soundblaster  audigy does.
  • Thu, Oct 16 2008 8:03 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 1,389
    • Points 15,920
    Caber, if You're on Win XP SP2 see if installing this will help.
    MC 3.5/Mojo, Vista 64 biz, Gigabyte GA-EP45T-EXTREME, Intel Q9450, 8 GB ram, Pyro 64, Quadro FX 1700, 2 x 1TB drives (raid 0) for mediafiles + G4 MacBook... [view my complete system specs]
    peace luca
  • Thu, Oct 23 2008 6:26 AM In reply to
    • nogable
    • Los Angeles, CA
    • Posts 55
    • Points 640
    I tried pluging in a USB Soundblaster Extigy with no success. The message states that the installer can not find Avid's own install files. Would the sound card have anything to do with that? Any other ideas?
    Many thanks,
    S Behrens
  • Thu, Oct 23 2008 7:59 AM In reply to
    • jknikman
    • Leiderdorp - NL
    • Posts 3,461
    • Points 39,230
     did you disable the internal card?
  • Tue, Oct 28 2008 6:51 AM In reply to
    • nogable
    • Los Angeles, CA
    • Posts 55
    • Points 640
    Yup. No joy. I've never had a problem installing Avid software. Why would this show up now?
    Many thanks,
    S Behrens
  • Tue, Oct 28 2008 6:58 AM In reply to
    • jknikman
    • Leiderdorp - NL
    • Posts 3,461
    • Points 39,230
     I think it is related to this:
    http://community.avid.com/forums/t/61838.aspx
    Let's wait what engineering has to say
  • Thu, Oct 30 2008 1:33 AM In reply to
    • nogable
    • Los Angeles, CA
    • Posts 55
    • Points 640
    Just tro keep the post up to date, I checked http://community.avid.com/forums/t/61838.aspx and realized I had a later version of QT installed. I installed 7.4.5, but it did not correct the problem. Is this automatically reviewed by engineering or is there something I should do?
    Many thanks,
    S Behrens
  • Thu, Oct 30 2008 3:34 AM In reply to
    • tvkenny
    • Fort Worth, TX
    • Posts 2
    • Points 20
     I thought I would repost the solution that worked for me, just in case some missed it.
    Oct. 5, 2008
    Media Composer 3.0 installation error.  "DigiAudio" Drivers missing.
     I'm having exactly the same problem.   Re-Downloading MC 3.0 doesn't solve this problem and yes, I removed the registry keys and all Avid folders.
     I was able to install MC 3.0 successfully by executing the Avid Media Composer.msi file in the AvidMediaComposer_3.0\Installers\AvidMediaComposer\Disk1\   folder.
    KC
  • Thu, Oct 30 2008 7:26 AM In reply to
    • jknikman
    • Leiderdorp - NL
    • Posts 3,461
    • Points 39,230
     No you don't have to do anything.
  • Thu, Dec 11 2008 1:48 AM In reply to
    • nogable
    • Los Angeles, CA
    • Posts 55
    • Points 640
    I just wanted to update this string.
    3.1 installed with no problem.
    Many thanks,
    S Behrens
