Latest post Tue, Jun 17 2008 2:51 PM by boltown. 6 replies.
Page 1 of 1 (7 items)
  • Wed, Jun 11 2008 10:20 PM
    Advice for broadcast animations
    Hi guys
    I'm going to get some animations done with Flash and I will import them into the Avid to check them and lay the soundtrack. This animations will be broadcasted (in the UK, so they are PAL). As far as I know they are going to give me uncompressed QTs. I've never done a job like that, so I want to make sure that I avoid pitfalls.Here are my questions:
    1-Is that the best format to get the animations?
    2-Which codec should I use? RGB or IRE?
    3-The animations are obviously progressive but should I re-render them as interlaced to avoid jerking movement?
    4-What's the best way to make sure that the colours are broadcast safe?
    Please let me know if there are more issues I should be aware of.
    Alberto Corredor
    Avid Xpress Pro 4.6.7 with Mojo Dell Precision 650 Operating System(s) Windows System : Microsoft Windows XP/2002 Professional (Win32 x86) 5.01.2600... [view my complete system specs]
  • Thu, Jun 12 2008 2:35 AM In reply to
    • tawlif
    • Alexandria, VA
    • Posts 97
    • Points 1,095
    Re: Advice for broadcast animations
    to my knowledge, yes.
    my guess, they where done on RGB,
    so RGB should be used (to avoid changing color space)
    I would not.
    you can always check the wave form and the vectorscope,
    but I would trust the animator and avoid playing with his colors.
    good luck.
    MacBookPro/MC2.8... [view my complete system specs]
    It is an amazingly simple devise, an "idiot" can operate it, and indeed, many do. (Alfred Hitchcock)
  • Thu, Jun 12 2008 11:40 PM In reply to
    Thanks Tawlif. Seems like broadcast specifications are not that daunting after all. Normanlly if I add an animation to my edits I add the broadcast filter in After Effects as routine. Should I do that with the quicktimes, or can I just use the color effect in Avid?
    Cheers
    Alberto
  • Fri, Jun 13 2008 3:56 AM In reply to
    • tawlif
    • Alexandria, VA
    • Posts 97
    • Points 1,095
    bertocorredor:
    yes they are, there are norms and standards we have to follow.
    i am sorry, i am not sure if i understood your question,
    Avid does have 3 levels of quality for rendering an effect, if that's what you meant.
  • Fri, Jun 13 2008 4:05 AM In reply to
    • Brickwad
    • Simsbury, CT
    • Posts 390
    • Points 4,695
    bertocorredor:
    Just adding the color effect to a clip or to a filler layer at the top of the timeline will bring your luminance levels into compliance - 16 to 235. I do this as a matter of routine, just in case I inadvertantly skipped over something. To my knowledge, it doesn't do anything to saturation automatically, so you would have to manually adjust anything that needs tweaking. Use a scope. It's the only way to know for sure.
    Good luck.
    I have 10 Avid systems, DX, Meridian and DNA. 1 MCA 1.8 on 2.5 quad G5 w/ 5 Gigs of Ram, 1 Symphony Nitris DX on eight core mac pro with 4 gig ram, 1 MC... [view my complete system specs]
    Andy
  • Tue, Jun 17 2008 2:04 AM In reply to
    Right guys. I've got now some animations on quicktime uncompressed done as 1024x576. They look beatiful on Quicktime Player. I'm trying to import them in a D1/DV 16:9 Widescreen project. I've tryied different codecs and settings, but the colors don't look very good to me (a bit washed up) and there is some kind of color banding also going on. We are using an Avid Xpress Pro 5.8.0 (on MAC).
    Any suggestions?
    Alberto
  • Tue, Jun 17 2008 2:51 PM In reply to
    • boltown
    • buenos aires
    • Posts 212
    • Points 2,565
    Import the Quicktimes in 1:1 resolution (need mojo on XpressPro) and as RGB color. That should fix banding contrast problems
    Intel 755xbx2 mobo Code 2 duo 2.2GHz 2GB RAM Quadro 550 Grapgic board Pyro DV Firewire board [view my complete system specs]
    www.wancamp.com.ar www.proeditor.org
