Latest post Fri, Jun 20 2008 1:32 PM by TCediting. 22 replies.
Page 2 of 2 (23 items) < Previous 1 2
  • Mon, Jun 16 2008 8:27 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,243
    • Points 168,005
      Moderator: MCA Mac
    Re: New Media Composer 3.0 now available...
    Uh...Robert, I don't know who told you that but, as long as I've been supporting Avids, the dongles have always been backwards compatible and have been supported as such.
    I've been running 2.8 under a 3.0 dongle most of the way through beta and it works fine. Most of my systems have mixed version of the software and, as long as the dongle is up to date, they all run really well.
    So, while you can't use the 3.0 updater to blast your dongle for 2.8, as long as the dongle is running 3.0, 2.8 should run and be supported just fine.
  • Mon, Jun 16 2008 8:30 PM In reply to
    • Avid Technology Inc.
    • Posts 703
    • Points 9,575
      Avid Employee
    The only thing here is we never tested MC v2.8 with a zapped v3.0 dongle and have no idea how it will perform.
    marianna_montague@avid.com
    813-493-6800
    AOL IM avidmarianna
  • Mon, Jun 16 2008 8:51 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,243
    • Points 168,005
      Moderator: MCA Mac
    Things may have changed but policy was always that dongles were backwards compatible. As long as the software launches, then the dongle should be good to go.
  • Mon, Jun 16 2008 8:56 PM In reply to
    • Posts 703
    • Points 9,575
      Avid Employee
    BUT.... wht the issues of compatibility with Studio and MC - I woudln't go there.    Xpro upgrade to MC 2.8 and stay there or go to MC 3.0 and put your Protools on a different system.
    813-493-6800
    AOL IM avidmarianna
  • Mon, Jun 16 2008 11:20 PM In reply to
    • Andiamo
    • Joined on Sun, Nov 6 2005
    • Posts 11
    • Points 155
     Just had a quick look at the Readme for 2.8 which also says that Protools LE should be placed on a different physical system.
    However, Avid's own Q and A doc on 2.8 says that it will function with the Digi 002 and Pro Tools LE 7.3.1 and that all other component parts will work.  See
    http://www.avid.com/promos/mcsavings/MCSavingFAQ.pdf
    So, if MC3.0 is a different animal to 2.8 I think it would be helpful if Studio Complete Users were given some clarity on how to achieve the seamless results of video production that was the core concept of Complete and (despite some hiccups along the way) is a very worthy one.  (Let us not forget the Mojo either).
    Perhaps Marianna, you could assist in moving such an idea forward?
  • Mon, Jun 16 2008 11:44 PM In reply to
    • Adman
    • Atlanta Georgia, USA
    • Posts 3,817
    • Points 42,365
    • Moderator: Avid Free DV
      Moderator: Avid Xpress DV PC
      Moderator: Avid Xpress Studio
    Interesting... I was about to post again but was distracted... I was going to comment on the fact that there is no guarantee that MC 2.8 will work with Pro Tools LE either... although we have had it working fine with a previous version of MC here -- sans Mojo.
    I have previously made Avid aware of the discrepancy with which you are referring... and I have reminded them again, fwiw.
    But I still say that the best course is to follow Marianna's direction and my earlier post... either do a dual boot (not something I am personally fond of) or put it on a separate system.
    Trust me... I share the frustration of these programs not playing together. It has been an issue that has been around for years and years with Pro and MC... although many, including me, have gotten them to work together just fine. I long for the day that this issue is resolved for good, both in real life and in the "read me" documentation. Hmm
    Dell Precision 650, 3.06 Ghz, 2 SCSI drives, 600 GB LaCie D2, 1.5 Mb Ram, Nvidia FX500 Suite 1. Avid Media Composer v3.0, Avid Studio Toolkit v 5.7... [view my complete system specs]
  • Tue, Jun 17 2008 9:13 AM In reply to
    • Andiamo
    • Posts 11
    • Points 155
     Not wishing to prolong this thread indefinitely, but could you give a few lines on the implications for the hardware side of things ie the Digi 002 and Mojo DNA if one is to use MC3 or 2.8?  For example where do they get connected when running two systems?  Are there any glitches when setting up or running them?
  • Fri, Jun 20 2008 1:32 PM In reply to
    • TCediting
    • Joined on Wed, Jan 18 2006
    • Colchester, CT USA
    • Posts 29
    • Points 375
    Another issue  I have found is that although my 002 works fine with MC2.8 I cannot launch MC without the 002 being turned on.  With XPro I had the option to run with it off.  MC closes during audio initializing if the 002 is not on.  I am concerned that if my 002 dies, something that has happened in the past, that I will be dead in the water and unable to run MC.  Is there a way to run MC without the 002?
    MC 2.8.1; Studio Complete 5.7; analogue Mojo; Digi 002; XP Pro; Dual Xeon 3.2GHZ HT/800 FSB/550W; PS/7525 Chipset/8 port SATA; 2GB DDR RAM; System Drive... [view my complete system specs]
    MC 2.8; Studio Complete 5.7; Mojo; Digi 002; XP Pro; Dual Xeon 3.2GHZ HT/800 FSB/550W; PS/7525 Chipset/8 port SATA; 2GB DDR RAM; System Drive 200GB ATA100 7200 RPM 8MB Cache; spare drive 200GB ATA100 7200 RPM 8MB Cache; Serial ATA drives (2) 200GB SATA 7200 RPM 8MB Cache;(2) External SCSI 146GB drives; Quadro FX1400 PCI-e128MB dual monitor DVI; (2) Samsung 711T 17" LCD w/DVI-I; Sony DRU710A DL DVD-R/-RW/+R/+RW; Sony DSR-25; Sony PDW-U1 Optical Drive.
