Latest post Fri, Jun 20 2008 1:32 PM by TCediting. 22 replies.
Page 1 of 2 (23 items) 1 2 Next >
  • Tue, Jun 10 2008 6:40 PM
    • Adman
    • Atlanta Georgia, USA
    • Posts 3,882
    • Points 43,060
    • Moderator: Avid Free DV
      Moderator: Avid Xpress DV PC
      Moderator: Avid Xpress Studio
    New Media Composer 3.0 now available...
    Studio owners can upgrade via your Xpress Pro license either via download or DVD format at the following links:
    Download only -- $395:
    DVD shipment -- $495
    Dell Precision 650, 3.06 Ghz, 2 SCSI drives, 600 GB LaCie D2, 3 GB Ram, Nvidia FX500 Suite 1. Avid Media Composer v3.0, Avid Studio Toolkit v 5.7, Pro... [view my complete system specs]
  • Tue, Jun 10 2008 8:54 PM In reply to
    • Adman
    • Posts 3,882
    • Points 43,060
    Re: New Media Composer 3.0 now available...
    Attn: Studio owners:
    According to the Media Composer 3.0 readme:
    "Pro Tools LE has been qualified for interoperability with the editing application but cannot coexist on the same system as the editing application."
    Fwiw... I have read at least two articles where the new CEO has made it clear that compatibility among the editor and Pro Tools is a high priority. Hopefully, the driver issues will be fixed in an upcoming release.
  • Wed, Jun 11 2008 10:37 AM In reply to
    • JVR
    • Joined on Thu, Jul 13 2006
    • Bulli , Australia
    • Posts 1,226
    • Points 13,680
    Could you please provide links to verify that this is no not speculation!
    MC 3.0 AXP 5.8.3 QTime 7.3 win xp pro service pak 2 Core 2 Duo Quad core 2.4 clocked to 3.1 4 gig ram 667mhz pci x nvidia 512mb geforce 8600 162... [view my complete system specs]
  • Wed, Jun 11 2008 1:45 PM In reply to
    • Adman
    • Posts 3,882
    • Points 43,060
    Huh? I provided links above... speculation is against the forum guidelines.
    If you are referring to Pro Tools compatibillity... I am not speculating... just hoping. ;)
  • Thu, Jun 12 2008 12:52 AM In reply to
    • JVR
    • Bulli , Australia
    • Posts 1,226
    • Points 13,680
      Touchy Stick out tongue
  • Thu, Jun 12 2008 1:24 AM In reply to
    • Adman
    • Posts 3,882
    • Points 43,060
     Hmm
  • Fri, Jun 13 2008 1:07 PM In reply to
    • Andiamo
    • Joined on Sun, Nov 6 2005
    • Posts 11
    • Points 155
     Hi Adman
    Not being very bright here, but does that mean as a Studio user I should wait until the Pro Tools LE problem is fixed before I get Composer 3 or is there a workaround.  When it says it shouldn't be on the same system does that mean the same computer?  I was about to buy Composer 2.8 which apparently is fully functional with Studio Complete.
    What's your view?
    Andiamo
  • Fri, Jun 13 2008 4:20 PM In reply to
    • dpreston
    • Joined on Fri, Jun 13 2008
    • Posts 1
    • Points 5
     Yes, that does mean that Pro Tools LE and the 002 should not be on the same computer. The two computers can be networked together and share files. The one thing to remember, if they do get it to be on the same system, 002 cannot work with MC 3.0, because of the upgrade path for MC 3.0 does not include the new Digi003. So, if they do fix the system sharing issue, you can use ProTools and the 002 separately from MC 3.0.
  • Fri, Jun 13 2008 4:48 PM In reply to
    • Adman
    • Posts 3,882
    • Points 43,060
    It is a driver issue. Media Composer actually does work with the 002... I have it working fine on my end. But, you cannot have Pro Tools LE installed on the same computer as Media Composer because the drivers are apparently not compatible.
    In the past, the readme's have said this, but in reality many have gotten them to work (including me)... but, at least for me... not this time unfortunately.
    If you need both you'll need to buy another computer for Pro Tools unfortunately. All the other components of Studio are compatible though and always have been -- since Studio is the same as Studio Toolkit (sans Pro Tools) which has been available for Media Composer all along...
  • Sat, Jun 14 2008 7:40 AM In reply to
    • JVR
    • Bulli , Australia
    • Posts 1,226
    • Points 13,680
    What about a dual boot system?
  • Sat, Jun 14 2008 11:33 PM In reply to
    • Andiamo
    • Posts 11
    • Points 155
     As ever Adman you are a fount of knowledge.
    Can you go back one step to MC 2.8.  Did this work with Studio Complete without a hitch?
    Will Avid still sell it ?
    What would we be missing (apart from frustration)?
    Thanx
  • Mon, Jun 16 2008 7:45 PM In reply to
    • Adman
    • Posts 3,882
    • Points 43,060
    The upgrade is for the current version 3.0. The only way to get 2.8, afain, is to try calling a vendor such as VideoGuys and ask them if they have MC 2.8 versions available for upgrading... (maybe they still have some in stock, I have no idea.).
  • Mon, Jun 16 2008 7:48 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,752
    • Points 174,300
    Actually, if you upgrade to 3.0, you are entitled to download any of the older releases from the download center.
  • Mon, Jun 16 2008 8:03 PM In reply to
    • Adman
    • Posts 3,882
    • Points 43,060
    Thanks Blkdog.. I wasn't sure about the dongle considerations...
  • Mon, Jun 16 2008 8:21 PM In reply to
    • Adman
    • Posts 3,882
    • Points 43,060
    Ok.. here is the official scoop according to Avid (Marianna)...
    The only real viable option here is to find a retail box upgrade to MC 2.8. This is because Avid doesn't support dongle updaters for past versions. So, if you go with 3.0 (via required dongle updater)-- running 2.8 would not be officially qualified or supported by Avid.
    The other issue is that there is a limited time period for getting the 3.0 upgrade free (from 2.8 purchase or upgrade after 3/17) -- and this version (as I noted) requires a dongle updater which is not reverse compatible in terms of licensing and support.
    So... the best option is just to go ahead with 3.0 and do a dual boot for Pro Tools and/or put Pro Tools on another computer on your network...
    I hope this is clear.
