Latest post Tue, Jul 15 2008 11:43 PM by AndrewAction. 24 replies.
Page 2 of 2 (25 items) < Previous 1 2
  • Wed, Jun 11 2008 7:00 PM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,607
    • Points 78,265
    Re: Huge Problems with MC v3 -- How to Roll Back?
    Hey Don, as far as i know you do not have to uninstall the 3rd party plugins. Do make sure you uninstall the Avid stuff like the DIO manager etc.. For me it went (besides the graph card) flawless on multiple systems without altering registery or anything else "abnormal" ...
    Menno
    Test-Intel Core2Duo 6800,GTS8800 Nvidia (soft modded into Quadro FX4600),Soundblaster Live 5.1, 21" Samsung display [view my complete system specs]
    Dutch AV forum
  • Wed, Jun 11 2008 9:29 PM In reply to
    • rferguson
    • Joined on Wed, Jun 11 2008
    • Posts 9
    • Points 125
    DSI.dll is installed with the Digidesign_Audio_Drivers_Setup.exe, which installs both drivers for digi devices (if you have any) and the engine necessary for Audio Suite.  It should be located on your CD: Right Click the CD->Explore->Installers->DIGIAUDIOInstaller->Digidesign_Audio_Drivers_Setup.exe.
    1) Run: C:/Program Files/Digidesign/Drivers/digidriver.exe
        and press "uninstall" to get rid of any old drivers on your system
    2) Reboot
    3) Install the new drivers with Digidesign_Audio_Drivers_Setup.exe on the CD
    4) Reboot
    Should be set!  If you are having problems then just manually delete any old DSI.dll file you have and run the installer.
    Best Regards,
    Rob Ferguson
    Audio Software Engineer
    Avid Technology, Tewksbury
  • Thu, Jun 12 2008 2:07 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,311
    • Points 38,030
    DonR:
    I suppose the uninstall also applies to the various plug-ins like Boris and Sapphire.
    Just confirming Menno's post, Don.  I left all third party software in situ and removed absolutely everything Avid, incuding relics of an earlier Xpress Pro install that I thought had already been fully removed.
    My subsequent install just happened.  It was an absolute anticlimax.  No drama waiting to see what fell over, nothing.  It just worked.
    MC 3.0 - Gigabyte GA-X38-DQ6 mobo - Intel core 2 Extreme Q6850 3 GHz - nVidia Quadro 1700 - 4 Gbyte mem - Internal 4 Tb SATA II 4-way RAID 5 array - Pyro... [view my complete system specs]
  • Thu, Jun 12 2008 5:32 AM In reply to
    • wmcole
    • Posts 473
    • Points 6,180
    Check http://www.dll-files-download.com/D/2008-01-13/3183.html
    to download the missing file.
    conleec:
    Okay, so I reinstalled 2.8.3 and this time it got closer to launching. I actually thought it was going to work. Then, at the last minute, I got this error:
    Man. I'm gonna kill myself.
    Chris
    wmc -----
  • Thu, Jun 12 2008 3:29 PM In reply to
    • rferguson
    • Posts 9
    • Points 125
    If you download the wrong version of DSI you're going to be in for a world of hurt.  I would try the digi audio installer I mentioned..
  • Thu, Jun 12 2008 4:12 PM In reply to
    • Baklap
    • Posts 6,607
    • Points 78,265
    rferguson:
    agreed Smile
    Menno
    Dutch AV forum
  • Thu, Jun 12 2008 5:31 PM In reply to
    rferguson:
    Great to have an Avid Audio Software Engineer posting here. Thanks for the info and welcome to the forums.
  • Mon, Jun 16 2008 3:29 PM In reply to
    • conleec
    • Los Angeles
    • Posts 515
    • Points 6,780
    Well for anybody who's keeping tabs, I reinstalled MC3 over the weekend and all went swimmingly. During the brief amount of testing that I was able to do, it definitely feels snappier and much quicker to render. Not sure what caused the horrible crash the last time around, but all is well now.
    For anybody considering doing an upgrade, I'd still recommend using something to back up your boot partition beforehand, just in case. It's the first time I've ever had difficulties upgrading an Avid version.
    Chris
    xw8200, Dual 3.4Ghz Xeons, 4Gb RAM, vVidia FX1300, Adrenaline HD, MC 3.0, QT 7.4.5 [view my complete system specs]
  • Tue, Jul 15 2008 11:36 PM In reply to
    • conleec
    • Los Angeles
    • Posts 515
    • Points 6,780
    Hey Guys,
    So I've been running V3 absolutely without issue for a couple weeks now. However, today I left the machine rendering out reels for the audio house when I went to lunch and when I returned I had crashed with an "access violation" error.
    I had to force-quit the application and when I tried to relaunch it I get the following error and the software crashes back out to the desktop.
    I tried re-installing the software but I continue to get the same error message. This is the same error I received after installing the software the first time several weeks ago as well.
    Has anybody else seen this, and how do I go about resolving this (seemingly) recurring problem?
    Thanks in advance.
    Chris Conlee
  • Tue, Jul 15 2008 11:43 PM In reply to
    I would look to eliminate anything Avid checks with from the old install (ie files that are not replace when reinstalling) at startup time
    First guess would be to move all the user and site settings from there usual places to a backup somewhere. Then try again
    Maybe temporarily rename all your media file folders.
    Good luck
    PS I would also do a manual uninstall of the Avid DIO if I was reinstalling Avid again
