Latest post Tue, Jun 24 2008 4:45 AM by s1eve. 24 replies.
Page 1 of 2 (25 items) 1 2 Next >
  • Mon, Jun 9 2008 11:19 PM
    • billhsp
    • Joined on Fri, Nov 10 2006
    • Midwest
    • Posts 23
    • Points 345
    MCA 3.0 Problem - "Versioner.avd" Doesn't Update Dongle for 3.0
    Hello all,
    Just upgraded to MCA 3.0.  Went to update my dongle with the "Versioner.avd" downloaded from the Download Center and Dongle Manager tells me this in Step 2 of the update, "No dongle compatible with this update file found."  2.7 is the current version of the dongle.  Contacted Avid tech support, and they've confirmed others have had this problem as well.
    So is anyone else having this problem?  Does anyone have a solution?
    Thank you,
    Bill
    Note: just upgraded my hardware in preparation for rolling out 3.0.  Pay no attention to my current hardware specs. Will update shortly.
    HP XW8000 MCA 2.7 PC XP SP2 3G Ram 3G Dual Xeon INVIDIA Quadro4 980XGL [view my complete system specs]
  • Tue, Jun 10 2008 1:44 AM In reply to
    • Avid Technology Inc.
    • Posts 773
    • Points 10,360
      Avid Employee
    Re: MCA 3.0 Problem - "Versioner.avd" Doesn't Update Dongle for 3.0
     Bill,
    I assume you have a valid Avid Assurance contract right?
    marianna_montague@avid.com
    813-493-6800
    AOL IM avidmarianna
  • Tue, Jun 10 2008 4:25 AM In reply to
    • billhsp
    • Midwest
    • Posts 23
    • Points 345
    Thanks for the response Marianna.
    Actually, I don't presently have assurance.  However, I had purchased the 2.8 upgrade from my reseller for $995 (moving up from 2.7) utilmately intended to be the path to 3.0.  I have spoken with him and he assures me that I am entitled to a free upgrade to 3.0 (as intended),  He has checked with his AVID rep and he agrees.
    I am presently awaiting word from tech support as they indicated they had others with similar issues.
    Any ideas?
    Thanks again.
    Bill
  • Tue, Jun 10 2008 5:41 AM In reply to
    • jjytan
    • Joined on Wed, Oct 31 2007
    • Posts 7
    • Points 95
    Hi i had the same problem, upgraded my xpress pro dongle to Media composer. i called tech support and they emailed me a new versioner.avd, it worked. John
  • Tue, Jun 10 2008 12:28 PM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,458
    • Points 39,980
    The download from the update site seems to work now.  I've just done it, and it just worked.
  • Tue, Jun 10 2008 5:07 PM In reply to
    • Isaquit0
    • Joined on Mon, Jan 9 2006
    • Posts 41
    • Points 445
    jwrl, Right on. The correct versioner is indeed available. Upgraded the dongle a few moments ago and can now use MCA 3.0. Thanks for the heads up. -Isaquit0-
    DIY Avid Workstation: Dual Intel Xeon @ 2.5 GHz (Harpertown), Tyan Tempest i5400 (s5396) Motherboard, 4 GB FB-DIMM @ 667 MHz (2 x's 2 GB), nVidia Quadro... [view my complete system specs]
  • Thu, Jun 12 2008 8:04 PM In reply to
    • Isaquit0
    • Posts 41
    • Points 445
    Hello again,
    Went to install MCA 3.0 on another workstation.  Had to re-download "Versioner.avd" from the Download Center and this one doesn't work (again).  Noticed this Versioner is dated 06/12/08.  Can someone send me their Versioner.avd from 06/10 or 06/11 so I can proceed?  Or can you help me out that way Marianna?
    Thank you,
    Isaquit0
  • Fri, Jun 13 2008 4:33 PM In reply to
    • cdumitrescu
    • Joined on Sun, Apr 13 2008
    • Bucharest, RO
    • Posts 13
    • Points 170
    I'm getting the same error when I try to update my dongle to 3.0 in Mac os x leopard. Any clues ?
    MC 3.0.5 software-only / Quad Core MacPro 4GB RAM / OSX 10.5.5 [view my complete system specs]
  • Fri, Jun 13 2008 11:38 PM In reply to
    I have this same problem on OS X Leopard  10.5.3 - PLEASE HELP!  I just bought this and want to start using it this weekend - this process is so stupid and un-user friendly.
  • Sat, Jun 14 2008 11:02 AM In reply to
    • lowresboy
    • Posts 8
    • Points 100
    Hey Folks
    I just upgraded from XPressPro >MC2.8 on osx 10.4.11 > osx10.5.2 then installed MC3.0 and ran the updater file (which showed as a QuickTime icon?) then it says my dongle is invalid!!!
    I bought the MC2.8 upgrade and Avid have said I am completely entitles to the FREE upgrade (surely i wouldn;t have been able to download it from Avid if I wasn't legitimate??!!)
    Anyhow, i can't edit a darn thing til i fix this, so ANY help would be more than appreciated...
    Cheers
    Mike
  • Sat, Jun 14 2008 11:22 AM In reply to
    • cdumitrescu
    • Bucharest, RO
    • Posts 13
    • Points 170
    Just call the Tech Support number. Someone will probably send you a modified versioner.avd file, which WILL work with your dongle. That's how I solved it. The tech support guy was very helpfull.
    This probably happens becouse not all the "upgrade-compatible" Sys IDs are registered in the versioner.avd file.
    Cheers.
  • Sat, Jun 14 2008 11:59 AM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,625
    • Points 78,505
    I take it anyone entitled to the free upgrade (aka purchased after march 17) went through this page?
    http://www.avid.com/register/30_cpr_form.asp
    Menno
    Test-Intel Core2Duo 6800,GTS8800 Nvidia (soft modded into Quadro FX4600),Soundblaster Live 5.1, 21" Samsung display [view my complete system specs]
    Dutch AV forum
  • Sat, Jun 14 2008 6:24 PM In reply to
    • lowresboy
    • Posts 8
    • Points 100
    Right, well that was painless....
    a simple email explaining everything in detail to the wonderful Marianna (moderator for Avid on this forum/thread) and...hey presto....she emailed me back immediately and even followed with a phonecall to ensure the problem was sorted. AND that was at wekend!
    Many thanks, I am now up and running on Media Composer 3.0 on my Macbook Pro....
  • Sat, Jun 14 2008 9:38 PM In reply to
    It must be said: it's not just the software itself that has improved responiveness. Avid are very on top of things in this busy time around the upgrade.
    Symphony Nitris 3.0 on 2xquad core XW8400/4(??)GB | MC 3.0 on dual core XW8400/3GB | Mojo SDI | Unity Lanshare 4.23 fibre | MC 3.0 on MacBook 2.16/2.5GB... [view my complete system specs]
  • Sat, Jun 21 2008 6:16 AM In reply to
    • kgildemast
    • Joined on Sat, Jun 21 2008
    • Posts 2
    • Points 30
     I get the same message "No dongle compatible with the update file found". I purchased a new Avid Media Composer after March 17, 2008. I went to http://www.avid.com/protect and filled in the information. After submitting, it said I am eligible to receive Avid Media Composer 3.0. I downloaded the Versioner file, ran the Dongle Manager and got the message. I followed the information if your Dongle does not update and emailed downloadhelp. I received a reply that the file is updated daily and to try it again. It has been a week now and I have been downloading the file each day and keep getting the same results. Do you need to install 3.0 first before updating the Dongle?
    Kurt
