Latest post Tue, Aug 12 2008 10:31 AM by oh01. 21 replies.
Page 2 of 2 (22 items) < Previous 1 2
  • Wed, Jul 9 2008 4:37 PM In reply to
    • robg
    • Tewksbury, MA
    • Posts 130
    • Points 1,730
      Moderator: Avid Symphony Nitris
    Re: Mojo SDI not working after upgrade to MC 3.0
    We tracked this one down in the lab and found the source of the problem. With the 2x Sunix PCIe, there is a problem with a configuration parameter called the cache line size.
    Another workaround to this issue use a standard PCI 1394 adapter card which does not have the cache line issue.
    I'll keep you posted on a fix...
    - Rob
  • Wed, Jul 9 2008 4:57 PM In reply to
    • genéa
    • Joined on Thu, May 10 2007
    • Salt Lake City, Utah
    • Posts 14
    • Points 160
    Maybe this is too simple an answer for a more complex situation, but I initally had that problem and then had to flash the firmware. It worked after that. We are on a Dell.
    Avid DS/Symphony Nitris (Dual Boot) and Avid Media Composer Adrenaline and Avid Media Composer with SDI Mojo [view my complete system specs]
  • Thu, Jul 31 2008 3:43 PM In reply to
    • CreativeControl
    • Joined on Mon, Dec 10 2007
    • Edmonton, Alberta, Canada
    • Posts 215
    • Points 2,700
     Please do keep us posted.  I ran into this problem.
    http://community.avid.com/forums/p/61520/345240.aspx#345240
    2 MC4.0.3 systems, both Intel Quad Core PC's. 4GB ram each on Asus P5n32-e motherboards. NV7800GT cards with 191.07 drivers. WinXP 32 SP3. 2 Classic... [view my complete system specs]
  • Thu, Jul 31 2008 6:08 PM In reply to
    • robg
    • Tewksbury, MA
    • Posts 130
    • Points 1,730
     OK. We are working on a fix for this. I will post back when the fix is available...
  • Thu, Jul 31 2008 8:25 PM In reply to
    • Random Post
    • Toronto, canada
    • Posts 52
    • Points 695
     oh01,
    I have a Dell 670 (approved Avid config.) and both a Mojo-SDI and a Mojo analogue (older).  I upgraded to MC3 last week and the entire system works with out any problem, on either Mojo.
    Michel
    MC 3.1.2, Mojo SDI and Mojo analogue, approved Dell 670s config.(both of them) 3Gb RAM, DVD, etc... Internal 1Tb esata (striped 2x500Gb), LVD SCSI 160... [view my complete system specs]
  • Fri, Aug 1 2008 12:48 AM In reply to
    • TerryO
    • Joined on Mon, Oct 24 2005
    • Oslo, Norway
    • Posts 111
    • Points 1,310
    oh01:
    Does someone else have problems updating with Mojo SDI?
     I am running Mojo SDI on a HP Pavilion laptop with Vista.
    Works fine here...
    (No older Avids have previously been installed on this machine. Only 3.0)
    Work machines: 5 Avid Media Composer Adrenaline version 3.5 Avid Sympony Nitris v. 3.5 Interplay and Unity Medianet TV 2 Oslo, Norway [view my complete system specs]
  • Tue, Aug 12 2008 10:31 AM In reply to
    • oh01
    • Joined on Mon, Mar 26 2007
    • Germany
    • Posts 18
    • Points 240
    Thanks for the replies.
    I'm still working with the old flamethrower.sys and I had no problems yet.
    Mediacomposer 3.0, Mojo SDI, Dell Precision 390, Intel Core 2 Duo 6600 2,4 GHz, 4GB RAM, nVidia Quadro FX 550, 2x Sunix PCIe Firewire, Windows XP Professional... [view my complete system specs]
