Latest post Sat, Jun 7 2008 5:24 AM by jdrouette. 8 replies.
Page 1 of 1 (9 items)
  • Thu, Jun 5 2008 8:26 AM
    • mix74
    • Joined on Thu, Jun 5 2008
    • Posts 4
    • Points 70
    Media Composer 2.8.1 with Mac Pro in Win XP.
    Hello, I'm italian, forgive my english..
    I have bought a mac pro intel 2.8 with leopard os 10.5.3. MComposer  2.8 obviously  don't work with this OSX. I have created a partition with XP and installed avid.The only software perfectly works, but when I connect MOJO SDI I read the following error:
    a device on the 1394 bus causing problems. please remove it or disable output to dv device. -ftstatus code . ft_linkinitilizationfailed - flamethrowerlinkmanager::openlink - failed to create link obj ect.
    What does it mean? What can I do? HELP ME!
    Thank you....
  • Thu, Jun 5 2008 2:46 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 14,218
    • Points 180,205
    Re: MEDIA COMPOSER 2.8.1 WITH MAC PRO IN WIN XP
    IS that Mojo connected via  the CPU's internal FW bus? IS it on the front or  the back?
    Also, what else is connected to the CPU?
    "We do not wash our pits in the sacred pool of tears..."
  • Thu, Jun 5 2008 3:52 PM In reply to
    Re: Media Composer 2.8.1 with Mac Pro in Win XP.
    Are you booting in XP or are you running an emulator?
    MacPro Symphony Nitris DX (v3.0.5), MacPro MCA HD (v3.0.5), Mac Meridien (v12.1.2), Unity LanShare EX (v4.1.6) [view my complete system specs]
  • Thu, Jun 5 2008 11:01 PM In reply to
    • mix74
    • Posts 4
    • Points 70
    Huh? Is the firewire on the back, the internal one.
    I am running XP by bootcamp.
    Nothing else is connected to the mac ports...
    Any idea?  Thank you!
    Andrea
  • Fri, Jun 6 2008 4:08 AM In reply to
    • jdrouette
    • Vancouver, BC
    • Posts 72
    • Points 955
    I had the same problem using the Mac Pro's built in Firewire ports. I solved the problem by installing an ADS Pyro PCIe Firewire card and connecting the Mojo to it instead of the built-in ports. For some reason the Mojo doesn't like the Mac Pro's ports on the Windows side, while they're OK in OSX.
    Also, if you're running SP2, make sure that you've installed the Windows XP firewire firewire fix update:
    http://support.microsoft.com/kb/885222
    I presume this fix is included in SP3, although I haven't tested that update.
    Hope this helps!
    jd
    Avid Media Composer 3.1 + Avid Mojo DX on Mac OS 10.5.5, Mac Pro 2 x Dual Core Intel Xeon 2.66 Ghz 6GB SDRAM, NVIDIA GeForce 8800 GT 512MB, Quicktime Pro... [view my complete system specs]
  • Fri, Jun 6 2008 8:36 AM In reply to
    • mix74
    • Posts 4
    • Points 70
    jdrouette:
    Hope this helps!
    jd
     Thank you Jd.. i will try this solution! Do you have a mac pro with leopard 10.5.3 too? Is exactly the same mac configuration of mine?
    Thank you !
  • Fri, Jun 6 2008 3:00 PM In reply to
    • jdrouette
    • Vancouver, BC
    • Posts 72
    • Points 955
    You can see my specs below. I recently installed Leopard since I wouldn't be using my home system much until MC 3.0 came out. MC 2.8 installed on 10.5.2 but it doesn't work with the Mojo connected. It's OK for editing, though.
    I should point out that it is VITAL that you use the ADS Pyro card in Windows, and NOT a generic firewire card. I tried one of those first and it did not work until I got the Pyro.
    Good luck!
    jd
  • Fri, Jun 6 2008 7:42 PM In reply to
    • mix74
    • Posts 4
    • Points 70
    jdrouette:
    Good luck!
    jd
     Amazing! Updating XP as you have recommended everything works! Even if unfortunatlely XP recognizes only 2 GB of RAM..
    Also on the inside/back firewire seems that Mojo correctly works! Thanks JD you  have been precious!  Now we just have to wait for MC 3.0..
    Andrea
     PS. I forgot: how can U run Avid software on leopard? Ireally can not!! (also without mojo...)
  • Sat, Jun 7 2008 5:24 AM In reply to
    • jdrouette
    • Vancouver, BC
    • Posts 72
    • Points 955
     I'm happy to hear it worked out.
    I found the following recipe for Leopard somewhere else on the forum and it worked for me. It appears that 3.0 may be arriving next Monday, so you may not want to bother unless you're really desperate...
    1. Update Leopard to 10.5.2 (including Quicktime)
    2. Install Media Composer 2.8 (Not 2.8.3)
    3. Recieved digIO.kext error
    4. Restarted Avid and was prompted to Pace website
    5. Installed Interlok extention for Mac OS v5.6.1
    6. Recieved error "app core midi server quit caused by Direct IO plug-in"
    7. Went to library>audio>mididrivers and dumped everything
    8. Restarted computer and launched Avid
    9. Began editing with no problems
    Cheers,
    jd
