Latest post Fri, Jun 6 2008 1:16 AM by Kenton.VanNatten. 11 replies.
Page 1 of 1 (12 items)
  • Thu, Jun 5 2008 2:23 AM
    • BEN3MAN
    • Joined on Sun, Jun 25 2006
    • harrisburg,PA,USA
    • Posts 62
    • Points 830
    Audio frequencies reduced when copying tracks
    First off, I realize that when 2 pieces of the same audio playing exactly together, they will phase out one another, reducing frequencies.  The problem is, I don't know how to get my audio, which is on one track, to another track duplicated, and have the sound be how it was before, and on both tracks, in stereo, without being muffled.  In the past I was just taking the audio track, copying it and pasting it on a new track and it would sound great.  I did a whole feature length project this way, taking the better of the 2 tracks and removing the bad one and copying the good track, and the tracks would play together without any loss of sound.  Now, when I do this, every time I do it, it is phasing out the tracks, and it sounds muffled.  Am I missing something here?  Is there a better way?  I am at a loss to figure it out.  I messed with the pan etc.  I am stumped.  Can someone please help me with this?  Thanks.  B--
  • Thu, Jun 5 2008 2:33 AM In reply to
    Re: Audio frequencies reduced when copying tracks
    I have to ask "Why are you copying to another track?"  what's the point of having the exact same clip on two tracks.  If you want to hear that track in both speakers, then just pan that one clip to the "mid".
    I'm sorry don't know why you are getting the loss of signal.
    MC 2.5.1 with Analog Mojo. HP xw8000, dual 3.0 Xeon, 3 Gig Ram, nVidia FX1100, ADS Pyro Firewire Card. [view my complete system specs]
  • Thu, Jun 5 2008 3:37 AM In reply to
    • BEN3MAN
    • harrisburg,PA,USA
    • Posts 62
    • Points 830
    I did it before cause it seems to make everything much louder thats why, but not anymore.
  • Thu, Jun 5 2008 6:16 AM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,569
    • Points 78,500
     You are experiencing "phase cancelling" because one of the channels is 180 degrees out of phase with the other. To correct the problem, go into audio suite and apply an "invert" effect to ONLY ONE of the two channels - it doesn't matter which.
  • Thu, Jun 5 2008 7:50 AM In reply to
    Which, BTW,  is a bad solution if the phase inversion happens in monitoring.
    If you switch your audio output to mono, what happens?
    Is the panning different on these tracks?
    You should search for any place in the chain where the phase may get shifted or flipped. Simple procedure involves creating tone media in the Avid Audio Tool, then splicing that tone into (two) different tracks, and measure what happens.
    Your original remark worries me, though:
    They should not. Two identical pieces of a clip, played back twice, on different tracks, panned to the same outputs, should line up 1000%, and only increase the total volume, and should not cancel anything out.
    Symphony Nitris 3.0 on 2xquad core XW8400/8GB | MC 3.0 on dual core XW8400/3GB | Mojo SDI | Unity Lanshare 4.23 fibre | MC 3.0 on MacBook 2.16/2.5GB |... [view my complete system specs]
  • Thu, Jun 5 2008 9:38 AM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,660
    • Points 78,890
    i so agree, a copied track which phases out another has another problem. But you should really look at your workflow. Copying a track to increase volume is a bad workflow... just set the pan to mid and use the audio level to increase the level... and you should be checking your monitoring system as there is a good chance you switched wires somewhere..
    Menno
    Test-Intel Core2Duo 6800,GTS8800 Nvidia (soft modded into Quadro FX4600),Soundblaster Live 5.1, 21" Samsung display [view my complete system specs]
    Dutch AV forum
  • Thu, Jun 5 2008 8:28 PM In reply to
    • teddylevy
    • Posts 22
    • Points 230
    If someone really needs to boost the volume of some very low audio in a sequence beyond the +12 setting in the Audio Mixer faders, they can always switch to the AudioSuite, apply the Gain effect, bring up the wiindow and enter the number of decibels of gain (remember to cliick "OK" or it won't be entered), then render the effect in the timeline.
  • Thu, Jun 5 2008 8:55 PM In reply to
    • evansmalley
    • Kansas City, MO (USA)
    • Posts 268
    • Points 3,395
    BEN3MAN:
    no,  O BEN3MAN, 2 COPIES of the same audio will only cancel each other when they are OUT OF PHASE. If they are IN phase, they will play properly, but as all have said- it's best to just raise the volume of the one (mono track, and these things ONLY apply to a mono track) you can find extra gain in a number of stages (called gain staging) within your signal path. Besides adding volume in the ways mentioned, you can add volume at specific frequencies with EQ, and also add volume with "output gain makeup" after a compressor. You would probably be wisest to export your audio to an audio app, as Avid's audio tools are merely adequate in a pinch, but there are much better apps for real audio work.
    Just because you have successfully pasted a copy to a 2nd track before, doesn't mean that it's good gain staging or good audio technique! But lots of crazy stuff works fine! And who cares?!
    Still, you should better analyze what's going on with your audio tracks- if/when your program is summed to mono you're probably just begging for trouble the way you're trying to do it! Try exporting to a decent audio program and clean up, polish, pump up!, and enhance your sound- then import it back to Avid. I recommend .wav's for import/export... but there are lots of options.
    HTH-
    Ev
    P4 XPsp2, 2.8 GHz, 2 gig RAM, 120 gig, 2x160 gig and 80 gig drives, much other external drive'n, dual-monitor mode, 2x MOTU 2408 mk2 ASIO, Tascam US... [view my complete system specs]
  • Fri, Jun 6 2008 12:30 AM In reply to
    • BEN3MAN
    • harrisburg,PA,USA
    • Posts 62
    • Points 830
    Cool guys...lots of input for this!  The audio suite gain is a good solution which I knew about at one point but since I haven't edited in about a year, I completely forgot about.  Also, I may have an answer to what happened, I think somewhere along the line, my reciever got switched to the wrong setting.  I'm at work, but I will check it when I get home.  I have been panning it to center for the time being, but I just found it less of a hassle and faster just to copy and paste the track to increase the volume, for me anyway.  I will see if that audio suite gain trick will boost my levels to the needed levels.  Thanks everyone.  B--
  • Fri, Jun 6 2008 12:53 AM In reply to
    • BEN3MAN
    • harrisburg,PA,USA
    • Posts 62
    • Points 830
    The invert audio solution fixed my problem....BIG Thanks....!!!
  • Fri, Jun 6 2008 12:56 AM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,569
    • Points 78,500
     You're quite welcome, Ben. I'm glad to help and glad that worked out for you.
  • Fri, Jun 6 2008 1:16 AM In reply to
    teddylevy:
    I dislike rendering most times... so I often use the Automation Gain to get extra boost after I maxed out the +12 in the Mixer.
    MacPro dual 2.66GHz 2GB RAM NVIDIA GeForce 7300 GT Storage: 2TB G-Speed eS with controller card 3x500GB Hitachi SATA-II internals various external... [view my complete system specs]
