Latest post Tue, Jun 10 2008 4:16 PM by Dom Q. Silverio. 4 replies.
  • Wed, Jun 4 2008 5:53 PM
    • JP Redman
    • Joined on Wed, May 31 2006
    • Sacramento, California
    • Posts 30
    • Points 530
    Anyone successfully connected a Dell 755 to a Unity LANshare?
    Has anyone figured out a way to get a Dell 755 computer to talk well with a Unity LANshare?
    The background is a sad story, but I'll keep it short as I can.
    We set out to build an encoding station on which to turn edited projects into DVDs, Quicktime, Real, Flash, etc. QT Reference files would be created on edit stations and saved to the Unity LANshare. The encode station would connect to the Unity, pickup those QT Refs, and using the raw media files do the needed encodes.
    After consulting with Avid Support I did the specs for an HP machine. BUT our university is a Dell campus so Purchasing looked at my specs, found a Dell with exactly the same specs, and bought it.
    Unfortunately, that Dell and the Unity don't get along. They connect, but the connection speed is VERY slow.
    Avid Support doesn't have any info on the 755 and can't help. One fellow their suggested that if one of the PCI slots doesn't share its buss with anything else we might successfully put a supported card in that slot. Unfortunately, both slots share their buss' with something else.
    I'm at a loss.
    So back to the question... has anybody managed to create a usable connection between a Dell 755 and an Avid Unity LANshare?
    Thanks, JP
    Unity LANshare [v4.1.6] with ZX MediaArray (2TB)fiber networked to 2 - HP xw-8000 Adrenaline [both with Nvidia Quadro FX1100] (1 has DNxcel HD board)running... [view my complete system specs]
  • Wed, Jun 4 2008 9:54 PM In reply to
    • jasonsaro
    • Philadelphia
    • Posts 447
    • Points 5,420
    Re: Anyone successfully connected a Dell 755 to a Unity LANshare?
    Sorry man, this is why Avid uses workstations that have dual bus's.  One for a mojo / camera, and the other for the unity connection.
    Jay
    4 MCA's ver. 2.8 1 MC Meridian Composer 1000 Ver 12.1.1 3 MC Mojo 2.8 1 Xpress Pro Mojo 5.2 1 LanShare 6TB Ver. 4.1.5 [view my complete system specs]
    "What we want is a smashing theme of mythic grandeur" - Stanley Kubrick Favorite Avid Term "JBOD" - Just a Bunch Of Disks _______________ Jason Saro SR. Avid Editor / Unity Admin. - Nancy Glass Productions jason@nancyglassproductions.com
  • Wed, Jun 4 2008 10:11 PM In reply to
    I assume you are trying to connect this via Ethernet?
    If yes, check your Unity ethernet switch. It will indicate to you how fast is the actual connection (via color of the LED lights).
    What OS do you have installed? What version of File Manager and Connection Manager?
  • Tue, Jun 10 2008 4:11 PM In reply to
    • ceffoavid
    • Joined on Thu, Jan 17 2008
    • Posts 123
    • Points 1,400
    How would someone get any client connected to Unity with an unsupported fiber or ethernet card?
    I would think you must have a supported card to connect.
    ACSR
    Media Composer, Symphony, DS, Unity
  • Tue, Jun 10 2008 4:16 PM In reply to
    With FC you NEED to use supported cards. Wrong config can cause corrupt data. For ethernet, Unity is a lot more forgiving. You can pretty much use any gigabit ethernet card.
