Latest post Mon, Jun 23 2008 1:53 PM by Larry Rubin. 15 replies.
  • Wed, Jun 4 2008 9:08 AM
    • dariv
    • Joined on Tue, Dec 5 2006
    • Posts 151
    • Points 2,260
    Can I import shared footage into a private project
    I have captured some footage into a shared project, I now want that footage in another project, which is private.
    When I try import> shared avid projects >test bin it tells me wrong format.
    How can I get the footage into the private project without having to re-capture?
    Thanks.
    Avid xpress pro v5.5.3 Dell Inspiron 6400 (videoguys tweaked) 80gb hard drive 2gb RAM E:drive 300 gb Deck Varies [view my complete system specs]
    AKA Newbie Wan Kanewbi
  • Wed, Jun 4 2008 9:26 AM In reply to
    Re: Can I import shared footage into a private project
    Are both projects the same format?
  • Wed, Jun 4 2008 10:44 AM In reply to
    • dariv
    • Posts 151
    • Points 2,260
    yes they are
  • Wed, Jun 4 2008 1:53 PM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,660
    • Points 78,890
    do you want to import the media or do you want to use a bin from that project? if the latter you might as well copy paste the bin inside the project you created..it will show up fine and if indeed the same project settings apply it will open.
    Menno
    Test-Intel Core2Duo 6800,GTS8800 Nvidia (soft modded into Quadro FX4600),Soundblaster Live 5.1, 21" Samsung display [view my complete system specs]
    Dutch AV forum
  • Wed, Jun 4 2008 2:01 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,568
    • Points 78,465
     Keep in mind that any media shared into another project will go offlline if the original project it was borrowed from is deleted. Using the consolidation process will eliminate this possibility.
  • Wed, Jun 4 2008 5:17 PM In reply to
    • dariv
    • Posts 151
    • Points 2,260
    Cool, thanks for that guys, could I just ask what's the consolidation process and how do I implement it?
  • Wed, Jun 4 2008 5:24 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,568
    • Points 78,465
     In the new project, use the open bins command to navigate to the appropriate bin from the source project, then right click on the clip or sequence and choose "consolidate/transcode". In the pop-up window, select "consolidate", identify the target drive, decide whether you want a new sequence created, and whether or not to skip media files already on target drive. Then launch the process. This will create a new set of clips that are linked to your new project.
  • Wed, Jun 4 2008 5:41 PM In reply to
    Edit: nm. I walked away fro 5 mins on reply screen...
    It has nothing to do with share/private projects. You just have 2 different project types this is why you are getting the Wrong Format error.
  • Wed, Jun 4 2008 5:44 PM In reply to
    • dariv
    • Posts 151
    • Points 2,260
    Sorry Larry, I'm a total newb and still don't get it, I've followed your advice I'm still at a loss as to what to do next, how do I get the media I've just consolidated into my original project?
    Also copy and pasting the bin didn't work.
  • Wed, Jun 4 2008 5:47 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,568
    • Points 78,465
     Sorry, dariv, I left out a step. I have edited my previous response to include it.
  • Wed, Jun 4 2008 5:50 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,568
    • Points 78,465
     Also, after you have created the new clips, which will have a ".new" suffix attached to them, you can create a new bin in your new project and move the consolidated clips from the original project bin to the new project bin. And if you chose "master clips remained linked to media on the original drive", you will have two completely independent sets of identical clips - the original ones which are linked to the original project and the new set of clips linked to the new project.
  • Wed, Jun 4 2008 6:23 PM In reply to
    • dariv
    • Posts 151
    • Points 2,260
    great stuff, I'll get to it, thanks
  • Mon, Jun 23 2008 11:28 AM In reply to
    • dariv
    • Posts 151
    • Points 2,260
    Have been away  from this  one for a while to see if it made any difference. But I seem to be missing something, the procedure I've followed is below:
    I have to projects; A and B, I wanted to take some captured footage from project B (shared) and put it into project A.
    I consolidated the relevant clip in project B, then created a new folder in project A, then, tried to import from shared avid projects.
    Once in shared avid projects I expected to see two sets of the consolidated clips, but only saw one, but tried to import anyway and the error message I get is; the file format of test.avp is not supported for import.
    Where have I gone wrong?
  • Mon, Jun 23 2008 1:12 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,568
    • Points 78,465
     You need to have the project open that you are consolidating to, not the one you're consolidating from when you create the new consolidated clips. That's why you use the open bins command while inside project A. This is necessary so that the .new clips are associated with project A, not project B. If you do the consolidation within project B, the new clips will be linked to project B. No importing after the fact is necessary. Just move the ".new" clips into a local bin in project A.
  • Mon, Jun 23 2008 1:48 PM In reply to
    • dariv
    • Posts 151
    • Points 2,260
    Thank you for having the patience with me Larry, I've finally got it now, that was my problem I was consolidating from the wrong project :-).
    Once again thank you for your help.
