Latest post Sat, Jun 7 2008 9:59 PM by Reanimated. 6 replies.
Page 1 of 1 (7 items)
  • Wed, Jun 4 2008 4:20 AM
    consolidating errors
    I am having problems moving media from one drive to another.  I don't know what is causing the issue because it doesn't happen all the time, but I will consolodate media from one drive to another and everything will be fine, then the AVID will do a scan of the drive and determine the consolodated media is now not recognizable as a media file and I have to either ignore or quarantine the file.  What would cause the omf file to all of a sudden become unrecognizable to the system when I've done nothing to it?
    Quad Core 3 gHz Intel / 3 GB RAM / OS 10.4.11 [view my complete system specs]
  • Wed, Jun 4 2008 12:54 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,566
    • Points 78,455
    Re: consolodating errors
     Look at the contents of your OMFI MediaFiles folder. I'm wondering if the ".omf" suffix might be missing from the files in question. In the case of MXF Media, the suffix would be ".mxf".
  • Fri, Jun 6 2008 9:54 PM In reply to
    No, the suffix is there.  So far as I can tell, there is nothing missing or wrong with the file.  It is primarily the video portion of the omf, the audio is almost always fine.
  • Sat, Jun 7 2008 9:12 PM In reply to
    • siencs
    • Joined on Wed, Oct 17 2007
    • Posts 164
    • Points 1,855
    What happens if you choose 'ignore'? Do you actually have any missing media? We sometimes get this error (we're using non-avid shared storage) but if we 'ignore' no media is actually offline and the next time we start up the error message doesn't appear.
    2x MC 2.6.6 with Mojo on HP xw8400 MC Adrenaline 2.6.6 on HP xw8400 MC 2.8 on MacPro dual 2.66 Editshare 4.1 [view my complete system specs]
  • Sat, Jun 7 2008 9:33 PM In reply to
    • Reanimated
    • Joined on Mon, Jan 16 2006
    • Stockholm, Sweden
    • Posts 57
    • Points 645
     I've had a similar problem....
    don't know if it's the same problem
    but I was consolidating an old project that I started in xpress dv and I couldn't consolidate in mc- it was all the dissolves and audio dissolves that was rendered......
    I deleted all the renders (lost a few imported stuff) and then after re-importing some stuff I could consolidate.....
    hope it helps.....
    henrik
    MC 3, Nitris DX, HP XW8600, Win Vista 64bit, Avid VideoRaid RTR320, MC 2,8,Mojo SDI, HP nw9440 2GB, Windows XP Pro SP2, Aten usb to rs-232thing Homebuilt... [view my complete system specs]
  • Sat, Jun 7 2008 9:36 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,566
    • Points 78,455
    Reanimated:
    Have you checked the resolutions between the two systems to make sure the resolution you worked in within DV Express is present in Composer?
  • Sat, Jun 7 2008 9:59 PM In reply to
    • Reanimated
    • Stockholm, Sweden
    • Posts 57
    • Points 645
    I was in panic.... didn't check anytning...... just wanted it to work...... And it does :)
