Latest post Mon, Jun 2 2008 8:09 PM by bccforlife. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Jun 2 2008 3:26 AM
    • bccforlife
    • Detroit
    • Posts 32
    • Points 410
    Quicktime exporting issue
     I just installed Media Composer on a new XP system. Everytime I try to export a quicktime using custom settings its gives me and exception error and I have to restart Avid just to continue working. I went to download the latest quicktime thinking that may be the issue, but it wasn't. Then I uninstalle and then reinstalled Avid but that didn't fix the issue either. Does anyone know why quicktimme and Avid aren't working? The other exporting options work fine. I didn't know what else to try.
    Other quicktime files play fine through the quicktime program.
  • Mon, Jun 2 2008 12:53 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,169
    • Points 73,620
    Re: Quicktime exporting issue
     Check your QT version and driver version against this matrix to make sure you are running the right ones.
  • Mon, Jun 2 2008 1:41 PM In reply to
    • bccforlife
    • Detroit
    • Posts 32
    • Points 410
     Hi, I am running the correct version listed. 7.1.6 but I still get the error.
  • Mon, Jun 2 2008 4:08 PM In reply to
    Gosh, you could try a number of things.  What's the destination for your .mov files? Network or Local drive?  What's the running time of your program?  Do you have any other software running besides Avid?  Are you using "same as source" in your QT settings?
    Failing that, is it possible you've got a corrupt media file? One way to check is to simply make Mark In/Out points on a small portion of your program to see if you can get it to work.  Of course, you may have to do that in a couple of different places to insure you don't happen to pick the spot that might have the corrupt media.
    Unfortunately, there's much to consider (and troubleshoot).
    Tim Scarpino
    Avid MCA v2.6.4 on HP xw8200 Windows XP SP2 4 gig RAM QT v7.2 [view my complete system specs]
  • Mon, Jun 2 2008 4:11 PM In reply to
    • PPavel
    • Joined on Fri, Jun 9 2006
    • Brno, Czech Republic
    • Posts 50
    • Points 610
    Someone in other thread suggested to turn off using the Directx and it solved the same problem for me in MC 2.8.1 and MC 2.8.3.
    Go to QuickTime preferencies, Advanced tab, Video section. Then swith to Safe mode. I hope it'll help you too.
    PP
    MC 3.0.5, Mojo, Dell 670, 2x Xeon 3.2GHz, 2GB RAM, nVidia Quadro FX4000, Win XP SP2 [view my complete system specs]
  • Mon, Jun 2 2008 5:04 PM In reply to
    • DonR
    • Irving, Mexas
    • Posts 89
    • Points 1,260
    A couple of weeks ago II had the same problem with custom settings in QuickTime and checking the "Safe Mode" box in QT solved the problem.
  • Mon, Jun 2 2008 8:09 PM In reply to
    • bccforlife
    • Detroit
    • Posts 32
    • Points 410
     Yes thank you so much guys, that did the trick.
    Big Smile
