Latest post Sun, Jun 8 2008 1:07 AM by TommyAF. 18 replies.
Page 2 of 2 (19 items) < Previous 1 2
  • Sun, Jun 8 2008 12:47 AM In reply to
    • zacksnygg
    • Fort Lee, NJ
    • Posts 59
    • Points 750
    Re: 24p confusion
     Tommy,
    This was the answer from RAYLIGHT
    MXFX needs the XML file to get the starting timecode and other info.
    To use MXFX you will need to get one good XML file and make a copy of
    it for every clip. If you don't care about the timecode you can use an
    identical copy for each one, but the file name must match the name of
    the clip (eg 0001GH). The folders need to be set up as follows:
    VIDEO folder contains the video MXF files eg 0001GH.MXF
    CLIP folder contains the fake XML files eg 0001GH.XML
    AUDIO folder contains the audio MXF files eg 0001GH00.MXF, 0001GH01.MXF etc.
    Best Regards
    DVFilm Support Team
    Essentially you create a three folders under a CONTENT folder AUDIO, VIDEO and CLIP - copy and paste from AVID MEDIAFILES your MXF media - placing video MXF files in VIDEO folders and placing MXF audio files into the AUDIO folder.  From there you create your own XML clip files.  Then drag into RAYLIGHT MXFX and it does downconvert to 23..98. It works.
    Now the question is - can you take a Video Mixdown file in AVID MEDIAFILES and do the same thing?  I haven't had any success at that.  Let me know if anyone has any success with taking a Mixdowned Video file in AVID MEDIAFILES and creating a Pulldown removal in Raylight.
    Best,
    Zack
    Pentium 4 CPU 3.6 Ghz Esata Drives 3000 gigs of memory Avid xpress 5.6.3 Avid Media Composer 2.8.1 [view my complete system specs]
  • Sun, Jun 8 2008 12:54 AM In reply to
    • TommyAF
    • Joined on Fri, May 4 2007
    • Posts 47
    • Points 675
    Re: 24p confusion
    Thanks for that info, where do the XML files come from though?  I have none of those.
    Media Composer 3.0, Windows Vista Ultimate, Intel Core 2 Duo CPU T7800 @ 2.60GHz, 3.00 GB RAM (Should be 4?), NVIDIA GeForce 8400M GT [view my complete system specs]
  • Sun, Jun 8 2008 12:58 AM In reply to
    • zacksnygg
    • Fort Lee, NJ
    • Posts 59
    • Points 750
    Re: 24p confusion
     You can contact RAYLIGHT direct they will send you one.
    Be specific what you are looking for you want 1080i/59.94 XML and are going to 23.98 etc
    Support <dvfilmsupport2@gmail.com>
    Best,
    Zack
  • Sun, Jun 8 2008 1:07 AM In reply to
    • TommyAF
    • Posts 47
    • Points 675
    Re: 24p confusion
    Great, thanks Zack!
