Latest post Tue, Jun 3 2008 6:32 PM by sjon. 17 replies.
  • Sun, Jun 1 2008 4:12 PM
    • sjon
    • netherlands
    • Posts 210
    • Points 2,780
    avid 351 freezez
    when I connect my pd-150 on my Imac 10.3.9 it freezes allready at the beginning.
    When it's not connected (firewire)...it just starts. No problems with connecting to my powerbook g4...only with the Imac an that's never happened before also....
    Any suggestions welcome!
    mac 0SX 10.5.2. dual boot 2.6 ghz intel core 2 duo 4 gb 667 mhz ddr2 sdram media composer 2.8 [view my complete system specs]
  • Sun, Jun 1 2008 4:53 PM In reply to
    Re: avid 351 freezez
    What are the specs of the iMac?  Is it Intel-based?
    MacPro dual 2.66GHz 2GB RAM NVIDIA GeForce 7300 GT Storage: 2TB G-Speed eS with controller card 3x500GB Hitachi SATA-II internals various external... [view my complete system specs]
  • Sun, Jun 1 2008 6:18 PM In reply to
    • sjon
    • netherlands
    • Posts 210
    • Points 2,780
    The specs of the mac with the problem is Imac, 16 ghz, powerpc 1,5 gb ddr sdram
  • Mon, Jun 2 2008 12:56 AM In reply to
    • sjon
    • netherlands
    • Posts 210
    • Points 2,780
    anyone???
  • Mon, Jun 2 2008 3:00 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,871
    • Points 175,805
    What version of QT Sjon? Also, you don't say what version of the Avid software.....
  • Mon, Jun 2 2008 10:26 PM In reply to
    • sjon
    • netherlands
    • Posts 210
    • Points 2,780
    <p></p> avid 4.3.5 qt 7.4.5. (just upgraded....might that be the problem)?
  • Mon, Jun 2 2008 11:00 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,871
    • Points 175,805
    Could be, yes. I would roll back to the approved version as a first troubleshooting step. May not solve anything but it will eliminate a variable.
  • Mon, Jun 2 2008 11:43 PM In reply to
    • sjon
    • netherlands
    • Posts 210
    • Points 2,780
    what version of qt is compatible again and how can I downgrade?
  • Tue, Jun 3 2008 5:00 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 2,754
    • Points 31,475
    Check out the OSX Cheat Sheet announcement on the top of the Forum page for the OSX, Xpress Pro and QT version matrix.
    MacPro, MacBook Pro and a Cube. The Cube doesn't do much but it looks cool. [view my complete system specs]
  • Tue, Jun 3 2008 7:26 AM In reply to
    • sjon
    • netherlands
    • Posts 210
    • Points 2,780
    where can I get QT 6.5(1)...? Is this stil available...did a search, but nothing...
  • Tue, Jun 3 2008 11:26 AM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,871
    • Points 175,805
  • Tue, Jun 3 2008 11:33 AM In reply to
    • sjon
    • netherlands
    • Posts 210
    • Points 2,780
    thanks blkdg! you're the best.
    One more to go: I dropped QT in the trash and tried to install qt 651...then I get the message:
    not possible, there is a newer qt allready installed....
    how does this work????
  • Tue, Jun 3 2008 11:37 AM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,871
    • Points 175,805
    There are third party apps that will let you uninstall QT but the easiest way is  to just do an archive and install of your OS and then upgrade only as far a 6.5.1.
  • Tue, Jun 3 2008 11:53 AM In reply to
    • sjon
    • netherlands
    • Posts 210
    • Points 2,780
    how can i archive and install os? sounds more difficult than uninstall qt??
  • Tue, Jun 3 2008 12:18 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,871
    • Points 175,805
    No, it's not actually. It is very simple.
    Just put your Panther install disc in and boot from it. In the install options window, choose "Archive and install". Also choose to preserve User and Network Data. A new copy of the OS will be installed leaving your applications and user data untouched. You  will, however, have to reinstall the Avid software after doing this.
