Latest post Mon, Jun 2 2008 5:00 PM by hbrock. 2 replies.
  • Sun, Jun 1 2008 4:39 AM
    • mGmiller75
    • Joined on Tue, Nov 13 2007
    • Posts 6
    • Points 90
    Can't get my Mojo workin'!
    Help!  I just bought a used Mojo off someone -- very nice person who will give me my money back if I can't get this thing to work.
    Here's what I've got, system-wize:
    Cutting on Avid Xpress Pro v5.8 (Academic)
    Using a Mac Pro Tower with OS 10.4.11
    Don't know if this is important, but the Mojo was previously being used with a PC.
    I plug in the Mojo correctly, separate bus, etc.  When the Mojo comes on, the lights for POWER and HOST are lit.  My Mac does recognize the Mojo through Firewire.
    When I open Avid Xpress Pro, I get a "Power Up Error" and am asked to close the program and power-cycle the hardware, which I've done numerous times, and it still doesn't work.
    I've tried:
    Different power supplies/cables
    Different firewire cables
    Re-installing Avid Xpress Pro
    I am taking the Mojo tomorrow to try on a different computer, but the seller assured me he has never had any problems with it.  I tried e-mailing Avid Tech Support, but didn't really get an answer.  Also talked with some local tech guys from where I work, and they couldn't figure it out.  They told me that having Academic version and the fact that the Mojo was previously used on a PC don't matter -- it should still work.
    Any other thoughts on what I can try?  Why isn't this working?
    Thanks!
  • Sun, Jun 1 2008 1:25 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,696
    • Points 161,345
      Moderator: MCA Mac
    Re: Can't get my Mojo workin'!
    The Power up error means that the incorrect version of firmware is on your Mojo.
    Unfortunately, the only way to re-flash the firmware is to load an older version of the software (Like 4.8.x), launch it and let the software re-flash the Mojo and then to load the current version and let if update the firmware.
  • Mon, Jun 2 2008 5:00 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 2,714
    • Points 31,085
    And you'll need to find a older Mac or any PC to load a old version of Xpress Pro as 4.8 won't work on a Mac Pro.
    MacPro, MacBook Pro and a Cube. The Cube doesn't do much but it looks cool. [view my complete system specs]
