Latest post Sat, May 31 2008 9:50 AM by chumpster. 3 replies.
  • Sat, May 31 2008 3:12 AM
    Exporting QT out of MC Adrenaline, audio problem: Help!
    I'm getting warbled audio when I export a QT using h264 and ima 4:1 (22kHz, mono). does anyone know if there is a fix? I'm running MC Adrenaline 2.8 on a PC with QuickTime 7.3.1
    2 dual core 3.2 GHz Xeon processors 2G RAM XP, SP2 Hard drives: 2 500 GB IDE Local 2 500 GB firewire External Xpress Studio Complete (Mojo, Digi002... [view my complete system specs]
    Trevor Hyslop day18.com
  • Sat, May 31 2008 7:49 AM In reply to
    Re: Exporting QT out of MC Adrenaline, audio problem: Help!
    Have you tried an audio mixdown to a mono track before exporting?
    Any good reason for not using your projects audio sample rate in your QT export?
  • Sat, May 31 2008 9:47 AM In reply to
    • chumpster
    • Central Scotland
    • Posts 20
    • Points 250
    I've experienced this same problem whilst using similar export settings (but my audio was 44kHz).  I was scratching my head for ages, and then I tried exporting it at 48kHz, and it sounded fine.
    So, as a quick fix, try exporting at the original sample rate.
    Hope it works for you,
    CP
  • Sat, May 31 2008 9:50 AM In reply to
    • chumpster
    • Central Scotland
    • Posts 20
    • Points 250
    Oh, and I also exported it with two channels of sound after I had the warble problem.
