Guys it's been a couple of weeks that I upgraded to 5.7.5 , so I can look at
Avid's new subcap plugin.
I tried capturing a dvd through my DVCAM deck, I get video but no audios ?
thanks
Mike
I found an old post my Marianna! fixed the problem thanks Marianna
With the new subcaps does somebody know how to make the texts in italics?
thanks again Marianna
here's Marianna's post:
Hey folks......... Menno escalated this situation to me yesterday and here is what I have found. You have to choose transcoder as your device first but then you will need a fix or you'll get timecode repeats causing the audio to be written in as zeros - hence the errors. QA says there is a fix coming soon and says it has to do with using the device as a transcoder. It's difficult to tell from the posts above if that is how some of you are using the devices, or whether tyou are using the decks as just decks, but QA can reproduce the issue, and a fix is coming soon which will solve their problems. From what I can gather - the fix will be in June. Email me directly if this is not what is happening to you and I can research further. Thanks Menno for letting me know this was happening. Marianna marianna_montague@avid.com [view my complete system specs] marianna_montague@avid.com 813-493-6800 AOL IM avidmarianna
813-493-6800
AOL IM avidmarianna
thx for the feedback! Sorry have no answer to your other question..
Menno
Dutch AV forumFCP2Avid I hear and I forget. I see and I remember. I do and I understand. - Confucius
Marianna's response to this problem was actually written in May of 2007. So, don't go counting on any sort of fix in June of this year, or a fix at any time at all. First, her suggestions didn't work for me, and second, Avid has no intentions whatsoever of fixing this problem that so many of us have suffered with for the past several years.
