Latest post Sun, Jun 1 2008 7:12 AM by joelrmorgan. 3 replies.
  • Sat, May 31 2008 12:21 AM
    • MIkeFilm
    • Joined on Mon, Apr 24 2006
    • Posts 215
    • Points 2,945
    no audios
    Guys it's been a couple of weeks that I upgraded to 5.7.5 , so I can look at
    Avid's new subcap plugin.
    I tried capturing a dvd through my DVCAM deck, I get video but no audios ?
    thanks
    Mike
  • Sat, May 31 2008 12:49 AM In reply to
    • MIkeFilm
    • Posts 215
    • Points 2,945
    Re: no audios
    I found an old post my Marianna!  fixed the problem thanks Marianna
    With the new subcaps does somebody know how to make the texts in italics?
    thanks again Marianna
    here's Marianna's post:
    Hey folks.........  Menno escalated this situation to me yesterday and here is what I have found.
    You have to choose transcoder as your device first but then you will need a fix or you'll get timecode repeats causing the audio to be written in as zeros - hence the errors.
    QA says there is a fix coming soon and says it has to do with using the device as a transcoder. It's difficult to tell from the posts above if that is how some of you  are using the devices, or whether tyou are using the decks as just decks, but QA can reproduce the issue, and a fix is coming soon which will solve their problems. From what I can gather - the fix will be in June.
    Email me directly if this is not what is happening to you and I can research further.
    Thanks Menno for letting me know this was happening.
    marianna_montague@avid.com
    813-493-6800
    AOL IM avidmarianna
  • Sun, Jun 1 2008 12:10 AM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,625
    • Points 78,505
    Re: no audios
    thx for the feedback! Sorry have no answer to your other question..
    Menno
    Test-Intel Core2Duo 6800,GTS8800 Nvidia (soft modded into Quadro FX4600),Soundblaster Live 5.1, 21" Samsung display [view my complete system specs]
    Dutch AV forum
  • Sun, Jun 1 2008 7:12 AM In reply to
    • joelrmorgan
    • Gresham, Oregon
    • Posts 131
    • Points 1,720
    Re: no audios
    Marianna's response to this problem was actually written in May of 2007.  So, don't go counting on any sort of fix in June of this year, or a fix at any time at all.  First, her suggestions didn't work for me, and second, Avid has no intentions whatsoever of fixing this problem that so many of us have suffered with for the past several years.
    - Dell Precision 670 - Dual Xeon processors (2.8) - 2 gigs of Ram - nVidia 1400 (driver 7.7.1.8) - Creative SB X-Fi sound card - 120 Gig boot hard... [view my complete system specs]
