Latest post Fri, May 30 2008 8:33 PM by Larry Rubin. 5 replies.
Page 1 of 1 (6 items)
  • Fri, May 30 2008 7:33 PM
    • Yasch
    • Joined on Tue, Sep 19 2006
    • New York
    • Posts 37
    • Points 480
    Video Input Tool
    I have a 45 minute program cut and when I redigitized in hi-rez, all the footage came in dark. In the past, I redigitized leaving the video input tool at the default settings and the footage looked accurate enough.
    Is it necessary to create a custom setting for each tape in the video input tool? What is the proper workflow?
    Media Composer v2.8.3 (PC) HP xw8200, Xeon 3.40GHz, 3GB RAM, 4TB Unity MediaNetwork Server (connected via 4Gb Fiber) [view my complete system specs]
    Yanky Ascher
    Jewish Educational Media | Avid Editor
  • Fri, May 30 2008 7:37 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,169
    • Points 73,620
    Re: Video Input Tool
     I leave the video tool at proper levels for SMPTE bars, and use TBC adjustments on our Sony Betacam SX decks to tweak video going on (as seen on a waveform monitor) as best I can, and then do final finessing using the color correction toolset.
  • Fri, May 30 2008 7:41 PM In reply to
    • Yasch
    • New York
    • Posts 37
    • Points 480
    Larry Rubin:
    Please excuse my ignorance on the topic... Your Betacam deck has it's own level adjustments?
    Yanky Ascher
  • Fri, May 30 2008 7:51 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,169
    • Points 73,620
     Yes indeed, all Professional Betacam decks, digi-beta, SX and SP have built in TBC's for adjustment of analog gain, set-up, chroma, and phase. Of course, this works for us because our flow in and out of the Avid platforms is still analog component. It's the one thing I really don't like about firewire and SDI, the absence of the ability to "pre-adjust" if you will, when video levels on tape are really wacked. An extra measure of flexibility.
  • Fri, May 30 2008 8:03 PM In reply to
    • Yasch
    • New York
    • Posts 37
    • Points 480
    We are going in analog as well, with a sony pvw-2800 betacam sp deck and a dsr-1500 DV. I'm unaware of any built in controls.
    Yanky Ascher
  • Fri, May 30 2008 8:33 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,169
    • Points 73,620
     It's been a while since I had my hands on one, but the PVW series does have TBC adjustments. If I remember correctly, they're behind the fold up panel with the transport controls. Or, if they're not there, the transport panel may pull out horizontally and reveal another panel of controls. Look for two small rack handles on the transport panel.
