Latest post Wed, Jun 4 2008 8:54 PM by CreativeControl. 13 replies.
Page 1 of 1 (14 items)
  • Fri, May 30 2008 6:23 PM
    • Rignold
    • Cape Town
    • Posts 75
    • Points 1,080
    AVID EX1 Support
    After catching a hint on the forums that 5.8.3 enables the use of EX1 35 mb/sec footage I gave it a try.
    IT WORKS JUST GREAT. It takes me about 30 secs to import +-70secs of footage! Once imported it looks good and considering it's HD, plays back off an external USB drive(500gig 7200rpm) just fine. Obviously a RAIDed setup will be much better.
    Some limitations on my machine: (and I'm not sure if a better faster machine will help)
    1. When playing back in full quality mode the effects all need to be rendered. (For me a minor issue)
    2. There is no Quicktime reference export due to the Long GOP footage.
    3.When exporting I exported as Uncompressed with Animation codec and the result is a very washed out image. I tried several other codecs including the AVID DNxHD one with the same result. Must still try transcoding within AVID and then exporting.
    4. The footage I worked with is 1080 25p which views nicely on my SD monitor once the project output is switched to Pal 25p.
    The workflow seems smooth to me and beats the cr@# out of FCP workflow so far.Yes Well done AVID!!!
    Asus P5K3 Deluxe Motherboard, Intel Core 2 Duo E6600 Conroe 2.4GHz, 4gig DDR3 1333mhz RAM, PNY Quadro FX1700(Driver 169.47), XFX GeForce 7900GT, QT 7.45... [view my complete system specs]
    Before you judge a man walk a mile in his shoes. After that who cares, you're a mile away and you've got his shoes.
  • Fri, May 30 2008 10:40 PM In reply to
    Re: AVID EX1 Support
    You mean except for the teeny weeny export problem. If QT Animation doesn't work then what does? I guess we all wait for MC 3.0 and hope it works well there
  • Mon, Jun 2 2008 3:18 PM In reply to
    • CreativeControl
    • Joined on Mon, Dec 10 2007
    • Edmonton, Alberta, Canada
    • Posts 122
    • Points 1,470
     That sounds great, I'll have to try it.
    Where do I find 5.8.3?  I can't seem to find it in the download center.
    2 MC3 systems, both Quad Core PC's. 4GB ram each. 1 NV7800GT and 1 8800GTS with Riva Tuner. WinXP 32. 2 Mojo's (non-sdi) with UVW1800's. [view my complete system specs]
  • Mon, Jun 2 2008 3:35 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,871
    • Points 175,795
    IT is in the DL center. You have to make sure that you are registered to get a password for access. The first page is not the actual DL page.
  • Mon, Jun 2 2008 3:45 PM In reply to
    • CreativeControl
    • Posts 122
    • Points 1,470
    Thanks!
  • Tue, Jun 3 2008 12:28 PM In reply to
    • Rignold
    • Cape Town
    • Posts 75
    • Points 1,080
    Rignold:
    I tried transcoding the clip in AVID to DNxHD 185 and then exporting a Quicktime Ref. This seems to work fine.
  • Wed, Jun 4 2008 2:56 PM In reply to
    • CreativeControl
    • Posts 122
    • Points 1,470
     I tried to register but there was no response.  I tried to email but no response.  It would appear (although it's not too clear on the page) that this is only for those with "maintenance contracts", is this true?  If not, I'll try again.
  • Wed, Jun 4 2008 3:05 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,871
    • Points 175,795
    How long ago CC?
    It is not only for Maintenance customers so, if it's been more than 4 days, email me with your name, company name, location and system ID and We;ll get it taken care  of.
  • Wed, Jun 4 2008 4:00 PM In reply to
    • CreativeControl
    • Posts 122
    • Points 1,470
     It's been two days so I'll hang in there and hope for a response.  If I don't hear from them I'll let you know, thanks so much for the help.
    I have an EX-1 and would like to use the feature.  In the past I've been using a utility to transcode to DNxHD but it's a bit slow.
    Thanks!
  • Wed, Jun 4 2008 4:30 PM In reply to
    • CreativeControl
    • Posts 122
    • Points 1,470
     They finally sent me this message:
    Dear Len,
    Go to the link below to register, then you will be
    able to request a Download Center Account.
    http://www.avid.com/download
    Kind Regards,
    Avid Technical Support
    Of course the link doesn't work.  Do you happen to have the real link?
  • Wed, Jun 4 2008 4:36 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,871
    • Points 175,795
    Hi Len,
    I think they mean avid.com/downloadcenter.
    Haven't you done  that registration already?
  • Wed, Jun 4 2008 4:46 PM In reply to
    • CreativeControl
    • Posts 122
    • Points 1,470
     Yes I have.  The reason I'm confused is that it asked for a product number that was under a maintenance contract (which appears to be manditory).  I have two seats of Xpress pro but no maintenance contract.  The registration would not complete without it.  I entered my product number anyway but haven't heard back.
  • Wed, Jun 4 2008 4:49 PM In reply to
    • CreativeControl
    • Posts 122
    • Points 1,470
     It seems to have been resolved.  They just sent the login and password.  Thanks for your help!
  • Wed, Jun 4 2008 8:54 PM In reply to
    • CreativeControl
    • Posts 122
    • Points 1,470
     I've installed 5.8.3 and I have to say it seems to work great!  I haven't tried all frame rates and resolutions yet but 1080 24p seems fine.
    Also, I noticed full screen playback on all projects seems much better.  Nice!
    Exporting sequences to DNxHD is probably the best workaround for the lack of long GOP support.
