Latest post Tue, Jun 3 2008 6:22 AM by belloman. 5 replies.
Page 1 of 1 (6 items)
  • Thu, May 29 2008 4:05 AM
    • belloman
    • Joined on Fri, Oct 14 2005
    • Posts 122
    • Points 1,525
    Importing 720p 30fps QT into PAL project
    Have just purchased a Panasonic Lumixd digital camera which also shoots HD 720p video at 30fps and recorded in Quicktime. Great little camera and great for those times when you don't have your big camera with you. So my plan was to then be able to drop any footage into a project I'm working on. However I'm in PAL land and so my timelines are at 25fps, so when I import the QT file into Avid the shots become jerky because of conversion to less fps.
    Does anyone know how I can get around this so the footage is smooth? If I create a project at 30fps and import the footage plays fine but my output timelines need to be at 25 fps.
    Pentium 4 2.8 1.5 GB ram Xpress Pro 4.6 DVCam 30P deck [view my complete system specs]
  • Fri, May 30 2008 12:05 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 2,736
    • Points 31,285
    Re: Importing 720p 30fps QT into PAL project
    I suppose you could convert the frame rate from 30 fps to 25 fps using Fluid Motion but you'd have to upgrade to Media Composer to be able to do this.
    MacPro, MacBook Pro and a Cube. The Cube doesn't do much but it looks cool. [view my complete system specs]
  • Fri, May 30 2008 6:23 AM In reply to
    If you ignore the sound and use the "ignoreqtrate true" console command, you will be able to import these files frame-by-frame into a 25 project. Then apply a motion effect.
    Symphony Nitris 3.0 on 2xquad core XW8400/4(??)GB | MC 3.0 on dual core XW8400/3GB | Mojo SDI | Unity Lanshare 4.23 fibre | MC 3.0 on MacBook 2.16/2.5GB... [view my complete system specs]
  • Fri, May 30 2008 8:22 AM In reply to
    Job ter Burg:
    You can split a wav file out of the QT and import the wave file into the PAL project. It will then marry up to the video after you have applied the motion FX.
    http://www.24p.com/conversion.htm  will lead you to some great info and there is a downloadable bin of Media Composer frame rate motion effects that you can open and use in a Pro project.
    DV Film's Atlantis 2 will perform the conversion of audio and video for you (at a price)
  • Tue, Jun 3 2008 6:15 AM In reply to
    • belloman
    • Posts 122
    • Points 1,525
    Sorry..been away for few days. Thanks for input and I am about to upgrade to Composer, but how does using Motion Effect smooth out the movement. If frames have gone (5 every second) how can they be replaced?
  • Tue, Jun 3 2008 6:22 AM In reply to
    • belloman
    • Posts 122
    • Points 1,525
    AndrewAction...thanks for that page. Good info.
