Latest post Mon, Jun 2 2008 2:35 AM by Ra-ey Saleh. 30 replies.
Page 3 of 3 (31 items) < Previous 1 2 3
  • Mon, Jun 2 2008 2:35 AM In reply to
    • Ra-ey Saleh
    • Sydney, Australia
    • Posts 290
    • Points 3,515
    Re: Unrendered Effects
    eddieb:
    Ra-ey Saleh:
    Can talk you through AvidFX if you need...
     Yes, Please!
    -  Just drop a, 'Avid FX 1 Input' onto your clip and open the Effects Editor.
    -  In your Comp window, you'll see a Layer called 'Video1'.  Click on the last icon on this Layer (V1) and a drop-down menu appears.  Select 'Still Image File'.  Navigate to your hi-res image and load.  Now use your Position controls and keyframe away.
    -  Be careful, the keyframes don't work identically to the way they do in the Avid, so you might need to experiment a little (i.e. although you can 'copy' a keyframe, you can't paste...  Have no idea why).
    -  Also, to avoid any fine-line aliasing on the final product, go into EDIT Menu > Project Settings... and turn on '1:2:1 Deflickering'.
    Hope this helps, like I said, can be 'quirky' but does the job...
    HP 8600 Symphony Nitris DX v3 Sapphire v2.07 Boris Continuum Complete v5.8 AvidFX (Boris Red) Heroglyth v2.6 Vitascene v1 Adrenaline (XP 8400)... [view my complete system specs]
    Ra-ey Q: "How many Editors does it take to change a lightbulb?" A: "Why do you want to change it?"
