Latest post Wed, Oct 22 2008 1:01 AM by malefunktion. 123 replies.
Page 6 of 9 (124 items) « First ... < Previous 4 5 6 7 8 Next > ... Last »
  • Sun, Jun 29 2008 1:39 AM In reply to
    • hhgross
    • Joined on Thu, Jun 26 2008
    • New York City
    • Posts 3
    • Points 45
    Re: Graphics Card Question
    using "force opengl 1.5" worked to keep avid from crashing on startup.  so you were right, I didn't need to softmod the 8800gt.  Now I'm trying to figure out how to get Avid to recognize my audio card.  If I can do that, everything should be a go.  (Everything booted up fine with 3.0 otherwise, got video playback, so I'm almost in business)
    Intel Core 2 Quad Q6600 2.4Ghz 3 GB DDR2 800 (2x1GB, 2x512MB;) XFX GeForce 8800GT 512MB 300 GB HD (System) Windows Vista 32bit SP1 [view my complete system specs]
  • Sun, Jun 29 2008 3:14 PM In reply to
    • Pacific88
    • Joined on Wed, Apr 23 2008
    • Moscow
    • Posts 5
    • Points 55
    hhgross:
     i have same card.. installed on vista 64 biz version.. and cant run mc3.. hungs on startup.. if you will have some results post here tweaks please..
    btw on GF 7800 gtx  and xp sp2 system works very good.. but vista fails with 8800 GTX and 8800 GT ..
    8800 GTX i have tryed to emulate Quadro 4600 but it not works..
    so you told about opengl force.. how you did it?
    MC 2.8.3 Asus Maximus Formula, Intel Quad Core Q6600, nVidia GTX8800 768 MB, OCZ Platinium 6Gb [view my complete system specs]
  • Sun, Jun 29 2008 6:16 PM In reply to
    • dougd71
    • Posts 17
    • Points 305
    i've got an old version of riva tuner, but with a little digging, if this doesn't work you should be able to find it.  and don't forget your friend google.
    on the "Main" Riva Tuner menu, under "Driver Settings" hit "Customize"  select the "OpenGL" button.  go to the "compatability" tab.  select 1.5 from the OpenGL version string override.
    Asus P5Q Pro, Q9450 overclocked to 3.4Ghz, 4GB Ram, 4 Seagate ST3500320AS 500GB drives in Raid-0, P182 Case, Corsair 620HX PSU, MSI 8800 GTS 512MB, Vista64... [view my complete system specs]
  • Sun, Jun 29 2008 6:42 PM In reply to
    • Pacific88
    • Moscow
    • Posts 5
    • Points 55
    dougd71:
     ohh man.. it came alive! :)
    now will try on 8800 GTX
    thank you!
  • Mon, Jun 30 2008 12:59 AM In reply to
    • lalittle
    • Posts 173
    • Points 2,450
    dougd71:
    So as I understand it, you don't need to soft-mod a Geforce, you simply need to use the "force OpenGL 1.5" setting.
    On that note, is the "force 1.5" setting only a "Global" setting -- i.e. does it always effect everything, or can you set it to only force OpenGL 1.5 for a specific application (i.e. Avid MC3.0)?
    Also, does changing the "force OpenGL 1.5" setting require rebooting the system, or can you toggle it ON when you run Avid, and then toggle it back OFF again when you want to run other apps?  In other words, is this easy to turn on and off depending on whether or not you want to run Avid, or does it require extra rebooting time?
    On a related note, does anyone know if Avid utilizes any of the "newer" OpenGL capabilities from OpenGL versions after 1.5?  I'm wondering if using the legacy "force 1.5" mode has any effect on Avid, and if so, if it's simply a matter of slower performance in some areas, or if it might actually "break" something or limit functionality.
    Thanks for all the feedback on this,
    Larry
  • Mon, Jun 30 2008 6:12 AM In reply to
    • dougd71
    • Posts 17
    • Points 305
    excellent!  please report back on how it works on your 8800GTX!
    sorry lalittle, i don't know the answers to your questions.
  • Mon, Jun 30 2008 9:18 AM In reply to
    • Pacific88
    • Moscow
    • Posts 5
    • Points 55
    dougd71:
     yep! 8800 GTX  works too...
  • Mon, Jun 30 2008 10:42 AM In reply to
    • lalittle
    • Posts 173
    • Points 2,450
    dougd71:
     Do you remember if applying the "force OpenGL 1.5" setting required a reboot?
    Pacific88 -- what happened when you applied the "force 1.5" setting in Rivatuner?  Does it require a reboot, or are you able to simply toggle it on/off anytime you start/stop running Avid?
    Larry
  • Tue, Jul 1 2008 3:38 AM In reply to
    • TommyAF
    • Joined on Fri, May 4 2007
    • Posts 47
    • Points 675
    Wow nice, thanks to that "force OpenGL 1.5" I was able to put my card back to it's original GeForce form.  One of the problems I had been having with my comp since the soft mod has been that I can't put it in hybernate mode because when I try to bring the computer back up the screen stays black.
    And Larry it doesn't require a reboot.
    Media Composer 3.0, Windows Vista Ultimate, Intel Core 2 Duo CPU T7800 @ 2.60GHz, 3.00 GB RAM (Should be 4?), NVIDIA GeForce 8400M GT [view my complete system specs]
  • Tue, Jul 1 2008 10:28 AM In reply to
    • lalittle
    • Posts 173
    • Points 2,450
    TommyAF:
    That's good news -- thanks for the report.
    I wonder if any functionality is missing or limited when using this setting.  It would be interesting to hear if Avid uses any OpenGL features specific to versions after 1.5.  If anyone has any information on this, please let us know.
    Larry
  • Thu, Jul 3 2008 12:41 AM In reply to
    • TerryO
    • Joined on Mon, Oct 24 2005
    • Oslo, Norway
    • Posts 75
    • Points 845
    TommyAF:
    I have the same GeForce 8400 M GS graphics card as TommyAf on my brand new laptop, and I can confirm that I didn't need to do the "Quadro mod" (i tried, but then the playback went away). Only the "Open GL 1.5" setting was sufficient.
    Thanx guys!
    Work machines: 5 Avid Media Composer Adrenaline version 2.8.3 / 3.0 Avid built HP machines 3 GB RAM, Dual Xeon processor 3,2 GB 1 Avid Symphony Nitris... [view my complete system specs]
  • Sun, Jul 6 2008 6:26 PM In reply to
    Hi everyone,
    I tried so many things that I'm a bit lost... These are my specs :
    - CPU: Intel Core2Quad Q6600
    - GPU: nVidia GeForce 8800 GTS 320 Mb
    - OS: Windows Vista Home premium 32 bits
    So, I soft-moded it into a Quatro FX4600 and downgraded OpenGL to v1.5 using RivaTuner. I can launch Avid MC 3.0 but have no video playback.
    I'm using nVidia forceware 169.25... Maybe it's too recent for MC 3.0 so do you know if there's a qualified version for MC 3.0 (and where I could download it)? I searched the whole Avid website, unsucessfully.
    Subsidiary question: I'm using two different screens. An old 1024*768 one and an other in 1440*960. According to you, may that difference cause troubles?
    Thanks a lot for your answers,
    Julien
    [PS: I really apologize if my English doesn't sounds good, as it is not my native language ^^]
    CPU: Intel Core2Quad Q6600 ; GPU: nVidia GeForce GTS8800 320 Mb ; OS: Windows Vista Home premium 32 bits ; HDD: 2*500 Gb [view my complete system specs]
    Julien
  • Sun, Jul 6 2008 7:27 PM In reply to
    • Pacific88
    • Moscow
    • Posts 5
    • Points 55
     Julien
    try to do this steps:
    1. do not soft mode (recall back making changes in rivatuner)
    2. just use 1.5 option in opengl (rivatuner)
    3. if it not helps then change home version of vista to biz
    to my mind home vista is reason of your failure
  • Sun, Jul 6 2008 9:01 PM In reply to
    Well, if don't softmod the GPU, MediaComp just fails while loading (on the ACPL)... so I guess you're right about Vista HP.
    Sometimes I just wonder about buying an OEM XP Pro......
    Thanks for your help.
    Julien
  • Sun, Jul 6 2008 9:32 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,013
    • Points 71,730
     Here's a link to XP Pro, SP 2.
