Latest post Tue, Sep 30 2008 10:05 AM by tom_e. 118 replies.
Page 5 of 8 (119 items) « First ... < Previous 3 4 5 6 7 Next > ... Last »
  • Fri, Jun 20 2008 7:43 PM In reply to
    Re: Graphics Card Question
    TommyAF:
    Success!
    I ended up taking the plunge and ordering my software yesterday, and I was amazed to get it today.  Installed the program, and as I expected it wouldn't run on my native GeForce card.  I soft modded it into a Quadro NVS 290 and presto!  Everything appears to be working great now.  Thanks for all your help guys I definitely could not have done this without you!
    Does modding it into a Quadro cause it to act like a "true" Quadro in the sense that it loses performance in other (non OGL) areas?
    Intel Core 2 Duo E6750 2.66Ghz 3 GB Crucial Ballistix DDR2 800 (2x1GB, 2x512MB;) XFX GeForce 8800GT 512MB 250 GB Seagate HD (System) 3x500 GB Western Digital... [view my complete system specs]
  • Sat, Jun 21 2008 10:25 PM In reply to
    • TommyAF
    • Joined on Fri, May 4 2007
    • Posts 47
    • Points 675
    Steeldestroyer:
    I honestly have no idea.
    Media Composer 3.0, Windows Vista Ultimate, Intel Core 2 Duo CPU T7800 @ 2.60GHz, 3.00 GB RAM (Should be 4?), NVIDIA GeForce 8400M GT [view my complete system specs]
  • Mon, Jun 23 2008 8:27 PM In reply to
    • lalittle
    • Posts 173
    • Points 2,450
     Has anyone here tried the "512MB" version of the GF 8800GTS?  I know that this card uses the G92 chipset rather than the G80 chipset found on the 320MB and 640MB version of the 8800GTS, and since I don't see a "G92" version of Quadro cards (I only see "NV92" Quadros), it appears that this card might have to work natively with MC3.0 in order to work.  I've seen several 8800GTS posts, but as far as I can tell, none were the "512" version.
    I know that teh GF7xxx series works natively with MC3, so I'm curious if the G92 version of the 8800 (8800GTS 512MB) might also work.
    Larry
  • Tue, Jun 24 2008 11:58 AM In reply to
    • lalittle
    • Posts 173
    • Points 2,450
     New Geforce drivers were released yesterday (Monday, June 23) -- 175.19.  I was curious if anyone had tried them with an 8800 series card to see if the newer drivers fixed the issues that currently require soft modding 8800's to Quadros.
    Larry
  • Wed, Jun 25 2008 5:28 AM In reply to
    • raspago
    • FL, USA
    • Posts 826
    • Points 10,275
    .- Running 3.0 succesfully with a GeForce 6800GT (no, is not a typo, an old 6800GT)  softmodded to a quadro FX1400.
    Full screen and everything, using the Avid approved drivers.
    Custom made Intel core 2 duo 2.4 (overclocked to 3.0) Nvidia 8800GS, 3GB Ecc Ram, E-MU 1212M Sound card, Sata Drives, Analog Mojo. [view my complete system specs]
  • Thu, Jun 26 2008 3:33 AM In reply to
    • hhgross
    • Joined on Thu, Jun 26 2008
    • New York City
    • Posts 3
    • Points 45
    Running Vista 32 with an 8800gt, had the same hangup during avid startup on the acpl screen, unable to softmod as it's a G92 chip (and rivatuner doesn't support any of the G9X chips).  Updated today with the newest Geforce drivers and the problem persists.  Still waiting for some kind of solution so I can start using 3.0.
    Intel Core 2 Quad Q6600 2.4Ghz 3 GB DDR2 800 (2x1GB, 2x512MB;) XFX GeForce 8800GT 512MB 300 GB HD (System) Windows Vista 32bit SP1 [view my complete system specs]
  • Thu, Jun 26 2008 5:35 AM In reply to
    • lalittle
    • Posts 173
    • Points 2,450
    hhgross:
    Thanks for posting -- I was wondering about the G92 chipset cards, so your post was helpful.
    I'm wondering if a decent workaround would be to just install two cards in the system at the same time -- i.e. the 8800 and a lower end Quadro -- and just disable the 8800 when running Avid.  In other words, use the Device manager to select "Do not use this device (disable)" for the Geforce card.  This way, you'd have a less expensive Quadro for Avid without the Geforce interfering, and you'd still have the much higher power of the Geforce for everything else.
    I'd be very interested to hear If anyone has any thoughts on this.  A similar discussion was started a while back, but it was dropped because MC 2.8.3 ended up working with Geforce cards.
    Larry
  • Thu, Jun 26 2008 9:22 AM In reply to
    • daveswan
    • London, UK
    • Posts 187
    • Points 2,355
     Running on a non-qualified laptop with an old GeForce 7800 GO, very happily running two monitors, playing full screen on one with source / record on the other, full res DVCPro HD, not a stutter.
    Very chuffed,
    Dave
    MESH P4 3.0 GHz, 1.5 GB PC 3200 DDR RAM, 160 GB system disk, 250 GB media disk, SoundBlaster Audigy zx platinum, nVidia FX 5700/250MB. Xpress pro HD 5... [view my complete system specs]
  • Fri, Jun 27 2008 6:47 PM In reply to
    • siddallj
    • Joined on Fri, Jun 27 2008
    • UK
    • Posts 1
    • Points 15
    Could you tell me how to soft mod the 8800gt ?
    Im tryin to run Avid MC 3.0 software
    Machine spec:
    IP35 motherboard
    4GB Ram
    Q6600 CPU
    Nvidia 8800GT
    Sound Card: Edirol FA101
    Windows XP 32 sp3, Abit IP35 motherboard, 4GB Ram, Q6600 cpu, 500gb raid 0 HD, Nvidia 8800GT,Driver Forceware 175.19 June 2008 [view my complete system specs]
  • Fri, Jun 27 2008 8:03 PM In reply to
    • AquaPix
    • Joined on Sat, Sep 16 2006
    • UK
    • Posts 389
    • Points 4,795
     Hi siddallj,
    I suggest that you read through the entire thread and then download RivaTuner.
    MC3.0, QT7.4.5, Vista Business x64, Intel Quad Core Q6600 @ 3.4GHz, Asus P5K Mobo (FSB 1500MHz), 8GB RAM (OCZ Reaper @ 950MHz DDR II), GeForce 8800GTX... [view my complete system specs]
  • Sat, Jun 28 2008 3:05 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,337
    • Points 38,410
    I think that Baklap said that he was using an 8800 as a Quadro.
  • Sat, Jun 28 2008 7:14 AM In reply to
    • dougd71
    • Posts 17
    • Points 305
    I believe the Quadro FX 3700 uses the G92.  http://en.wikipedia.org/wiki/Nvidia_quadro and http://ads-spot.com/nvidia-launches-quadro-fx-3700.html
    And looking over the specs for Rivatuner, it should support the G92s and up to 175.12...have i misread?  i sure hope not cause i;ve got a brand new 512 mb 8800GTS (G92) sitting here waiting for my Avid upgrade to 3.0 sometime very soon.
    Asus P5Q Pro, Q9450 overclocked to 3.4Ghz, 4GB Ram, 4 Seagate ST3500320AS 500GB drives in Raid-0, P182 Case, Corsair 620HX PSU, MSI 8800 GTS 512MB, Vista64... [view my complete system specs]
  • Sat, Jun 28 2008 10:05 PM In reply to
    • lalittle
    • Posts 173
    • Points 2,450
    dougd71:
    On this note, I'm a bit unclear about the chipset information on the techarp site.  The 8800GTS 512 is listed as "G92," but the FX3700 is listed as "NV92GL."  Is this the same as the "G92," which the wiki article obviously implies, or are there some differences?
    Larry
  • Sat, Jun 28 2008 10:21 PM In reply to
    • hhgross
    • New York City
    • Posts 3
    • Points 45
    In my experience so far with trying to softmod the 8800gt, the problem is within rivatuner.  There is no NVstrap tab within the quick modification area, thus no way of sofmodding the 8800gt to the 3700fx.  I know within the rivatuner documentation it says that the G92 chipset is supported, but within other forums on the guru3d site, the rivatuner moderator has explicitly said that as of right now softmodding on an 8800gt is not supported by rivatuner.  This has been my experience, and unless someone has other information on a workaround, there's no way for me to softmod the 8800gt using rivatuner.
  • Sat, Jun 28 2008 10:54 PM In reply to
    • dougd71
    • Posts 17
    • Points 305
    after posting last night i did some research, and you're correct.  there's no way to mod a 8800GTS into a Quadro.  but is that necessary to get avid to work?  it seems from the other posts, that all that's required is using riva tuner to force OpenGL 1.5.  is this correct?
    and which will offer better performance.  an 8800GT soft moded to a Quadro or an umodded 8800GTS or 9800GTX?
