Latest post Thu, Aug 7 2008 10:48 AM by BobbyMurcerFan. 8 replies.
Page 1 of 1 (9 items)
  • Wed, May 28 2008 10:13 PM
    • Glans
    • Sweden
    • Posts 192
    • Points 2,735
    Full screen working... then not working - mystery
     I just worked with my project and hit ctrl-shift-f for full screen and it worked smooth and perfect. Then I shut down MC going for lunch and coming back I started it again and then when I hit ctrl-shift-f I get this message:
    "Full screen playback is not supported on this system"
    Followed by a comment on going to avid.com/support for a list of supported graphic cards where mine is on.
    What happend? Why does it play and then don't without any settings whatsoever changed?
    * Pentium D 950 3,4 Ghz - 3GB DDRII RAM - Geforce 7800 GTX 256 * Intel Core 2 Quadcore 2,5 GHz (Q9300 6mb Cache) - 4GB RAM - Geforce 8800GTX 512mb... [view my complete system specs]
    * Intel Core 2 Quadcore 2,5 GHz (Q9300 6mb Cache) - 4GB RAM - Geforce 8800GTX 512mb - Laptop
    * Avid Media Composer  3.5.4
  • Wed, May 28 2008 10:22 PM In reply to
    • AquaPix
    • Joined on Sat, Sep 16 2006
    • UK
    • Posts 447
    • Points 5,555
    Re: Full screen working... then not working - mystery
     I had the same problem when I was still using my GT7900GFX card. A few times, out of the blue FSP wouldn't work.
    Re-installing the nVidia driver solved the problem. I suggest you do the same and see if that gives you back FSP.
    Hope this helps, good luck.
    MC3.0.5, QT7.4.5, Vista Business x64, Intel Quad Core Q6600 @ 3.4GHz, Asus P5K Mobo, 8GB RAM (OCZ Reaper @ 950MHz DDR II), GeForce 8800GTX (multithreading... [view my complete system specs]
     Andy Lange www.aquapix.tv
  • Wed, May 28 2008 10:24 PM In reply to
    • Glans
    • Sweden
    • Posts 192
    • Points 2,735
     Seems like an odd thing to do when I haven't touched the settings of the video card Hmm
  • Wed, May 28 2008 11:06 PM In reply to
    • AquaPix
    • UK
    • Posts 447
    • Points 5,555
     I know what you mean. It is really random. Since I have switched to a supported GFX card and using the nVidia driver quoted in my AXP/MC readme, it never occurred again.
  • Wed, May 28 2008 11:30 PM In reply to
    • DIESELE
    • Joined on Mon, Apr 28 2008
    • Cymru/Wales
    • Posts 326
    • Points 3,975
    I've had this randomly several times recently since moving to MC 2.8.1.  I've just changed the faulty Quadro 1500 GFX card however and hope its banished.  I have same base sytem, gfx card and driver as you Andy (funny that ;) )
    D
    Panasonic HPX301 P2 Camcarder (sic!), MC 4.0.3, Vista 64 SP2, Asus P5K-E Mobo, Q6600 Dual Quad Core @ 2.4Ghz (3.0 Ghz if I'm up against it!), 8Gb 800Mhz RAM Dual channel, C: Raptor (can you hear it?!) Media: 4 x 500Gb SATA Stripe O pairs, P2 archive E-Sata WD x 4, Quadro FX 1500 GFX, Soundblaster Audigy, Mojo SDi.  Sony PVM CRT.  Approved Avid HP 8240 Notebook.
    VIDEO PRODUCTION SOUTH WALES CRACKING PRODUCTIONS
  • Thu, May 29 2008 12:12 AM In reply to
    I've experienced the same problem several times before as well. After several times, I realized it only happened when an item called "AvidSDMService.exe" was running in the "Processes" tab of the Windows Task Manager before I opened Avid. Now I simply check the processes in the task manager before I open Avid, and if that *.exe is open I end the process and then run Avid, and FSP has worked everytime.
    Hope this helps!
    -Matt
    Avid Xpress Pro 5.8, Avid Studio Toolkit 5.7, Protools 7.4 with DV Toolkit 2, Dell Precision 380, Pentium D 3.0GHz processor, 4GB RAM, nVidia Quadro FX... [view my complete system specs]
  • Thu, May 29 2008 10:53 AM In reply to
    • Glans
    • Sweden
    • Posts 192
    • Points 2,735
     So... what is "AvidSDMService.exe"? I end processes all the time, but only when I know what it is.
  • Thu, May 29 2008 2:18 PM In reply to
    • camoscato
    • Posts 6,089
    • Points 73,015
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Glans:
    You found a link to a Media Composer supported video card list with a GeForce card on it?  Could you link to it please?
    thanks,
    Carl
    MC 3.5.4, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 4 GB RAM, nVidia GeForce 7150M, Conexant HD Audio, G-tech 500GB G-drive [view my complete system specs]
  • Thu, Aug 7 2008 10:48 AM In reply to
    Glans:
    I'd love to know as well. My Quadro FX1100 only does full screen playback when AvidSDMService.exe is not running.
    BTW, you don't have to keep on ending process, you can right click on My Computer, choose Manage, choose Services and Applications, choose Services, double click on AvidSDMService, press Stop and change Startup type to either Manual or Disabled.
    P4 3.0. 4 Gig RAM, CAS 2.0. 3Gig patch. Intel 865PERL mobo. Two WD 7,200 IDE drives. SIIG SATA II-150 PCI RAID card w/ 2 WD Raptor 10,000 SATA drives as... [view my complete system specs]
