Latest post Wed, Jul 2 2008 1:56 PM by ED-it. 10 replies.
Page 1 of 1 (11 items)
  • Wed, May 28 2008 6:17 PM
    • jtr
    • Joined on Wed, May 28 2008
    • Posts 3
    • Points 45
    Marquee - title and shapes not saving/rendering correctly
    I need some help with Marquee. Every once in a while when I am working with titles, I type the words (or create the shapes) and place and move them around on the screen. Everything looks fine. But when I exit and save the title to the Bin the saved file is distorted....some of the words are various levels of opacity, some are fine. If I re-load it and make any sort of saveable changes (for example moving the text or adding spaces) the problem areas change but are still there.
    I'm really stumped. It seems like a bug, anyone have any ideas of a fix?
  • Wed, May 28 2008 11:50 PM In reply to
    • sverkalo
    • Thessaloniki Greece
    • Posts 3,621
    • Points 44,080
    Re: Marquee - title and shapes not saving/rendering correctly
    When you export it within a video file does it seems distorted?
    Otherwise might be the VGA as well.
    Armor 8000/Zalman 600W/Abit IP35 Pro/Quad 6600/4G OCZ DDR2 800/Sapphire 1950GT 512(8.4)/X-Fi Xtreme Music/250 Hitachi SATA/2x500 WD SATA 2(RAID 0)/Samsung HD103UJ 1TB(e-SATA)/Seagate 500(USB2)/Optiarc 7203S/Optiarc 7200S/XP ProSP2/Liquid 7.2(4296).
  • Thu, May 29 2008 1:42 PM In reply to
    • jtr
    • Posts 3
    • Points 45
     Not sure what you mean "export it within a video file".
    When I am creating the title in Marquee it looks 100% perfect, but once I play the file back in the timeline or from the bin portions of it are distorted.
    It only happens occasionally and it seems the more separate objects I have on the screen (separate text boxes) the more prone it is to happening.
    Does that help?
  • Thu, May 29 2008 5:24 PM In reply to
    • sverkalo
    • Posts 3,621
    • Points 44,080
    When you export as QT file for example the titles are distorted or only at screen???
  • Thu, May 29 2008 5:38 PM In reply to
    • camoscato
    • Posts 4,647
    • Points 55,425
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    jtr:
    Corrupt user settings can cause weird stuff like that.  Try creating a new user and see if the problem is still there.
    Good luck,
    Carl
  • Fri, May 30 2008 2:51 AM In reply to
    • Chad
    • Joined on Fri, Oct 14 2005
    • Sydney, Australia
    • Posts 95
    • Points 1,100
    In Marquee, have you set the bit depth in Render > Options from 8 to 16?
    I've had similar issues in the past - and this fixed it.
    Avid MCA 2.7.7 on WinXP Sp2 HPxw8400 with 3GB Ram [view my complete system specs]
    Filed under: , , ,
  • Fri, May 30 2008 12:04 PM In reply to
     I'm experiencing exactly the same issue. I tried setting the render options from 8 to 16, and there was no change in my case.  What I have noticed is that this happens at random - every time you resave the title, something else's opacity changes
    Avid Media Composer Adrenaline 3.0 HP xw8200 4GB RAM nVidia FX 1400 WinXP SP2 1 x 1.2TB Avid VideoRAID 5-drive config ****** Avid Media Composer... [view my complete system specs]
  • Fri, May 30 2008 1:25 PM In reply to
    • jakeheat
    • Joined on Sun, Sep 3 2006
    • Posts 57
    • Points 700
    I've had this too.  I find it only happens with 2D titles within a 3D layer.
    Try moving the title a little bit forward ie: change it's Z position to 0.1.
    Or else extruding the text a little can help - thus giving it a little weight.
    SYMPHONY NITRIS 3.0 HP xw8400 ADRENALINE 3.0 PC HP xw8400 MC SOFT 3.0 PC HP xw8400 -& MacPro 3Ghz Quad 10.5.2 and MacPro Quad 3Ghz 10.5.2 Unity 5.x [view my complete system specs]
  • Fri, May 30 2008 1:44 PM In reply to
    • jtr
    • Posts 3
    • Points 45
     Thanks everyone for your help.
    I changed it from 8 to 16 Bit and that fixed it and seems to be working fine.
    Thanks again!
  • Fri, May 30 2008 1:46 PM In reply to
     Thanks for this.  Just tried it and it does seem to improve a little.  In my case I'm probably better off just doing a new title altogether, I've noticed that the quality of the adjusted title does seem to deteriorate in that it starts to look jagged around the edges.
  • Wed, Jul 2 2008 1:56 PM In reply to
    • ED-it
    • Joined on Tue, Jun 17 2008
    • Posts 1
    • Points 5
     Hey, thanks for the bit depth tip. I was ready to burn my Marquee until I read your solution… and I mean with a match and not to disc.
    I’m a new user on the whole Avid scene, so this helps out loads.
