Latest post Tue, May 27 2008 3:05 PM by Dom Q. Silverio. 6 replies.
Page 1 of 1 (7 items)
  • Mon, May 26 2008 9:58 PM
    • babyblue
    • Joined on Fri, Oct 5 2007
    • Rio de Janeiro Brazil
    • Posts 58
    • Points 755
    Compression Issue
     Maybe someone can explan.
    DV25 compression 4:1:1
    DV50 compression 4:2:2
    HDCAM SR compression 4:4:4
    What about NTSC betacam?
    Many thanks
    Allan
    MC 3.0 - Pentium quad core, 8 gbytes memory, MSI 9800 VIDEO BOARD, 4 SAT-3 HARD DISC(750GBYTES EACH), AUDIO CONTROLLER, IDT high definition audio codec... [view my complete system specs]
  • Mon, May 26 2008 10:05 PM In reply to
    Re: Compression Issue
    "What about NTSC betacam?"
    Also 4:2:2.  Was there another question here?  These values aren't compression.  They are the sample rates applied to the various video components.
  • Mon, May 26 2008 10:40 PM In reply to
    • sverkalo
    • Thessaloniki Greece
    • Posts 3,621
    • Points 44,080
    They are compressions. Because all of those formats are compressed.
    As the values approach the 1:1 ratio they are better in terms of image quality.
    Just a small reading
    This explains about color-chroma subsampling
    Armor 8000/Zalman 600W/Abit IP35 Pro/Quad 6600/4G OCZ DDR2 800/Sapphire 1950GT 512(8.4)/X-Fi Xtreme Music/250 Hitachi SATA/2x500 WD SATA 2(RAID 0)/Samsung HD103UJ 1TB(e-SATA)/Seagate 500(USB2)/Optiarc 7203S/Optiarc 7200S/XP ProSP2/Liquid 7.2(4296).
  • Tue, May 27 2008 3:59 AM In reply to
     actually you are both right. I think he meant 5:1 vs 15:1 etc as more traditional descriptions as opposed to color etc. But i wonder what the actual question from the post is?
    HP XW8400 Dual, Dual Core; 4 TB Dulce RAID 5; 3GB Ram; XPRO (latest version); AJHD 1400; HP XW8400 Dual, Dual Core; 7 TB G-TECH RAID 5 (2 encl); 3GB... [view my complete system specs]
    Eating is a moral act. If you eat meat from factory farms, you partake in a system of cruelty, violence and evil. Always take sides. To be passive empowers the oppressor.
  • Tue, May 27 2008 2:28 PM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,457
    • Points 39,975
    Well, whatever the question is,
    babyblue:
    is only true if you're working in NTSC.  In PAL it's 4:2:0 and DVCpro 25 is 4:1:1.  Since you don't say where you are the clarification may be necessary.
  • Tue, May 27 2008 2:53 PM In reply to
    • sverkalo
    • Posts 3,621
    • Points 44,080
    I really don't like those questions at which the OP disappears.
  • Tue, May 27 2008 3:05 PM In reply to
    babyblue:
    You are stating color sampling. This refers to the color accuracy not the actual compression ratio of a particular codec.
    babyblue:
    Since Betacam is an analog format there is no compression per se. Compression as stated here is a digital concept. Basically, compression is the process in which information is discarded (usually but not always 'redundant' information) in order to reduce the size of a given data stream.
    Betacam and other analog formats (like casette tapes, 8 track, VHS, etc) quality is measure dthrough analog parameters like bandwidth.
