Latest post Sun, May 25 2008 10:56 PM by cbezeike. 5 replies.
Page 1 of 1 (6 items)
  • Sun, May 25 2008 6:41 PM
    • cbezeike
    • Toronto
    • Posts 71
    • Points 935
    Unable to Import.mov file with Alpha Channel
    I have an quicktime file that I'm 100% sure has Alpha chanel on it. I used it recently in FCP and in Avid about 4 yrs ago.
    However the clip is opaque everytime I import it into avid. I've inverted the channel in Import Settings still nothing. Am I missing a ste?
    Software: Avid Xpress Pro HD 5.5.3 (no Mojo), CPU: Intel P-4 930 3.0Ghz Dual Core, Memory: 2G, 1 160 GB Sata/1 320 GB Sata, Motherboard: Asus p5B Deluxe... [view my complete system specs]
  • Sun, May 25 2008 9:40 PM In reply to
    • camoscato
    • Posts 4,647
    • Points 55,425
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: Unable to Import.mov file with Alpha Channel
    What version of Quicktime is on your system?  It should be 7.1.  If it is, what else can you tell us about the file?
    good luck,
    Carl
  • Sun, May 25 2008 9:51 PM In reply to
    • cbezeike
    • Toronto
    • Posts 71
    • Points 935
    I have 7.1.3. on my system.
    It's a .mov video of black spots (like old film effect). Basically I want to make a clip black & white and put the black spots on it. The background is black but it has Alpha chanel on it.
    I'm not sure what other details I can tell you about the file. It's strange cos the file has been untampered with.
    Let's assume I didn't import it properly can you pls give me a 101 on how to import? thanks.
  • Sun, May 25 2008 9:56 PM In reply to
    • camoscato
    • Posts 4,647
    • Points 55,425
      Moderator: Meridien
    If you've tried Use Existing and Invert Existing under the Alpha Channel settings, there's not much else I can tell you except that maybe the file doesn't have an alpha channel.  You're certain it does, though, so I'm stuck.
    Is it a Quicktime file?  AVI?  Something else?
    good luck,
    Carl
  • Sun, May 25 2008 10:19 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,013
    • Points 71,730
     If the file doesn't have an alpha channel or the alpha is unusable, you could import it as a standard clip (ignore alpha) and apply a luminance key to it...you should be able to get acceptable results, given the nature of the material.
  • Sun, May 25 2008 10:56 PM In reply to
    • cbezeike
    • Toronto
    • Posts 71
    • Points 935
    Yeah it's a mystery.
    It's a quicktime file .mov file. 22.5MB size. I just used this for a project in FCP, no problem.
    I've had the file since around 2004 and have used it sparingly but it's unchanged.
    I will restart my system and see what happens.
