Latest post Thu, May 29 2008 6:50 PM by mastermidnight. 7 replies.
  • Sat, May 24 2008 7:38 PM
    P2 crashing
    I am having some P2 importing and consolidating issues.  First, when I try to import using the current workflow, I get this message:
    Assertion failed: mediaDirs
    File: /Snapshots/releng.relengintel2_1196644544/vobs/coresw/ame/Projects/Mac/ ../ ../ ../ ../ppg/ame/msm/msmUtils.c, Line:387
    When I looked it up in the knowledge base, it suggested importing the old way via drop and drag using the media tool.  This works somewhat, but I'm always loosing my 1st track of audio and when I consolidate to another drive, it freeze crashes the computer.
    Any suggestions?  I'm going to try re-installing the software and see if that helps.
    Quad Core 3 gHz Intel / 3 GB RAM / OS 10.4.11 [view my complete system specs]
  • Sun, May 25 2008 1:43 AM In reply to
    Re: P2 crashing
    re-instal didn't fix the problem, but I think unmounting the G-Drive Q's I had connected and were using to consolidate to were the issue.  Has anyone run into this?
  • Sun, May 25 2008 1:19 PM In reply to
    • BobRusso
    • Tewksbury, MA
    • Posts 455
    • Points 5,595
    Re: P2 crashing
    Are you importing from a P2 device or Virtual P2 card?
    Do you have any '/' or other wild characters in the name of the folder structure? This will cause the problem you're seeing.
    -- Bob Russo Applications Editor at Avid Technology
  • Tue, May 27 2008 8:00 AM In reply to
    Re: P2 crashing
    I am importing from a virtual p2 card and have discovered the problem is the g-tech G-Drive Q.  I copied all the media from the one drive onto another then unmounted the G-Drive Q and the AVID was happy.  Does anyone have a clue why a hard drive would cause the problem?
  • Tue, May 27 2008 5:03 PM In reply to
    • Bill Nelson
    • West Coast
    • Posts 519
    • Points 5,955
    Re: P2 crashing
    with the material existing on two separate databases with all the same names, I'd be confused as well. After transfer, dismount the P2 card, and off you'll go.  (for the most part)
    MC v3.0.5 thru SDI Mojo, OS 10.5.5, QT 7.5.5, on Intel G-5 Octo 2.8 w/8 gig RAM, 2Tb internal RAID volume, 4TB CalDigit HDOne RAID, 30"Display, NVIDIA... [view my complete system specs]
  • Tue, May 27 2008 8:29 PM In reply to
    Re: P2 crashing
    That is the way I'm doing it.  There is only one folder I am transferring from, the other gets removed when I dismount the other drive and I didn't have two copies when I was having the problems.  It has something to do with the drive.
  • Wed, May 28 2008 5:23 PM In reply to
    • Bill Nelson
    • West Coast
    • Posts 519
    • Points 5,955
    Re: P2 crashing
    What's the formatting of the drive?  FAT32?
  • Thu, May 29 2008 6:50 PM In reply to
    Re: P2 crashing
    Nope, mac os extended.  I always re-format a new drive before using it.
