Latest post Tue, May 27 2008 6:17 PM by ratrat. 8 replies.
Page 1 of 1 (9 items)
  • Fri, May 23 2008 9:14 PM
    • ratrat
    • Joined on Sun, Jan 28 2007
    • Posts 16
    • Points 210
    Mpeg2 Export failing
     Everytime I try to export using the Mpeg2 export command (to eventually burn to a dvd) the command fails. ('Process failed check console').
    The console says the following:
    EDIT: MediaPos=0,MediaDur=6000,TrackPos=0,TrackDur=6000,SegRate=65536
    EDIT: MediaPos=6000,MediaDur=59900,TrackPos=6000,TrackDur=59900,SegRate=65536
    EDIT: MediaPos=65900,MediaDur=60100,TrackPos=65900,TrackDur=60100,SegRate=65536
    EDIT: MediaPos=126000,MediaDur=59900,TrackPos=126000,TrackDur=59900,SegRate=65536
    EDIT: MediaPos=185900,MediaDur=60100,TrackPos=185900,TrackDur=60100,SegRate=65536
    EDIT: MediaPos=246000,MediaDur=24200,TrackPos=246000,TrackDur=24200,SegRate=65536
    EDIT: MediaPos=270200,MediaDur=9800,TrackPos=270200,TrackDur=9800,SegRate=65536
    EDIT: MediaPos=280000,MediaDur=6000,TrackPos=280000,TrackDur=6000,SegRate=65536
        AS_Init() returned -1.
            Could not initialize Authorscript
    Does this make sense to anyone?
    thanks...
  • Sat, May 24 2008 1:10 AM In reply to
    Re: Mpeg2 Export failing
    ratrat:
    Yep... an oldie but goodie.
    You must be on XDV 3.5, right?
    The best thing you can do for yourself is to export as QTref, then encode that to MPEG-2 using a 3rd party encoder.  The issue you're having was so bad that Avid dropped the feature when they went to XpressPro (v4) and bundled 3rd party encoding software (Sorenson Squeeze) with the package.
    MacPro dual 2.66GHz 2GB RAM NVIDIA GeForce 7300 GT Storage: 2TB G-Speed eS with controller card 3x500GB Hitachi SATA-II internals various external... [view my complete system specs]
  • Sat, May 24 2008 7:15 AM In reply to
    • FunkyDragon
    • Boston MA
    • Posts 441
    • Points 5,195
    MC 3.0! HP nw9440 Laptop Mojo SDI Camera: DVX100A Deck: DSR 1500a [view my complete system specs]
     The FunkyDragon
    Happy Editing!
  • Sat, May 24 2008 7:26 AM In reply to
    FunkyDragon:
    BOOM!
    And how many times did we post that in the good ole days
  • Sat, May 24 2008 10:48 PM In reply to
    • FunkyDragon
    • Boston MA
    • Posts 441
    • Points 5,195
    no joke.  i ALMOST miss it.
    but not enough to do more than post a link.
     The FunkyDragon
    Happy Editing!
  • Sat, May 24 2008 11:07 PM In reply to
    • ratrat
    • Posts 16
    • Points 210
     Actually, i'm editing on Symphony. I've tried exporting as a QT ref & encoding in cleaner, but i get error messages about not finding the original file. Very frustrating. I just need to make dvd's. Any suggestions?
  • Sun, May 25 2008 12:21 AM In reply to
    If you go to http://community.avid.com/forums/t/997.aspx scroll down a few posts to one by Baklap "Everything you need to know, start here." Then down to "How to DVD?" you will find a wealth of detailed info.
    For me look at encoding with TMPGenc, ProCoder express or Cinemacraft Basic for the sub $70 range. I have and use all and all do excellent jobs
    Full ProCoder or Sorenson in the multiple hundred dollar range. I have both and ProCoder is IMO better than Sorenson.
    DVDLab Pro suits me for DVD authoring at the $200approx mark
  • Sun, May 25 2008 7:00 AM In reply to
    • FunkyDragon
    • Boston MA
    • Posts 441
    • Points 5,195
    or you can click on the link i provided....
     The FunkyDragon
    Happy Editing!
  • Tue, May 27 2008 6:17 PM In reply to
    • ratrat
    • Posts 16
    • Points 210
     Thanks for the links. I'll check them out & see if i can't resolve this situation!
