Latest post Fri, Jun 6 2008 11:58 AM by Sycophant. 23 replies.
Page 1 of 2 (24 items) 1 2 Next >
  • Fri, May 23 2008 2:52 PM
    • smanfredo
    • Joined on Sat, May 10 2008
    • Posts 22
    • Points 300
    Red Camera Workflow
    I'm about to start editing a project shot on red cam.  I'm following the steps laid out in http://www.studiodaily.com/studiomonthly/currentissue/9261.html.  I'm having trouble with the step where I create a quicktime (ref) in red alert and then batch import it into my media composer 2.8.3 after using metacheater to create an ale file.  Do I need a red cam codec for quicktime (I'm running QT 7.3.1)  The clip is just black after I import it.  I'm just stuck on this step.  I've tried using Red Cine to create a quicktime but that doesn't work either.  Any suggestions?  Thanks in advance.
    Steve
    MC 2.8.3, Mac Pro Quadcore 3.0, 5g ram, ATI X1900, Mojo [view my complete system specs]
  • Fri, May 23 2008 3:39 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,752
    • Points 174,300
    Re: Red Camera Workflow
    LEt me get Bob Russo in here to answer  this definitively. Be right Back.
  • Fri, May 23 2008 10:54 PM In reply to
    • BobRusso
    • Tewksbury, MA
    • Posts 413
    • Points 5,100
    You will need the RED codec without question. That's the only way to play the QuickTime Referance files. If they can play in QuickTime player, you have the codec installed.
    Take a look at this white paper also:
    <http://www.studiodaily.com/studiomonthly/currentissue/9261.html>
    -- Bob Russo Applications Editor at Avid Technology
  • Sat, May 24 2008 7:22 PM In reply to
    • smanfredo
    • Posts 22
    • Points 300
    thanks guys, was a simple codec problem.  One more quick thing- In that studio daily guide it says to create a qt ref from the r3d file- each folder though contains qt refs (f,h,m,p) along with the r3d which I've brought into the metacheater (the high version) and dumped out an ale file.  Is it a problem skipping that whole red alert step?  It just seems faster this way.
  • Sun, May 25 2008 6:48 AM In reply to
    • smanfredo
    • Posts 22
    • Points 300
    Having many problems importing audio.  I get an error importing quicktime audio so only the video gets imported.  I heard it could have something to do with the fact that the red cam takes in audio at 32 bit while the avid doesn't do more than 24.  Is there a solution to this?  I'm stumped.
  • Sun, May 25 2008 9:51 AM In reply to
    • rebusfilm
    • Malmo, Sweden
    • Posts 166
    • Points 2,165
    The Audio is 24 bit but padded to 32 bit for some reason.
    Convert the files with quicktime or compressor to 24 bit aif and import them into Avid.
    Then use AutoSync.
    iMac 24" 2.4 GHz Core 2 Duo| 3 GB RAM OSX 10.5.4 Avid Media Composer Software 3.0 Sony DSR-1500P JVC DTV1710 [view my complete system specs]
    Jorgen Persson
  • Sun, May 25 2008 10:55 PM In reply to
    • Sycophant
    • Auckland, New Zealand
    • Posts 771
    • Points 9,485
    I just completed a 48hour film on RED with Avid. Audio was the trickiest part, I had to create a Compressor droplet that would convert the audio from the RED QT files into AIF files that Avid would read.
    For the QT files for Metacheater, I have a simple shell script that uses REDline to create new proxy files for import all in one directory in the resolution I want.
    All manner of fancy edity stuff [view my complete system specs]
    Dylan Reeve - Editor and Stuff
    My opinions are my own.
  • Wed, May 28 2008 9:45 PM In reply to
    Surprised you had enough time left over after getting the RED footage in that you could still edit!  Stick out tongue
    Could you post that shell script?  That might come in handy for others.  It's annoying that the RED keeps each shot in a seperate folder, yet to import a bunch in MC, you'd like to have them all in the same place.
    MacPro Symphony Nitris DX (v3.0), MacPro MCA HD (v3.0), Mac Meridien (v12.1.2), Unity LanShare EX (v4.1.6) [view my complete system specs]
  • Wed, May 28 2008 9:56 PM In reply to
    • jasperfdo
    • Joined on Wed, Oct 11 2006
    • Los Angeles
    • Posts 535
    • Points 6,935
    Isn't all of this about to change next month as well?  I watched them use some type of RED software on MC 3.0 at the Avid event that was able to reference the proxy files and import right into Avid (I thought).  The Avid tech said June.
    Dell Precision 690, Intel 3.2GHz Dual Core Xeon (5060)4GB RAM, nVidia Quadro FX 3500 / Media Composer v3.0 / Mojo [view my complete system specs]
    kyler boudreau | www.theatereleven.com
    "Sometimes I wonder if men and women really suit each other. Perhaps they should live next door and just visit now and then. " - Katharine Hepburn
  • Wed, May 28 2008 9:58 PM In reply to
    • Sycophant
    • Posts 771
    • Points 9,485
    On the system we used the import time on the proxies to DV50 resolution (had to deliver on a DV tape, so HD wasn't going to benefit us) the import time was rought 2:1 so for the roughly 2 hours of footage we shot, the import time was 4 hours, over two imports (each about two hours) - and the one at 3am on Sunday was great as it gave me and the other editor some time to nap.
    The script I use is very simple:
    ----START make-qt.sh ----
    #!/bin/tcsh
    find "$1" -name "*_001.R3D" -print -exec /usr/sbin/REDline -i "{}" -w10 --useMeta --QTsize 2 --QTdir . \;
    ---- END ----
    So I create a directory call 'RED QT' or something, change to that directory (in the terminal) and then run the command:
    mac-pro:/Volumes/Media/RED QT user$ ~/make-qt.sh /Volumes/RedMedia
    In that case the shell script is in the user home directory. The drive with all my RED media is called 'RedMedia' and the drive I am on is 'Media' and I will be putting the files in the 'RED QT' directory.
    These files will not have audio on them. Only other thing to look at is the QTsize argument, which decides what proxy size you will be outputting. In this case 2 is Half (or 1024 from a 2K file, 2048 from a 4K)
  • Fri, May 30 2008 5:56 AM In reply to
    • smanfredo
    • Posts 22
    • Points 300
    When you guys are importing, after going through meta cheater, are you importing the H (high) qt ref or the F (full) qt ref.  Since I couldn't bring in the full version (it's all green) I'm bringing in the high which I figured was a high enough resolution but when I bring it in hd 1.1 10 bit it seem kind of compressed.  Am I just missing an codec in avid that would allow me to import the full version?
  • Fri, May 30 2008 6:28 AM In reply to
    • Svenbox
    • Germany
    • Posts 178
    • Points 2,170
    Importing is one thing. How do you guys get out again? Let's say if you want to cc the original footage on a DaVinci?
    MacPro 2.66 Quad, Mojo, MC 3.0.5 on 10.5.5, 4 Gb, 1.5 Tb int. [view my complete system specs]
    Wat soll dä Quatsch?
  • Fri, May 30 2008 12:11 PM In reply to
    • switthaus
    • Gwynn, VA
    • Posts 724
    • Points 9,450
    also, has anyone on this thread gone to "online", say on a DS or a box like that?  I have a Red gig coming up later this summer which will either go MC>>DS or FCP>>Smoke.  I really don't want to go FCP on this one so I am hoping that an MC offline and an HD finish in DS will be feasible.  Any tips and info appreciated as I am starting a notebook on this workflow
    sw
    Scott Witthaus Owner/Editor/Post Production Supervisor 1708 Editorial www.1708editorial.com
  • Sat, May 31 2008 12:03 AM In reply to
    • smanfredo
    • Posts 22
    • Points 300
    Does anyone know what the resolution of the High(H) qt ref is and if it's possible to import the Full (F) qt ref?
  • Mon, Jun 2 2008 1:22 PM In reply to
    • feeonac
    • Joined on Mon, Jun 2 2008
    • Posts 20
    • Points 300
    smanfredo:
    Hey
    I was thinking the same thing. I seem to be able to import the qt refs through metacheater. Do I need to use the red alert step? I can't actually seem to get red alert to export Qt refs? Also I'm quite new to AVID and don;t seem to have the option of import as DNxHD 36? Do I need to download a codec for this option or is it related to skipping the red alert step?
    Fiona
