Latest post Sat, May 24 2008 1:10 PM by DStone. 4 replies.
  • Fri, May 23 2008 1:59 PM
    • DStone
    • Massachusetts
    • Posts 2,065
    • Points 27,435
    Redcine and QT Timecode
    Since the last posts I've been able to find with Search are about a year old, what's the situation with this? Does Redcine still not pass timecode to the QT files? Is there a completely PC based workflow for dealing with offline/online editing and the Red?
    Dave S.
  • Fri, May 23 2008 2:43 PM In reply to
    • mattbennettedit
    • Joined on Fri, Mar 28 2008
    • Mt Tamborine, Australia
    • Posts 63
    • Points 775
    Re: Redcine and QT Timecode
    Michael P from Avid has come up with a workflow for Red, this is as of April 2008
    Check it out:
    http://www.studiodaily.com/studiomonthly/currentissue/9261.html
    MC3.0 Nitris DX, 8 x 3.0GHz Harpertown Mac Pro, 10GB Ram, MC3.0 Mojo, Macbook Pro 2.33GHz G-Tech 3TB speed-es, Caldigit 2TB VR [view my complete system specs]
  • Fri, May 23 2008 7:36 PM In reply to
    • DStone
    • Massachusetts
    • Posts 2,065
    • Points 27,435
    Thanks for the pointer, but I'm afraid it still doesn't help. This requires RedAlert, which only runs on the Mac. RedCine runs on the PC, and unless there's a version update out there that I haven't found, it doesn't incorporate the timecode into the QT file (so there's nothing there for Metacheater to extract).
    Dave S.
  • Sat, May 24 2008 5:04 AM In reply to
    • mattbennettedit
    • Posts 63
    • Points 775
    Ok, you might be better off checking out the Avid forum on the red user site.
    http://www.reduser.net/forum/forumdisplay.php?f=19
    Failing that maybe put in a question to Michael P here on the 24P forum.
    Let us know how you go as i'm sure others will be keen to know if you find a way around this on PC.
    Good luck!
    Matt
  • Sat, May 24 2008 1:10 PM In reply to
    • DStone
    • Massachusetts
    • Posts 2,065
    • Points 27,435
    OK thanks. I went over to the forums and found a couple of possible workflows. Thanks.
    Dave S.
