Latest post Fri, May 23 2008 12:24 PM by drortopper. 2 replies.
  • Fri, May 23 2008 7:18 AM
    capture from DV CAM
     hello,
    i use composer 2.7.2 without mojo. xp sp2.
    i try to capture from a mini DV CAM from sony.
    the computer is recognize the camera but the avid is not.
    i try to make achannel- firewire- ohci--generic (the camera is not on the list).
    autoconfiged is not working as well.
    what i need to do?
    Freedom
  • Fri, May 23 2008 10:05 AM In reply to
    • DIESELE
    • Joined on Mon, Apr 28 2008
    • Posts 106
    • Points 1,260
    Re: capture from DV CAM
     Just use the generic dv device setting - I'm sure it will work. D
    MC 3, XP SP2, Asus P5K-E Mobo, Quad Core 2.7Ghz CPU (3.0 Ghz if I'm up against it!), 4Gb 800Mhz RAM Dual channel, 4 x 500Gb SATA Stripe O pairs, Quadro FX 1500 GFX, Soundblaster Audigy.  Approved Avid HP 8240 Notebook. Original DIY PC: Shuttle SN85, AMD 3200, 1Gig Ram, Quadro 980, on board sound, on board firewire, 2 x SATA + WD ext HDD - could that be less 'compatible? Never hiccuped once! :-)
  • Fri, May 23 2008 12:24 PM In reply to
     i use the generic... it's not work.
    is this can be somthing in the system? i ask cause the xp recognize the cam but cant capture from it (movie maker)
    Freedom
