Latest post Thu, May 29 2008 1:55 AM by boltown. 9 replies.
Page 1 of 1 (10 items)
  • Fri, May 23 2008 2:39 AM
    • boltown
    • buenos aires
    • Posts 210
    • Points 2,535
    Conform XDCAM HD oflined in FCP into AVID?
    Hi, I have a client that is asking me to conform and online a show shot in XDCAM that he has offlined in a FCP, and I have some soubts about the workflow to folow.
    He told me that he has edited using DVCam Dubs from XDCAM discs. Is it possible to layout to a dv tape from XDCAM discs frame accurate?
    If he send me an EDL, will Avid relink to original MXFs from XDCAM?
    TIA, Agustin
    Intel 755xbx2 mobo Code 2 duo 2.2GHz 2GB RAM Quadro 550 Grapgic board Pyro DV Firewire board [view my complete system specs]
    www.wancamp.com.ar www.proeditor.org
    Filed under: , , ,
  • Fri, May 23 2008 10:52 AM In reply to
    • camoscato
    • Posts 4,647
    • Points 55,425
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: Conform XDCAM HD oflined in FCP into AVID?
    Assuming I'm reading this right, if the EDL is accurate and the DVCam dubs are accurate, then you shouldn't have any problems.  After importing the EDL you'd just have to batch capture the XDCAM material.
    I'm confused by "will Avid relink to original MXFs from XDCAM?"  If he's on FCP and you're on Media Composer, how is he getting you MXFs?
    good luck,
    Carl
  • Fri, May 23 2008 1:50 PM In reply to
    • boltown
    • buenos aires
    • Posts 210
    • Points 2,535
    camoscato:
    As I don´t have an xdcam deck, I´ll transfer all xdcam discs to an external drive  in another facility and import into avid.
    Is that the right way?
    thanks, agustin
  • Fri, May 23 2008 5:19 PM In reply to
    • bonang
    • Portland, OR
    • Posts 50
    • Points 680
    The right way to ingest XDCAM HD would be to rent a deck, and auto conform the EDL from FCP. By far the fastest way for your purpose.
    Avid Symphony Nitris 1.8.x Avid MC 2.8.x w/ mojo (desktop) Avid MC 2.8.x (laptop) Avid XPro HD (laptop) [view my complete system specs]
    Keith
  • Fri, May 23 2008 10:58 PM In reply to
    • boltown
    • buenos aires
    • Posts 210
    • Points 2,535
    bonang:
    Haven't worked with an XDCAM yet.
    Do I Have to capture via HD-SDI input, or the deck is connected via firewire?
  • Sat, May 24 2008 12:17 AM In reply to
    boltown:
    Look at the Sony PDW U1.  Attaches via USB and is a feeder for all XDCAM / XDCAM HD formats (allowing for the fact that EX is not XDCAM) via Batch import.
    Sometime in the next few weeks is will also operate like an external harddrive for archiving any computer file.
  • Mon, May 26 2008 12:44 AM In reply to
    • Sycophant
    • Auckland, New Zealand
    • Posts 771
    • Points 9,485
    Will Batch Import work with a sequence that was originated as a tape-based sequence to start with? It certainly didn't the last time I did an XDCAM job (which was more than a year ago).
    The workflow for file-based XDCAM conform used to require that the offline had been created file-based as well (so that the clips were recognised as being imported rather than captured media).
    All manner of fancy edity stuff [view my complete system specs]
    Dylan Reeve - Editor and Stuff
    My opinions are my own.
  • Wed, May 28 2008 9:04 PM In reply to
    • boltown
    • buenos aires
    • Posts 210
    • Points 2,535
    Sycophant:
    mmmmm, that's no good news!
    So is there any workaround to conform without an HD-SDI input?
    thanks for your replies,
    agustin
  • Wed, May 28 2008 9:09 PM In reply to
    • Sycophant
    • Posts 771
    • Points 9,485
    boltown:
    Sycophant:
    I'm only reporting my earlier memory of XDCAM workflow, I haven't used XDCAM for about 18 months, so it possible that things have changed since then. Or there might be a simple work around.
  • Thu, May 29 2008 1:55 AM In reply to
    • boltown
    • buenos aires
    • Posts 210
    • Points 2,535
    Thanks again Pycophant!
    Can anyone confim if it's possible to copy XDCAM disc mpeg 50 mbps files to and external Drive and then import into Avid MC
    Thanks!
    agustin
