Latest post Fri, May 23 2008 1:22 AM by sean90291. 2 replies.
  • Thu, May 22 2008 7:25 PM
    • sean90291
    • Joined on Fri, Oct 21 2005
    • Toronto, Canada
    • Posts 222
    • Points 3,115
    How do I mitigate the effect of motion tracking?
    There's a great tutorial here on Avid's site that explains how to use the motion tracking in Avid (which is faster and more accurate than After Effects, it seems).  But I have a question I can't find the answer to. It seems the most common solution to stabilizing shots is to use the tracking + scaling, which makes the picture bigger to compensate for the jittery footage. But what if I want to use that tracking data, but MITIGATE how much it attempts to stabilize the footage. That is, rather than making it 100% stable, let's say I want it to be averaged down a bit so that it's only 75% stable. That way, I can take crazy handheld and make it somewhat handheld, preserving some of that motion while still stabilizing it somewhat. Is there a way to change HOW MUCH stabilization Avid adds to the footage?
  • Fri, May 23 2008 12:14 AM In reply to
    • Ra-ey Saleh
    • Sydney, Australia
    • Posts 293
    • Points 3,560
    Re: How do I mitigate the effect of motion tracking?
    In the tracking Window, you have an option to use "SteadyGlide" or "Enable Smoothing" (both mutually exclusive).  By them is a number ('50 by default).  Simply 'dial in' a smaller number.  The higher the number, the more SteadyGlide/Enable Smoothing it does.
    HP 8600 Symphony Nitris DX v3 Sapphire v2.07 Boris Continuum Complete v5.8 AvidFX (Boris Red) Heroglyth v2.6 Vitascene v1 Adrenaline (XP 8400)... [view my complete system specs]
    Ra-ey Q: "How many Editors does it take to change a lightbulb?" A: "Why do you want to change it?"
  • Fri, May 23 2008 1:22 AM In reply to
    • sean90291
    • Toronto, Canada
    • Posts 222
    • Points 3,115
