Latest post Fri, May 23 2008 8:41 PM by AquaPix. 4 replies.
  • Thu, May 22 2008 9:57 AM
    • Sasquatch
    • Nottingham England
    • Posts 520
    • Points 6,235
    BCC field issues with the FX 1500
     I think this might have been covered but can't find the post, sorry.
    With the NVIDIA FX 1500 with the current and correct drivers insalled and performace set as per read me on MC2.8 there are a few open GL BCC 3/4 FX that cause field issues.
    The ones that have given me trouble are advance lense flare and film process.  Using quality optimised render settings causes the 2nd field to blur slightly and the motion detect render settings reverses the field order.
    All other effects seem to be fine.
    HPXW8400 4gb ram Nvidia FX 1500 MC 3 Adrenaline, HP XW8200 3gb ram Nvidia FX1400 MC 2.7 with SDI mojo, Avid express DV. [view my complete system specs]
    Mike Kruft. Nottingham, UK
  • Fri, May 23 2008 10:56 AM In reply to
    • Sasquatch
    • Posts 520
    • Points 6,235
    Re: BCC field issues with the FX 1500
     Working in PAL sd at 1:1 mxf
    Anyone?
  • Fri, May 23 2008 1:14 PM In reply to
    • Chad
    • Joined on Fri, Oct 14 2005
    • Sydney, Australia
    • Posts 89
    • Points 1,040
    Sasquatch - I feel your pain,  Same FX, same problem - I've never found a solution
    Avid MCA 2.7.7 on WinXP Sp2 HPxw8400 with 3GB Ram [view my complete system specs]
  • Fri, May 23 2008 1:27 PM In reply to
    • Sasquatch
    • Posts 520
    • Points 6,235
     too bad, maybe it will be fixed in an upgrade
  • Fri, May 23 2008 8:41 PM In reply to
    • AquaPix
    • Joined on Sat, Sep 16 2006
    • UK
    • Posts 389
    • Points 4,795
     I have had this before too. I guess yoir  problem is that DV and SD 1:1 have the opposite field order in PAL and you have either mixed material on your timeline or have switched between 1:1 and other formats.
    If you want to avoid the problem in the future stick with only one format throughout (transcoding footage if necessary) and selecting the right field order from the start.
    MC3.0, QT7.4.5, Vista Business x64, Intel Quad Core Q6600 @ 3.4GHz, Asus P5K Mobo (FSB 1500MHz), 8GB RAM (OCZ Reaper @ 950MHz DDR II), GeForce 8800GTX... [view my complete system specs]
